Like Tree4Likes
Old 08-31-2011, 01:17 AM   #1101 (permalink)
Default Governor Mode - Looking for direction
Hi Guys,
I have an Align RCE-BL60G here and am having trouble finding any good info about how to get this setup in governor mode.
Bob, do you know of any place where they spell out how to get this set up along with the flat line throttle curve and pitch curve?
Even a link to the esc manual would be awesome.
Thanks a million.
TM
HeliJib is offline        Reply With Quote Quick reply to this message
Old 08-31-2011, 04:04 PM   #1102 (permalink)
Team Taco VP
My video (step 15) on page one of this thread for ESC setup goes all through it.
As for setting up gov you simply enable it (Heli+gov) mode and set your flat throttle curve. 80% should do it.
The ESC setup instructions are in the Trex500 manual. You can find that as a sticky thread int he Trex500 forum.
Bob
Old 08-31-2011, 08:25 PM   #1103 (permalink)
Default DS510 servo question
The manual says to use a servo spacer when installing the elevator servo, as you did with the servo you used. however, I am not finding anything resembling this in the supplies given. Am I missing something, or do I need to manufacture one like you did? I purchased the 500ESP 3G kit.
I would still have two extra servo nuts, shown below, but won't I need those for the DS520 tail?
ID:	250470   Click image for larger version
Blade MCX2, Blade 120SR, Blade mSR, Phoenix sim, Align T-REX 500 ESP 3G, Blade mCP X (in that order...)
firefamily5 is offline        Reply With Quote Quick reply to this message
Old 08-31-2011, 09:57 PM   #1104 (permalink)
Team Taco VP
I believe Align now supplies a long ball for the elevator servo so spacers are not needed with their servos.
Bob
Old 09-01-2011, 07:53 AM   #1105 (permalink)
I will check that out after work....
Thanks so much!
Old 09-08-2011, 05:45 PM   #1106 (permalink)
Default Flybar Balance Issues
Hi Bob,
Big thanks once again for all you've done to help us all out.
Have question here about flybar balance. I going through my heli (trex 500) and doing a proper balance on almost everything. I thought I had a bent flybar when I popped off all the links on the head and the birdcage flopped to one side as if it were totally out of balance.
I inserted a new flybar, tightened everything down, and same thing happened, the birdcage went to extreme pitch when the links were disconnected.
So I loosened the four birdcage screws and the two flybar set screws just a tad and the birdcage was perfectly flat. When those screws weren't tight it was perfectly level!
When I tightened down just one screw the birdcage would flop over to one side.
I was told to try tightening the screws and put a slight bend in the flybar and that would level out the birdcage...
What do you think?
Leave it the way it is knowing that when the screws aren't tight it's balanced or tighten all the screws down and try to tweak the fly bar a bit to level the birdcage.
I'm trying to get all the vibes out cause I'm planning on using an onboard vid camera down the road so that's why I'm getting pretty picky here...
Thanks for you time...
Old 09-08-2011, 09:41 PM   #1107 (permalink)
Team Taco VP
Remember set screws have what are called "dog ears" and when you tighten them on a shaft the set screw cuts a ring in the shaft to "set" the screw. So if the flybar was just a little off to one side causing the balance issue, then when you loosen the set screws and move the flybar to balance, re-tightening can put the set screw right back where it was and into the cut ring in the shaft. Makes sense?
So to get it balanced loosen the set screws and rotate the shaft so there is no chance the set screws will try to sit in the old rings in the shaft. Now tighten one set screw. If balanced tighten the other. Now you will have to realign the paddles as you rotated the flybar.
Bob
Old 09-09-2011, 08:24 AM   #1108 (permalink)
hey BOB will we see a GP900 video for the new 500E PRO setup?
Ktmheli is offline        Reply With Quote Quick reply to this message
Old 10-27-2011, 04:52 PM   #1109 (permalink)
"hey BOB will we see a GP900 video for the new 500E PRO setup? "
I hope so, coz I am about to start my Pro build this weekend
nbells is offline        Reply With Quote Quick reply to this message
Old 11-11-2011, 03:00 AM   #1110 (permalink)
Very helpful, thank you!
Kilomeater is offline        Reply With Quote Quick reply to this message
Old 11-30-2011, 09:24 AM   #1111 (permalink)
Hi
Is there videos for trex 500e pro?
thanks
novice77 is offline        Reply With Quote Quick reply to this message
Old 12-01-2011, 02:01 AM   #1112 (permalink)
Team Taco VP
The 550 and the 500/600 are all SO much the same you should not need a specific 550 video. Watch those 500/600 vids and then ask specific questions in the Align forums.
I would have loved to do a 550 video but Align never asked me so I don't even own one nor had the chance or desire. I honestly have not been interested in buying one myself either. It seems now they are getting Jeff Fassbinder to do "professional" videos for you all on Align products so it appears I wont be asked again. If I buy an Align product myself, trust that I will do videos for you guys Thats a promise I always will keep!
Bob
Old 12-01-2011, 07:29 AM   #1113 (permalink)
thanks bob
Old 12-05-2011, 12:50 PM   #1114 (permalink)
Just started my T-Rex 500. Awesome set of videos! Thanks for putting together.
cruzurr is offline        Reply With Quote Quick reply to this message
Old 12-13-2011, 03:20 PM   #1115 (permalink)
Hi,
Here in my first post I want to say thank you very much to Bob for these exellent build video's. I'm currently building my first 500 class heli from CopterX.
Once again, thanks Bob and greetings from Amsterdam, The Netherlands!
Molari is offline        Reply With Quote Quick reply to this message
Old 12-18-2011, 07:22 PM   #1116 (permalink)
Love it!
hobbypartz is offline        Reply With Quote Quick reply to this message
Old 01-14-2012, 01:34 PM   #1117 (permalink)
Where you put home made spacers on the elevator servo so the ball link is central to the frame, could you not simply bend the metal servo arm so it is central?
Great build video's
Cheers, OD.
If you make a mistake and learn from it, that's progress
2 x Nano heli's - now passed on to Megan, HoneyBee V1.....Awaiting test flight, T-Rex 250 V1, Hitec 5084MG tail servo, DX6i, Walkera 4#3A (it's in fairly good hands Bugster).
oliverdots is offline        Reply With Quote Quick reply to this message
Old 01-14-2012, 01:42 PM   #1118 (permalink)
Team Taco VP
I am not into bending servo arms. It's called metal fatigue. I suppose it could work but to me spacers is the proper way.
Bob
Old 01-31-2012, 10:49 AM   #1119 (permalink)
Default Trex 500E Pro
what is the best tail servo to use that will fit in the frame without mods
Josh S is offline        Reply With Quote Quick reply to this message
Old 01-31-2012, 01:11 PM   #1120 (permalink)
Default Trex 500e Pro
do i need a receiver with a sat or can i just use one like in the blade 400
