Old 06-01-2014, 09:01 PM   #1 (permalink)
Default Two new flight behaviors
Recently my Nano started two different things. Would like some help to fix:
1. In flight, for no reason - in a hover - the heli shakes and shudders - a light but annoying tremble. Then it smooths out and goes away. It might come back every 40 seconds or so. Ideas?
2. On start up, the power suddenly dies - then powers back up and stays on just fine. I have to wait before taking off to see if it gets past that point. Ideas?
60 Years Young, Cleveland, OH
Newbie - October 2013
Syma 301 - Syma S107 - Blade 120SR - Blade CP X - Blade 130X - DX6i
Biggiekay is offline        Reply With Quote Quick reply to this message
Old 06-01-2014, 10:24 PM   #2 (permalink)
The first issue could be the feathering shaft, my ncpx does the power on power off thing, on mine it's the battery conection on the board needs re soldering.
terryv83 is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 04:19 AM   #3 (permalink)
Issue 1) could also be dirty servo(s), especially if you haven't cleaned them for some while. The Nano is making constant adjustments in-flight, so the servos are always on the move. If the tracks aren't clean, that can mean the servo thinks it's out of position and moves far too much, then it "realises" and goes back. Doing that will cause a shake.
Issue 2) could well be a power issue, weak batteries, poor connection to battery or board etc. Mine sometimes does it though, if it does I "reboot" because I don't trust it to fly properly. If it's more than a now-and-then thing it's worth looking into.
Belt CP/Blade 400 hybrid with RDTS mod
Blade mSR, Blade mSR-X, Blade mCP X (V1), Blade Nano CP X & QX
Buzzfly BE (aka Walkera 4#3B)
wulfrun is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 04:24 AM   #4 (permalink)
The shiver in a hover is most certainly oxidized servos! Deoxit or a manual cleaning will solve this problem. Just did it on my BL.
The 2nd problem sounds like a bad battery, unless it is with all your cells. Then I am not sure...could be a number of things all related to poor or loose connectivity.
obi
"Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.” L. da Vinci
Exploring the other side of the disk: Taranis (+OrangeRX). nanoCPX (AD mild-BLv2), mCPX dbl-BL (BLHeli XP-12A/HP10+XP-7A/HP03T-4000KV), Align-AD Trex 150 (BLheli+HP8).
Obijuan Kenobe is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 08:24 AM   #5 (permalink)
Motor be going bad?
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7
Courtesy Clerk at Safeway, Lonetree!
Varc is offline        Reply With Quote Quick reply to this message
Old 06-03-2014, 09:58 PM   #6 (permalink)
When a dirty servo causes it to shake, it will usually be sporadic. The dirtier they get, the more it will shake, until it does it all the time. All of the mcpx's I've had (3) were really bad about that, I was always cleaning the servo's. My Nano's haven't done it yet and one of them is like two years old. I was the first person to get one from my lhs, I grabbed one off of the pallet before he had a chance to put them on the shelf. Any time one of my Nano's would shake, well more of a shiver, it was because the blade grips/feathering spindle was a little loose.
Every AS3X based heli that I've ever had would cut out every now and then. Most of them, I would just rebind and the problem would go away. Again, except for the mcpx's. They were the most problematic helicopters I ever had. If rebinding don't work and your batteries are good, you have a bad connection somewhere.
Mark Ball is offline        Reply With Quote Quick reply to this message
Old 06-05-2014, 06:05 PM   #7 (permalink)
+1 to what others have suggested.
1) I know this sounds stupid but have you checked the main gear, it will slide up and down causing the vibes to come and go. 2) Like everyone else has suggested, the servos might need a cleaning 3) Also, motor or main board has gone bad, check all your connection wires on the board. Make sure none have come loose.
Sent from flying shrapnel that once was a heli
"If you aren't crashing...you aren't flying"
ZMR250-ZMR150-Custom 250 hex
-Nic, Team Mesa RC Foam Fighters Elite
Wildcat1214 is offline        Reply With Quote Quick reply to this message
