500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
09-10-2008, 11:01 PM | #1 (permalink) |
New Flybarless 500 in AZ
Here are the pics of the Flybarless 500 running on 7s. As you can see we have an Sk-360 with a Spartan taking care of the tail. This is the culmination of about a week's work between the Mad Scientist and Myself.
Henry AMA# 899515 Trex 450 SE w/ DX7 Trex 500 w/ 9650's and JR770/8900G |
09-11-2008, 01:40 AM | #2 (permalink) |
I like it !! i am drooling over flybarless heli ... i would like one
i like the link setup done here , but that bolt hanging out of the washout is a downer. how does it fly ? Jason |
09-11-2008, 02:15 AM | #3 (permalink) |
Love your 500 flybarless. I have not seen your kind of conversion of the head before... Does it fly well? You are using only two of the four balls on the swash...
I just converted my 500 to flybarless yesterday. Instead of drilling a hole in the washoutblock to pin it to the main shaft, I flipped the washoutblock upsidedown and used an extra main shaft collar to secure it. Swash is moving freely and looks good. Can post a pic if anyone is interested... My electronics look not so nice compared to yours, but I crash frequently, so I want everything easy to take apart and put together.
Regards perfeet |
09-11-2008, 11:21 AM | #4 (permalink) | |
The Mad Scientist chose to use that bolt because he needed to be able to torque that bolt down and with a set screw only being in 1.5mm it wasn't a very good option. So he opted for the 2.5mm bolt.
09-11-2008, 11:23 AM | #5 (permalink) | |
So far this heli is dialed in. It is very stable yet, snappy enough for 3d. The Mad Scientist designed this particular head to allow for greater resolution than with a direct link to the swash as well as removing some of the load off the nylon geared 9650's.
09-11-2008, 09:53 PM | #6 (permalink) |
In response to the complaint regarding the bolt, we revised the design and went with a larger bolt size which allowed us to use a 2.0mm wrench on the set screw.
09-22-2008, 07:25 AM | #7 (permalink) |
Hi,
it is readly new design/MOD and it also the most simple mod I ever seen. Do you have test fly video yet> I plan to make this mod for my T600 . thank for gread shared pics. regards caotri |
09-27-2008, 10:48 PM | #8 (permalink) | ||||
Hi, I did mod the head for my t600 as your mod on T500 and test fly yesterday with tictoc, sport fly, piroflip.
It work great and I am happy with this mod. thanks for your idea. Pics and video will be put later when I finish to convert them. just want to shared with you all. caotri Update pics links: Trex 600 , stretch to 700 size - Z50A motor - ESC HV85 - blade 710SB Curtis Head MOD
Test fly
09-29-2008, 08:47 AM | #10 (permalink) |
In case you need, I posted the updated Quick reference approved by Art in my site in my signature
www.Heli-RND.com - we ship worldwide free; SK 720, SK 360, DS 760, GyroBot .....mostly FBL only, the good products only www.Heli-RND.com |
09-29-2008, 10:07 AM | #11 (permalink) |
Glad you guys like the setup. So far it has been working out well, we have been experimenting with KBDD head dampners and they seem to be working out well.
09-29-2008, 07:59 PM | #12 (permalink) |
Some more pics of head mod and config of heli
http://www.rc-easy.net/forum/showthread.php?t=714 It is my club forum in Vietnam. Text is in Vietnamese but however I think we see the picture well. Videos are here. Head modify http://video.google.com/videoplay?do...01155422576783 First testfly http://video.google.com/videoplay?do...96602386288187 Second testfly http://video.google.com/videoplay?do...99891610731566 regards caotri |
09-29-2008, 08:00 PM | #13 (permalink) |
i gotta show that site to my uncle
he's in ho chi minh right now and he loves helis especially 90 size |
09-30-2008, 10:34 AM | #14 (permalink) |
I like the mods that you did with your 600, We have a 600e lying around here that we're thinking about stretching and going flybarless with, but we just aquired a Logo 600 3d that is flybarless, and we're doing a comparison of SK360 with Vbar.
So far the SK360 is more user friendly as far as setup goes, but the Vbar has more options.
10-01-2008, 06:32 AM | #15 (permalink) |
gaui just release new flybarless gyro 3 axis and it is really good price 199usd.
10-01-2008, 08:59 AM | #16 (permalink) | |
do you mind sharing how you've modified the mixing arms on the trex 600 washout base in detail? how did you mount the arms going to the swashplate? thanks... Marcel
Never allow someone to be your priority while allowing yourself to be their option! TRex600NSP:TT53,RDX600SB,Mgov/CSM,8717@7v,HS81,6100T/6100G,Hi-flow TRex700Pro:YS91SR,RDX690,MgovPro,8717@7v,9254,DS760/JR8900,SB19/KASAMA TRex450SEV2:2221-6,RTech320,CC60,HS65MG,401/JR3400G,CCBEC6V,3s OutrageG5:1700kv,Ctec350,CC30HV,HS5065MG,DS760/JR3500G,CCBEC6V,6s |
10-01-2008, 09:26 AM | #17 (permalink) |
As you can see on the First page, the pins on the head were cut off and the washout block was drilled and tapped so that set screws could hold the washout block in place. It may seem tricky, but it is a very simple mod and can be completed with all Align parts.
10-01-2008, 10:10 AM | #18 (permalink) |
how about the mixing arms?
10-01-2008, 10:12 AM | #19 (permalink) |
They are mounted in their stock positions
10-01-2008, 10:45 AM | #20 (permalink) |
okay... then this is different with the t600 where the lower metal mixing arms have the A-arm link to the swashplate on the SHORTER side of the metal arm.
@caotri.... any insights on that ? marcel
