Old 02-21-2014, 12:17 PM   #1 (permalink)
Default Help with grounding (pics would be awesome)
So I am new when it comes to Protos (Accutaly helis in general- Noobie). I love my Protos but got a little upset when it crashed on my maiden flight with the BD3SX! I was in a hover about a 8 feet off the ground and then boom it was in the dirt.
After reading some of the threads I have a feeling that static was the cause. It is nice, cold and dry here in WA and the static is out in full force. I had not done any static fighting measures prior to the crash as I didn't have any when flying this summer with my AR7200BX. Now that I have upgraded to the BD I would like to get some help in grounding this heli.
Here is my first step of grounding the motor to the frame. Should I run the wire away from the BD or will this work? I will also be going to Home Depot to get some silicone for the belt.
I am looking for some quick pictures on how people are doing it to help me get it right.
2004sccobra is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 04:08 PM   #2 (permalink)
Did you measure ohms between motor mount and frame? It should have been less than 100 ohms. I've never had to ground between motor and frame. Also, if you are using the conductive boom block and a recent tail boom with bare aluminum, you should be ok at that spot.
The only thing I added was a connection from frame to negative battery (lipo) with a 1k ohm 2w resistor. Never had a static problem since then. I connected one end to the screw that holds the landing gear.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 04:58 PM   #3 (permalink)
I would definitely apply a small amount of silicone spray to the belt - I use small paintbrush. Spray the paintbrush, then run it along the belt while I turn the rotor blades by hand.
Folk say to use "food grade" silicone spray to be sure that it will not degrade the rubber belt or the plastic parts. I never heard of it, but found it on Amazon and ordered a can that should last a few years.
This eliminated the static problems I was having in cold dry Winter NJ with my Mini Protos.
Good luck with your new heli.
flyingw is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 05:06 PM   #4 (permalink)
Default Re: Help with grounding (pics would be awesome)
Graphite spray applied the same way works wonders too. Makes the belt conductive, and pretty much unable to generate any sort of a static charge.
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 05:11 PM   #5 (permalink)
I wil check the ohms when I get home, thanks. Yes I do have the new boom block and boom. Could you snap a picture of that setup? I assume you have it wired in like you would a BEC but only on the negative? what concerns are there with sending that back into the battery?
I just picked up some silicone spray from Home Depot today, obviously not food grade. If this is all I need to do then that will be great. I never liked electrical stuff.
Old 02-22-2014, 12:10 PM   #6 (permalink)
The grounding usually comes from the tail boom to the frame or motor. I was having some static issues with my stretch kit (funny, never had static issues with my stock kit), I scraped off some paint on the tail boom where the servo clamps are, put a wire under the clamp and ran it to the motor bracket nut. Solved my problem.
Chief
ID:	489386   Click image for larger version
RC Chief Hobbies
MSH Protos 500 Flybar, Gaui 200 V2 Flybar,V120D01, V120D02S,MCPx (retired)
Boating Fleet: Toysport Syncron and Triton Monos, 1/10 scale 1967 Miss Bardahl Shovelnose Hydro, Executone semiscale Hydro, OPC Tunnel, Miss Geico Cat
BHChieftain is offline        Reply With Quote Quick reply to this message
Old 02-22-2014, 12:38 PM   #7 (permalink)
Chief
Thanks Chief that looks easy enough! Doing that and the silicone I should be set
Old 02-22-2014, 03:50 PM   #8 (permalink)
+1 on the silicon on the belt. I do that too.
Chief
RC Chief Hobbies
Old 02-22-2014, 04:57 PM   #9 (permalink)
Here is mine.
Tail to Boom:
Boom to Motor:
Name:	2014-02-22 17.49.25.jpg
ID:	489471   Click image for larger version
Name:	2014-02-22 17.51.09.jpg
Having fun. Slowly learning.
Protos Max v1 (800) - 7HV v2 - X7 - Trex 600 ESP - X5 FES - Logo 480 XXtreme - Protos 500 CF Stretched x 2 - Trex, CopterX & Blade 450s - CopterX 250 - MCPX - Nanos - XK 110. MD500 (Funkey / Align 600).
TimM is offline        Reply With Quote Quick reply to this message
Old 02-22-2014, 05:25 PM   #10 (permalink)
Thanks this will give me a place to start
Old 02-24-2014, 11:51 AM   #11 (permalink)
Quik Q) i have a Protos 500 but i have the plasyic frame do i need to ground it at all, i see in the pics you all have the carbon frame
MSH USA Team pilot (Lozki) Protos Maxx V2,Protos 380, jeti DS-14
Lozki is offline        Reply With Quote Quick reply to this message
Old 02-24-2014, 02:15 PM   #12 (permalink)
From what I have read, yes. The belt is what's creating the static and the plastic frame is still conductive.
Old 02-24-2014, 09:41 PM   #13 (permalink)
Check out the Finless Bob build videos,
The second to last video "Final Build Thoughts and Stuff" covers grounding (to the plastic frame)
https://www.helifreak.com/showthread.php?t=105493
Chief
RC Chief Hobbies
Old 02-25-2014, 08:03 AM   #14 (permalink)
sweet BH that video helped alot
Old 03-01-2014, 01:01 AM   #15 (permalink)
Detailed pictures of mine are here:
https://www.helifreak.com/showpost.p...5&postcount=21
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 03-01-2014, 01:03 AM   #16 (permalink)
Awesome thanks.
