Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
08-25-2011, 02:45 PM | #1 (permalink) |
Jive 80HV on 6v?
So are there any known issues running the internal bec at 6v?
I've heard mention that there are some issues running 6v but wasn't sure if it was the HeliJive that had the issues. I have run the seond/slave rcvr plug to help ditribute the amp load. My Jive 80HV is new running version 9. My equipment is 3-8717's a 251 and a vbar w/ rcvr. 12s w/ a HKIII4025-500 on a Furion 6 Thoughts or suggestions?
Robert Ables Gaui USA Team Pilot / Cyclone Blades Scorpion Power Systems / MKS USA / Optipower / VP Racing Fuels / YS Engines |
08-25-2011, 03:02 PM | #2 (permalink) |
Well..., depends on the servos in use, how prone they are for producing a high amount of back EMF voltage (generator voltage).
The higher the BEC voltage by setup the higher the risk that the monitoring processor in the JIVE will cut the BEC output voltage if exceeding limits by servo generator voltages on top. It starts to get critical from 6.5 volts on, the BEC output will be cut at the latest at 7 volts. From JIVE's firmware version 9 on the BEC output will be disabled for only 250ms, after that the controlling processor will try to bring the BEC back. But this can be dangerous anyway, especially for FBL systems, except of Vbar, because the stabilisor w'd try to recalibrate, which is impossible in-air. It has been observed that the use of both BEC leads (master+slave) will increase the risk for a cutoff caused by overvoltage. On the other hand we cannot pass on the 2nd lead because we need a source resistance as low as possible. A buffer battery can help here also. "Generator servos": JR, Savox, Align (OEM), some HiTec also. "Less generating servos": BLS e.g. See also http://62.153.249.80/jlog/jlog2-en/f...upport-battery. Tom
Tom (j-log.eu) |
08-25-2011, 03:36 PM | #3 (permalink) |
The vbar can make a Hotstart within a few 0.1's of a second. it will reinitialize based on the last good cold start.
Designing/Building the HEX Helicopters Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk, |
08-25-2011, 03:47 PM | #4 (permalink) |
What are your recommendation for me then.
Just run the stock voltage setting? 1 lead or 2? Or add an out board bec?
08-25-2011, 05:24 PM | #5 (permalink) |
Run 6 volts if you like to.
In any case use TWO leads. But also: Use a buffer battery, a pack of 4x Eneloop 800mAh w'd be sufficient. (Power up sequence: First the BEC, then the battery.) --- And, please: We're not talking about an autorotation to make on that battery. This BEC is extremely strong and reliable. Tom
Tom (j-log.eu) |
08-25-2011, 05:37 PM | #6 (permalink) |
Doesnt matter.
08-25-2011, 05:53 PM | #7 (permalink) | |
No good to inject into the not running BEC causing the JIVE's processors to run on that voltage. Why? Because all the power-up procedures would run against a hardware not supplied (drivers, switching FET bridges). ------ Hey, this is now the second time... Tell me please, what sources you refer your better knowledge all the time? Experience as a user? Experience can be deceiving sometimes.. Just because something several times had no negative impact, that does not mean that it is correct. "Take over" here, I'm anyway since longer tired of forums. My little JLog support forum is enough.
Tom (j-log.eu) |
08-25-2011, 09:55 PM | #8 (permalink) | |
Those servos are so bloody fast you won't notice the difference in 5.6v and 6v. Especially as awesome as you fly! A lot of the 6V issues were from the old v7 firmware. Run both leads, don't shorten them and 5.6V will help to eliminate any of the back EMF stuff the other really smart guy was talking about! Im running one at 5.6v with two leads and never had an issue with the Align servos or the Futaba ones I'm running now.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR |
08-26-2011, 01:29 AM | #9 (permalink) | |
And I'm talking about 500flights/startups per jive.
08-26-2011, 03:08 AM | #10 (permalink) | |
Off topic. Sorry.
How can you know that it will work with all firmware versions of the JIVE so? At least you did not differentiate on the firmware version. I understood it correctly? No diode, or similar, which is to avoid current flowing into the BEC? Okay... Now tell me please, why in the world, I should waste my time by trying to answer questions from the perspective of a bit more inner technical knowledge? There will always be people like you that argue that as a user, they knew better. --- Parable: Ten times already I've been standing during a thunderstorm with a long, vertical metal rod in my hand in an open field. Nothing happened. So you can do it. I know why I actually left all the forums, I forgot that apparently only for a moment. You would also explain to me the operation of the JLog from the definitive knowledge of the user where I know every bit to his name. This is a combat against windmills.. -- Carry On. I no longer want. Am not in a huff, I only was just forgetful. -- "Peace, joy, pancakes", as the German says.
Tom (j-log.eu) |
08-27-2011, 07:08 AM | #11 (permalink) |
It has nothing to do with the firmware, as the hardware in the jive is capable of accepting it.
There actually is a diode in the BEC of the jive
08-27-2011, 08:15 AM | #12 (permalink) | |
Sorry, guy, but you're hopeless clever fellow!
You know nothing. Do you know the circuitry of the JIVE and functional details of the firmware of the processors? Hardly. Are you an experienced electronics engineer? Quite obviously not. I don't like to say such thing, but when I graduated, you're probably still running with the tin drum around the Christmas tree. tss tss tss... This is all quite annoying.. --- And also: You simply do not understand. But thank you that you have reminded me that it really makes no sense to post in forums. - Thus it is clear: I am not here to run a "professional" dispute about how Kontronik ESCs work. Such disputes I have with Kontronik, but not with users. Ergo, it's just an annoyance, if my statements are tough negated by posts from users like you. Information that I have to give the sense of this board, are devalued as a result, distorted, fogged. The whole thus makes no sense. I will just continue, from to time to write a FAQ article under "Related" on J-Log.net, which is definitely more efficient. I'm gone. Congrats, dear friend. That was my last post in this board. I Kontronik already said that I will not go on here. K should "send a substitute", if they want. Maybe RH will do it, but very likely no one. Ciao.
Tom (j-log.eu) |
08-27-2011, 12:39 PM | #13 (permalink) | |
5.6V is fine, you will not notice any difference in flight between 5.6V and 6V with 8717's anyway. Absolutely run both leads from the Jive to the Vbar/Rx. Buffer pack is just added safety, and Kon. Recommends. 8717's are very amp hungry servos.
"If you think you can or you can not you are right" Goblin Xera 4530, YGE 160,VBar Diablo, HJive, 4525 Ultimate,VBar Synergy N5C sitting in Box... |
