Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 02-08-2014, 01:38 PM   #1 (permalink)
Default xp7a question
Building bless nano w xp7a esc and all I'm getting is a steady. Beep beep beep am arming the same as my other b less nano any help would be great thanks
golfgolf4 is offline        Reply With Quote Quick reply to this message
Old 02-08-2014, 01:54 PM   #2 (permalink)
Running bl.heli ..don't get beeps out of.e.s.c. at all. On fire up.
Old 02-08-2014, 01:58 PM   #3 (permalink)
Default Re: xp7a question
Constant beeps means the ESC isn't getting a signal.
Sent from my DROID RAZR using Tapatalk 2
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 02-08-2014, 03:48 PM   #4 (permalink)
Is the signal setting in esc set to negative? That would do it...
Edit: I mean in the BLHeli software... That's in the esc lol
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 02-08-2014, 03:56 PM   #5 (permalink)
Just depends on where he is pulling the signal from. There are positive and negative taps on the 3-n-1 to choose from.
Team Newb pilot
Old 02-08-2014, 04:52 PM   #6 (permalink)
Am trying to pull signal from white signal wire off e s c . Got the fire up beeps now but still can't get it to work motor just beeps repeatedly
Old 02-08-2014, 04:55 PM   #7 (permalink)
Where are you pulling the signal from on the 3-n-1?
Team Newb pilot
Old 02-08-2014, 05:03 PM   #8 (permalink)
Where Dylan does off the front of the board
Old 02-09-2014, 02:24 AM   #9 (permalink)
And what's the signal set for in the esc? Try changing it in BLHeli settings...
Old 02-09-2014, 07:02 AM   #10 (permalink)
Did you change the input polarity to negative in the software?
Team Newb pilot
Old 02-09-2014, 09:14 AM   #11 (permalink)
I didn't flash mega did said he flashed it for nano main so I assume it's set right but maybe it isn't..my laptop went down so I can't check till I get a new one .so you think it's in th e blues setup
Old 02-09-2014, 11:26 AM   #12 (permalink)
Tug your signal wire. What kind of wire did you use?
Old 02-09-2014, 03:01 PM   #13 (permalink)
Cat 1wire I think whatever comes with the Steve converter,if ya know what that is .have always used that and am pretty sure connections good ..must be signal setting in bl heli set wrong I assume,, can't mess with that at the moment my laptop go kapoot so am unable to access bl heli...I did get motor to run at one point but motor was running opposite what it should ,,at full throttle motor would shut down and at 0 stick it would run full ,,,super weird I've never had trouble like this have done a lot of mcpx bless builds and four or five nanos so really is driven me nuts...maybe I'm just dumb and am missing something
Old 02-09-2014, 04:29 PM   #14 (permalink)
When the motor spins the wrong direction just reverse 2 out of the three motor wires.
Check your TX for servo /reverse.
Fly your heli.
-רחל is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 05:46 PM   #15 (permalink)
Motor wasnt spinning reverse the controls were reverse full stick motor turn off zero stick motor run wide open
Old 02-09-2014, 06:27 PM   #16 (permalink)
Sounds like the others got it right, input needs to be reversed or you need to use the positive solder point.
Old 02-26-2014, 02:12 PM   #17 (permalink)
anyone know where i can find the hex file for brushless 10 a esc for nan0,,,and where to tap into xp7a esc for flashing on the esc board
Old 02-26-2014, 02:20 PM   #18 (permalink)
anyone know where i can find the hex file for brushless 10 a esc for nan0,,,and where to tap into xp7a esc for flashung on the esc board
The 10amp ESC's use the XP7A codes. The answer to your second question is here,
https://www.helifreak.com/showpost.p...91&postcount=1
Team Newb pilot
