Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Like Tree4Likes
Old 09-21-2014, 02:26 AM   #941 (permalink)
Lots of CAD time on the F-14 gead. I have essentially redesigned 80-90% of the landing gear and have been printing parts like crazy.
Everything red is essentially done with its design work.
Comparf Eurosport
1/7 F-14D
Rave 450, scorpion -10, DS285MG, 3500G, Spartan, 4s 2200 outrage, 6100e, 350mm radix
lookin for another Vibe 50
invertmast is offline        Reply With Quote Quick reply to this message
Old 09-21-2014, 06:21 PM   #942 (permalink)
The main design for the main landing gear is done and all but two parts have been printed in their final form. All i have left to do from this point is mirror the parts for the left side and draw up all the steel hinge pins and either source air cylinder for the retraction and down lock, or design and draw my own.
Here's some photos:
Comparf Eurosport
1/7 F-14D
Old 09-28-2014, 06:52 PM   #943 (permalink)
Im slowly beginning to get the gear fit into the fuse. The mount is just a wee bit to wide, so another update is in order... Which is actually already printing.
Comparf Eurosport
1/7 F-14D
Old 09-28-2014, 07:46 PM   #944 (permalink)
The Capi
Tom get some vid of how the gear rotates 90 while it retracts, love seeing that.
Old 10-01-2014, 09:34 PM   #945 (permalink)
I poured the first prototype tiresa today. The main tires are utilizing a machined aluminum tire mold with a 3D printed cavity plug. The plug is used to decrease material useage and reduce weight. The tire has a slightly thicker area newr the tread and thinner walls in the side. My hope is the hollow nature of the tire will allow a scale squish to the tire but the hardness of the rubber will allow it to spring back to shape.
The nose tire is using a 3D printed mold and cavity tool. This is more of a test to see what kind of quality i can get out of the tire with a $6 mold compared to a $500 mold.
Molds and cavities assembled and material poured:
main tire with the cavity plug removed prior to clamping the two halves together:
Comparf Eurosport
1/7 F-14D
Old 10-02-2014, 12:03 AM   #946 (permalink)
Ok. Custom tires! My brain just exploded. Keep it up.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 10-02-2014, 11:25 AM   #947 (permalink)
Will do, i need to fine tune some aspects of it of it first though.
Comparf Eurosport
1/7 F-14D
Old 10-02-2014, 11:26 AM   #948 (permalink)
Here is the main gear tire. I waited a little to long (about 5 minutes) to pull the cores and join the molds so it didnt join together 100% around the seam. I figured this would happen, but the test was a success with the cavity core mold. Ill do the second one here in a bit.
the nose gear tire printed mold produced a pretty decent tire. Most of the layers from the printer are visible, but i believe it i use a smaller nozzle and thinner layer height, i can produce reasonable finished tires. This is encouraging as it will allow me to do alot of one off designs for wheels and tires without having to invest in expensive aluminum molds.
This photo the tire still has the mold release in it which makes it look much worse than it does in person.
Comparf Eurosport
1/7 F-14D
Old 10-02-2014, 03:18 PM   #949 (permalink)
+1 absolutely incredible!
This is without a doubt my favorite long term subscribed thread.
One just wouldn't be enough so...
Lean not on your own understanding.
Goblin 500
silas3d is offline        Reply With Quote Quick reply to this message
Old 10-02-2014, 03:19 PM   #950 (permalink)
The Capi
A build that took so long they invented 3D printing !!
Old 10-02-2014, 04:27 PM   #951 (permalink)
And thank god they did! That has saved me over $3,000 in machined parts and MONTHS of rework on just the main gear. The nose gear should be fairly simple after this.
Comparf Eurosport
1/7 F-14D
Old 10-05-2014, 02:05 AM   #952 (permalink)
Over 5 years later this thing is finally sitting on something other than foam. Lol. Both main gear are mocked into place. Everything looks great, now its time to get the cylinders and the nose gear designed so i can get some useable gear for this thing.
Comparf Eurosport
1/7 F-14D
Old 10-10-2014, 10:55 AM   #953 (permalink)
Very, very nice....
Sent from my DROID3 using Tapatalk 2
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote Quick reply to this message
Old 11-09-2014, 06:03 AM   #954 (permalink)
I have been following this build for a while... every time I check back in I am truly amazed!
Incredible work and craftsmanship... keep the pics coming!
badfrog is offline        Reply With Quote Quick reply to this message
Old 03-11-2015, 09:02 AM   #955 (permalink)
Haven't checked this thread in a while, but glad to see the awesome progress Tom!!! 5 yrs has it been that long! wow!
[X]Outlaw is offline        Reply With Quote Quick reply to this message
Old 02-29-2016, 07:52 PM   #956 (permalink)
been almost 2 years now since the last update
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Reply With Quote Quick reply to this message
Old 02-29-2016, 07:53 PM   #957 (permalink)
Well.. 1 year.. but I was wondering about this too recently.
Old 03-01-2016, 02:58 AM   #958 (permalink)
Yeah, really hope this isn't over yet.
In the years I've been following this thread, I've learnt to fly fixed-wing, picked up several new disciplines. I've gone from a 450 Heli to owning mini-quads, flying wings, slopers and DLGs.
Tom, I hope you're well. I understand a lot of things can get in the way of a hobby, but I really hope to see more on this build at some stage.
You've been inspiring to say the least.
Sometimes I don't know why I try, then new parts arrive.
kiwi320 is offline        Reply With Quote Quick reply to this message
Old 03-01-2016, 09:23 AM   #959 (permalink)
Yep almost 7 year old thread now
Old 03-01-2016, 08:46 PM   #960 (permalink)
Im still around and doing well. We had our second child (A girl) in September of 2014 and my son started pre-K this past August. Life has just gotten insanely complicated and busy the past year or two.
The F14 is still in progress, it has just taken a small set back while im finishing up some commissioned jobs.
With the way life has been, ive been offloading projects and future projects to eliminate the road blocks on getting more important projects done. Im currently down to just a few projects needing finished, with the F14 being very high on that priority list.
Not much has really been accomplished since the last update. What i have accomplished is the Nose landing gear design is essentially complete and I started 3D printing the mockup assembly...
Comparf Eurosport
1/7 F-14D
