Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Glow
MA Glow Miniature Aircraft Glow Helicopter Support Forum
Old 04-07-2004, 04:21 PM   #1 (permalink)
Default Dial indicating a Tempest fan.
I need to dial indicate the fan on my Tempest and not sure which dial indicators to buy. Is this one good enough?http://www.harborfreight.com/cpi/cta...emnumber=33675 Also any tips on how to do it is appreciated! Thanks
Jimmy
Jimmyy2kws6 is offline        Reply With Quote Quick reply to this message
Old 04-07-2004, 05:12 PM   #2 (permalink)
It should do fine. You will also need a mounting set for the indicator, Harbor should have it.
To do the indicating, remove your glow plug as this will introduce a bit of run-out through loading the bearings. Mount the motor/fan so that it cannot move and also mount the indicator firmly. Set the indicator on the hub top rim and zero it out. Turn the hub slowly and see if the needle on the indicator moves. In an easy explanation, just slowly turn the fan to see if there is a high spot. If so, loosening the fan and turning it 180 degrees to the high spot and remounting it should do the trick. If not, continue to move the fan around and re-tighten at a new spot. Generally, adding a small amount of lube ( I use dish wash soap) and turning the fan on the collets before tightening (as if you are trying to screw it on) helps greatly.
Due to the collet centering, there is not much you can do radially for fan balancing, but you should not need to.
Hope this helps!
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
bigrcr is offline        Reply With Quote Quick reply to this message
Old 04-07-2004, 05:32 PM   #3 (permalink)
Thanks John, I will order them today.
Jimmy
Old 04-09-2004, 10:50 AM   #4 (permalink)
KJH
Jimmy,
I found this one. Includes base, calipers and carrying case, too. Works well. http://www.grizzly.com/products/item...=grizzly&box=5
-Kevin
KJH is offline        Reply With Quote Quick reply to this message
