Old 08-24-2010, 12:19 AM   #41 (permalink)
NTM
The shorter hubs will keep the blades up out of the grass, and away from the ground on those rough auto's.
They'll still have lots of authority with 105's, the grips are spaced roughly the same as the stock tail.
The longer spindle length on the other hub makes alot less of a difference than the actual blade size itself.
NTM is offline        Reply With Quote Quick reply to this message
Old 08-24-2010, 12:55 AM   #42 (permalink)
We're probably splitting hairs at this point... with either the X800 hub or XT90 hub it's only a couple millimeters either way. You're not picking up much diameter with the XT90 hub or gaining much ground clearance with the X800 hub.
You do need the appropriate tail pitch slider for whatever hub you're using. The UP60050 tail pitch slider has the links offset slightly to work with the longer XT90 hub (wider grip spacing) and the X800-60050 has straight links on the pitch slider to align with the shorter X800 hub (narrower grip spacing.)
It would probably have been easier to go with a QuickUK Trex or Raptor setup from the beginning... that way I could deal with a domestic vendor that doesn't have any communication problems or parts mix-up issues.
Here are pics comparing the two pitch slider versions.
ID:	175990   Click image for larger version
Minicopter Diabolo - BD Axon, Kosmik 200, Xnova XTS 4530-480, 14S 4500, BLS255HV/BLS256HV
Bergen Magnum 44 -
BD Axon, Wren MW44 turbine, BLS156HV/BLS256HV
Jeti DC-16
Kiba is offline        Reply With Quote Quick reply to this message
Old 08-24-2010, 01:25 AM   #43 (permalink)
I'm quite happy with the Quick UK Trex grips and Raptor fork on my SE. But I hope to try the RJX tail this weekend and see how it compares.
BennyTRD is offline        Reply With Quote Quick reply to this message
Old 08-24-2010, 01:27 AM   #44 (permalink)
Hopefully they sent you the right combination of parts.
I'm still waiting for an email back on my order from tonight so they could correct what they thought I wanted with what I actually wanted. And then I'll have to wait a few days to see if what they ship is what I ordered!
I will say if they sent you the correct parts they do fly extremely well.
Update to further complicate things:
RJX just emailed me a corrected invoice.
The following parts are discontinued:
XT90-60528 (tail assembly with longer center hub)
XT90-60222 (longer tail hub)
UP60050 (offset tail pitch slider for the UP60528 all metal tail and XT90-60528 tail assembly, both discontinued)
They have been replaced with:
X800-60528 tail assembly (short hub)
X800-60222 replacement short tail hub
X800-60050 tail pitch slider with straight legs for X800-60528 tail assembly
So for all new orders use the X800 series of parts.
Bergen Magnum 44 -
Jeti DC-16
Old 08-24-2010, 12:25 PM   #45 (permalink)
NTM
It's not hard to see why they haven't met with much success in the north american market.
They make a decent product but their distribution is terrible.
Old 08-24-2010, 12:44 PM   #46 (permalink)
That is an understatement for sure! Between the confusing part numbers, a questionable website, and parts going discontinued and superceded with new ones (in less than a month) it's hard to keep customers happy!
I'm trying to keep a small spare parts inventory on hand because I know I can't count on them to keep making what I'm running now or even ship the right parts in the future.
I'm now going to have a spare inventory of 2 pitch control arms, 1 package of spare delrin inserts for the control arms, a package of spare pivot balls, 2 complete X800-60528 tail assemblies, 2 spare X800-60222 center hubs, 2 X800-60050 sliders, and 2 replacement plastic link kits for the pitch sliders.
That's in addition to the UP-60528 all metal tail and UP60050 pitch slider that I currently have installed on the heli. I figure between 3 complete tail assemblies I should stay in the air for a long, long time.
Bergen Magnum 44 -
Jeti DC-16
Old 08-24-2010, 02:54 PM   #47 (permalink)
Yup, I've run them before.
The trex pitch slider bushing is just a little tight on the mikado tail shaft though, a few moments with a small roll of sandpaper sizes it appropriately.
Best tail you can do though is the rjx setup.
Second best is the quick uk raptor hub and grips with the raptor pitch fork threaded on to the stock mikado brass slider.
I like the raptor pitch fork idea...what version? 30/50/90? E? Thanks for the info!
rotaryguy is offline        Reply With Quote Quick reply to this message
Old 08-24-2010, 02:57 PM   #48 (permalink)
This one.
http://www.readyheli.com/search.asp?keyword=TTRPV0017
Not a real up close shot, but here's the Quick UK Trex grips and Raptor fork.
Old 08-24-2010, 03:27 PM   #49 (permalink)
That one does not appear to come with hardware...how about this version..
http://www.readyheli.com/TTRPV0504-T...0_p_36273.html
I see two main differences, one version uses screws to attach the links to the fork and the one I link to uses pins with c-clips.
Also, does this setup give you any more reach with the links? I have the newest Quick Logo tail with the offset that some are stating does not give you enough pitch in one direction.
Old 08-24-2010, 04:26 PM   #50 (permalink)
I asked the same question and my understanding is the "offset" grips with raptor forks dont work.....hope someone will confirm this....
Thanx
Ken
kenny.c is offline        Reply With Quote Quick reply to this message
Old 08-24-2010, 05:12 PM   #51 (permalink)
I ordered the part number I posted and it came with everything I needed. You use the Mikado brass sleeve and slider, and just screw the Raptor fork onto that. The version I have also has the pins for the pitch arms, and not the c clips. The bolts and bushings that attach the pitch fork arms onto the tail grips came with my Quick UK tail. Depending on what grips you have, you may or may not need all the associated Raptor parts.
I ended up going up 1 servo hole with my tail and got a 54CW and 55CCW in the VBar tail setup, which is where you want it (40-60).
Old 08-24-2010, 07:39 PM   #52 (permalink)
NTM
The raptor fork will not improve the geometry of the newer quick uk grips any more than the stock fork.
The new offset quick uk grips are currently under re-design to give them enough left rudder throw.
Old 08-25-2010, 06:34 AM   #53 (permalink)
Benny, what is the reason for moving the tail servo ball link out one hole? Shouldn't the geometry be the same because you're using the stock slider? Just wondering here, because this mod is high on my to-do list.
Specter 700 V2- Pyro 750-56, Kosmik 200HV, Torq servos, CGY760R
Tron 7.0 - Pyro 750-56 Comp, Kosmik 210 HV-I, Torq servos, CGY760R
Dirtmagnet400 is offline        Reply With Quote Quick reply to this message
Old 08-25-2010, 08:58 AM   #54 (permalink)
NTM
Actually with 5.0, you can move out 1 hole on almost all setups.
Going from 13mm to 15mm and the endpoints usually end up right around 50 and 50.
With a bls251 anyways.
Old 08-25-2010, 09:13 AM   #55 (permalink)
O.K. well i'm using a BLS251 and running 5.0, and i believe i am on the high side of the spec... 60 in one direction, and 48 in the other. This is with the stock tail. I will pick up the QUK T-Rex grips, and Raptor pitchfork and give it a try..
Thanks!
Old 08-28-2010, 03:50 PM   #56 (permalink)
Hi,
To be hunest I really cant folow you guys and al this part numbers maybe its just me but isnt there just ONE best solution? I just want to have the best solution
I want to order this, can someone confirn that I have the correct parts?
http://www.rcmarket.org/tail-pitch-slider-pr-20876.html
http://www.rcmarket.org/tail-rotor-a...-pr-30478.html
http://www.rcmarket.org/tail-pitch-c...-pr-20242.html
Thanks.
Gaui X7
Gaui X5
crash1000 is offline        Reply With Quote Quick reply to this message
Old 08-28-2010, 03:54 PM   #57 (permalink)
this is wat you want
http://www.rcmarket.org/tail-pitch-s...-pr-41743.html
believe me this is the combo you need.
0utrage fusion 50,
hk-4025 630kv scorpion.12s, v-bar, kontronik,
Sponsored by hobbymaniac
Proud to be a Maniac!
hawkins221 is offline        Reply With Quote Quick reply to this message
Old 08-28-2010, 11:53 PM   #58 (permalink)
Incorrect, you can't use the X800 pitch slider with the XT90 tail assembly. The X800 pitch slider doesn't have the arms offset to fit the wider XT90 tail hub.
You need either the XT90 pitch slider with the XT90 tail assembly or the X800 pitch slider with the X800 tail assembly.
The latest part numbers per RJX, as the XT90 tail has been discontinued:
X800-60222 replacement short tail hub (if you want a spare)
X800-60050 tail pitch slider (with straight legs for X800-60528 tail assembly)
XT60054 tail pitch control arm
Bergen Magnum 44 -
Jeti DC-16
Old 08-29-2010, 02:42 PM   #59 (permalink)
well I was just in time to change the order before shipping
Gaui X7
Gaui X5
Old 08-29-2010, 10:28 PM   #60 (permalink)
There's this German Logo-shop with some tuning parts, but I never tried one of those yet :
https://shop.strato.de/epages/612556...gelgelagert%22
https://shop.strato.de/epages/612556...0Kugellager%22
https://shop.strato.de/epages/612556.../Alu-Riemenrad
Anybody who has used one of those ?
Logo600 V-Stabi- BLS252/251 - Jive 80+HV - Scorp 4035-500 (12S)
Prōtos 500 - Microbeast - Sävox DS1250MG/MKS DS8910 - Jazz 80 - Scorp/MSH 3026-880
Funky242 is offline        Reply With Quote Quick reply to this message
