550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
05-12-2014, 01:56 AM | #21 (permalink) |
8kHz PWM and 12 degrees timing. I'm swing 550mm blades on 6S.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB 250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL 500E DFC Pro VBar, 500E SDC ZYX-S KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon |
05-12-2014, 06:23 PM | #22 (permalink) |
Anyone know anything about these HobbyKing motors?
I'm running the Align 70A ESC with the original gearing from the first run of kits. I just need something similar to the 600MX in performance and one that will fit the original frames and motor mount. Turnigy T600 1100Kv http://www.hobbyking.com/hobbyking/s...arehouse_.html Turnigy T600 1400Kv http://www.hobbyking.com/hobbyking/s...arehouse_.html Turnigy HeliDrive SK3 1100Kv http://www.hobbyking.com/hobbyking/s...arehouse_.html Thanks.
Jonathan Livingston Helicopter Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
05-12-2014, 06:29 PM | #23 (permalink) |
05-12-2014, 07:26 PM | #24 (permalink) |
Now that's what I call a clone.
Seems like the power specs and dimensions are right on...even looks like the 600MX. I'd just like to hear from someone who actually used one of these options since HK stuff is such a crap shoot. Thanks, I'll keep that one on my list.
05-12-2014, 07:57 PM | #25 (permalink) |
Not sure if this helps, but I have the 500 version of that motor and I like it better than the Align 500MX. They're also a great price:
http://www.hobbyking.com/hobbyking/s...dproduct=37458
05-12-2014, 08:28 PM | #26 (permalink) |
That definitely helps, thanks again.
05-13-2014, 01:59 PM | #27 (permalink) |
ended up going with Scorpion HKIII-4025-1100 and a castle 130 esc. hope to fly this weekend and check it out, any thoughts on the 5 amp bec that comes with this esc or do i need to also get a castle 20 bec? , only do sport flying with the stock servos.
05-13-2014, 03:43 PM | #28 (permalink) | |
05-13-2014, 05:08 PM | #29 (permalink) | |
Look at diameter C, they're all larger than 47mm. You want a motor that has at least 1mm clearance on each side i.e. 45mm diameter. |
05-13-2014, 09:02 PM | #30 (permalink) | |
Looks like the 1220Kv motor beenflying linked is still an option.
05-13-2014, 10:33 PM | #31 (permalink) |
Be prepared to carve the frame because the 4025 is too big for the 550. I did the same thing for my 550V2 and it appeared like I would have to cut way too much for comfort. I was fortunate enough that a buddy had a 600mx laying around.
Logo 690sx / Logo 480 Xtreme / Goblin 570 / QAV 250 [/SIZE][/SIZE][/COLOR] [/COLOR][/SIZE] |
05-14-2014, 11:48 AM | #32 (permalink) |
, Now with the new setup , the ar7200bx goes crazy when i plug the battery in, is it poss the castle 130 internal bec dosn't have enough power to intialize the ar7200bx?
05-14-2014, 01:32 PM | #33 (permalink) |
Define "crazy".
What EXACTLY is it doing? There is a section at the bottom of its manual that describes various flashing lights and sequences. You may want to have a look.
OXY5 MEG / 12S RAW KSE / 14S TDSF / 6S OXY rep |
05-14-2014, 02:01 PM | #34 (permalink) |
servos go back and forth to full lock ,, swashplate goes all crazy!!!
05-14-2014, 03:49 PM | #35 (permalink) |
What color are the lights on the Beast when you power up and what sequences are they performing? If there is an error the Beast will tell you what it is by these sequences.
Let me know what you see.
05-14-2014, 11:58 PM | #36 (permalink) | ||
the same thing happened to me too! The cause of all was the internal BEC Castle esc 100! 5 amp Bec are not enough to feed everyone! Fixed issue with warranty replacement with esc! Replaced with Talon90 .... It has an excellent Bec .... never again had problems! Bye
Sab Goblin 570 12s with Brain Msh Protos Max V2 with Brain |
05-15-2014, 10:25 AM | #37 (permalink) |
(Update!) ,, added bec,, problem solved, now I'm ready to fly!!
05-16-2014, 09:13 PM | #38 (permalink) |
test flight today,, flew ok but my max head is a little low for my liking, only able to get 2350rpms . running a 12t pinion. thinking of trying a 13t pinion. , stock align motor I was running 2450rpms.
06-04-2014, 05:27 PM | #39 (permalink) | |
01-04-2017, 08:16 PM | #40 (permalink) |
http://www.garttmodel.com/EN/product...198&kindid=376
Found this as a replacement will report back after install.
Trex 550 V2 FBL, Logo 550 SX V2, Logo 550SE V2, Oxy 4 Spirit Pro,Oxy 3 Spirit |
