Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Like Tree1Likes
Old 08-25-2010, 06:05 PM   #101 (permalink)
Originally Posted by Bri View Post
Does anyone have a link to the manual for the CPII? I would like to start reviewing it and figuring out some of this stuff.
Thanks.
You can find the manuals here, at the bottom of the page.
http://www.revolectrix.com/home.htm
Heli Skunk Works
CrazyHeliDude is offline        Reply With Quote Quick reply to this message
Old 08-25-2010, 06:06 PM   #102 (permalink)
Your quite welcome, but you'll soon learn there is not a lot to learn, and any questions feel free to ask
JR9303 / JR9503 / Futaba10CHP
nightflyr is online now        Reply With Quote Quick reply to this message
Old 08-25-2010, 06:25 PM   #103 (permalink)
Bri
I am still just trying to figure out a way to run it (and my gyro, obviously) with a 6 channel receiver (6110e). I would like to be able to........ set it up for: off, flight mode 1, and flight mode2, using a three position switch (idle up).
I am using MS Paint trying to come up with a decent wiring diagram and also trying to figure out how it is all going to be programmed in my DX7.
Brian
T-Rex 700F3C / T-Rex 450 Pro / Blade mCPX / Blade mSR / Blade mCX / Walkera 53Q3
JR X9503 /
Spektrum DX7
Phoenix Sim
Bri is offline        Reply With Quote Quick reply to this message
Old 08-25-2010, 06:51 PM   #104 (permalink)
your gyro gain lead will be removed from your Rx and installed into SV04 of the avionics computer,
"Actual "gain value is now inputted through the CPII to your gyro once setup with the programmer
Now you have an open channel on your Rx
Old 08-25-2010, 07:11 PM   #105 (permalink)
Originally Posted by nightflyr View Post
with out seeing how you installed and did the quick setup it will be difficult to tell where the issue is
Here's how I have the mechanical setup now. The quick setup seemed very straight forward and intuitive. There were no head scratchers during that. Can't be 100% sure, but I don't suspect there's any problem in that realm.
Heli Skunk Works
Old 08-25-2010, 08:19 PM   #106 (permalink)
Might consider moving the main sensor further back on the boom, and make sure that both have as clear line of sight as possible
Old 08-25-2010, 08:23 PM   #107 (permalink)
Granted this is an 800 but you get the idea...
Old 08-26-2010, 09:51 AM   #108 (permalink)
I'll pick up an extension today and move the main sensor back to the horizontal stabilizer.
Still, can't help but wonder why setups similar to mine seem to be working ok, as in the video above. But I'll eliminate all possibilities.
Heli Skunk Works
Old 08-26-2010, 10:01 AM   #109 (permalink)
+1
@Bri Also, (if you have CPII's ON/OFF input now connected to the vacant gain (aux/gear) slot of your RX), be sure to setup your gyro gain to its maximum ends in your TX (i.e. 0% - 100%). And if I understand correctly, you could then use your gyro gain to control the sensitivity of CPII, since CPII will alter it's sensitivity to incremental changes to its ON/OFF input.
Heli Skunk Works
Old 08-26-2010, 01:47 PM   #110 (permalink)
I think you will want to go to your TX settings and set gear to gear if you can. On the DX6i/7 you can do that. It was probably set to gear to gyro and then you adjusted your gyro gain in the gyro screen. After you set gear to gear, the gyro screen will no longer be available. Go to the servo end point adjustments to adjust the gear end points.
Woody_99 is offline        Reply With Quote Quick reply to this message
Old 08-26-2010, 05:33 PM   #111 (permalink)
Well my IRNet programmer gave up the ghost today. Just sorta blinked out and then nothing, so I guess I won't be doing much until I get another one ... if FMA ever gets back to me. What's that rule of heli stuff? .. If it's not one thing it's another?
Heli Skunk Works
Old 08-26-2010, 05:59 PM   #112 (permalink)
did you check your batteries in the programmer???
Old 08-26-2010, 07:09 PM   #113 (permalink)
Yep, replaced them. Tried two fresh new sets. Comes on real dim for a few moments then nothing, just blank. Thing that urked me about it is I just got the hardware set up perfectly per your advice. After 4 days, weather and overcast finally broke for a perfect day, but no programmer
Heli Skunk Works
Old 08-26-2010, 08:50 PM   #114 (permalink)
Well don't feel too bad..I wore the buttons out on mine so I decided to do a little refit and trick up on mine..
Old 08-27-2010, 09:21 AM   #115 (permalink)
Real nice job, Nightflyr. They should come stock like that.
Heli Skunk Works
Old 08-27-2010, 10:45 AM   #116 (permalink)
If you have the CP setup the way you want it, you don't have to use the programmer to check it each time.
It's been weeks and weeks since I've used my programmer and I fly several times a week.
Old 08-27-2010, 10:15 PM   #117 (permalink)
I spoke to Howard about your programmer today, so he is aware of the issue, suggest you try emailing him
Old 08-27-2010, 10:15 PM   #118 (permalink)
Ahhh remember it a cost issue to move into something like this...
Old 08-28-2010, 06:51 AM   #119 (permalink)
Thank you Nightflyr, I much appreciate that.
Heli Skunk Works
Old 08-28-2010, 07:35 AM   #120 (permalink)
Thanks for the info ... very nice to know.
Heli Skunk Works
