Go Back   HeliFreak > R/C Helicopter Support > Bergen R/C Helicopters
Bergen R/C Helicopters Bergen Intrepid 90 Intrepid Turbine Observer Industrial Twin Observer Turbine Support Forum
Old 02-20-2008, 10:08 PM   #61 (permalink)
There is plenty of room on the battery tray for most any requirements, you can also use the bottom of the tray...For this application, without the vibes of a gas engine when I usually install a strong box for the Rx and such, I just laid down some sticky backed Velcro and stick the Rx to it.
A wrap around gives me some more piece of mind, but when you want to move the Rx, you'll find it pretty darn difficult to get it loose from the Velcro bed...
We have in stock (a LOT of stock, ooops) packages of different colored tye wraps from FMP. Use them or Velcro one wraps to secure your wiring into a nice neat bundle. Prevents chafing and loose connections, and looks a whole lot better than a rat's nest.....
Name:	269velcro on batt tray.jpg
ID:	39469   Click image for larger version
Name:	270colored tye wraps.jpg
ID:	39470   Click image for larger version
Name:	271clean wiring setup.jpg
ID:	39471   Click image for larger version
Name:	plenty of room Magnum Tazer.jpg
Chris D. Bergen
cbergen is offline        Reply With Quote Quick reply to this message
Old 02-20-2008, 10:17 PM   #62 (permalink)
With the front end completed, we move to the tail.
The tail boom is aluminum, the Torque Tube drive is aluminum, the boom supports are aluminum, the tail pushrod is......carbon fiber.......HA!
The fins are G10, the tail gearbox is an open style (seems to be a popular way these days...) and aluminum with substantial nylon gears and a 6mm input and output shaft.
For the Tazer 800 and it's extended boom to allow 800mm blades, we use 2 TT shafts and a coupler/bearing carrier with 2 bearings to support it.
Name:	272complete tail system.jpg
ID:	39473   Click image for larger version
Name:	273 TT drive system.jpg
Chris D. Bergen
Old 02-24-2008, 09:51 AM   #63 (permalink)
With the whole assy together, we highly suggest that you "pin" or secure the shafts to the connections. Do this by drilling through the aluminum shaft with a #50 drill bit and creating a divot in whatever is inside the aluminum shaft (gearbox input shaft, coupler in the middle, or dogbone in the front)
The setscrew in that particular hole will then seat down in the divot securing the aluminum shaft, preventing it from rotating on whatever is inside at that particular point.
It is only necessary to do this for ONE setscrew at each joint, NOT all 3. By drilling all three, you run the risk of cracking the end of the aluminum shaft, which then defeats the purpose of securing it.....
Complete assy, ready to install into the tail boom.
Name:	284 whole TT assy.jpg
ID:	39799   Click image for larger version
Name:	285 drill hole in shaft and divot undershaft.jpg
ID:	39800   Click image for larger version
Name:	286 what divot should look like.jpg
ID:	39801   Click image for larger version
Name:	288 complete TT drive train.jpg
Chris D. Bergen
Old 02-24-2008, 10:07 AM   #64 (permalink)
To install the tail drivetrain into the boom, coat the bearing carrier with some grease. This will also make removal, if needed, a lot easier as well. Note that this is ONLY for the longer boom with 2 TT shafts. we'll cover the standard boom later.
Push it all the way in and align the holes for the gearbox screws. If they're not quite lined up, rotate the gearbox inside the boom 180 degrees.
Install the 2 3X4 SHCS bolts. These bolts have been a concern to some. They do NOT require a lot of torque on them, only blue loctite and a snug tightening. If there are vibrations in the tail (tail blades out of balance, a bent hub, for instance) then it is possile that these bolts can come free, just like any other bolt on a helicopter that is vibrating.
Before installing the boom into the helicopter, don't forget the horizontal fin clamp....
Name:	290 grease bearing carrier o rings.jpg
ID:	39803   Click image for larger version
Name:	292pushed all the way in.jpg
ID:	39804   Click image for larger version
Name:	293install bolts.jpg
ID:	39805   Click image for larger version
Name:	294 dont forget hz fin clamp.jpg
Chris D. Bergen
Old 02-24-2008, 10:16 AM   #65 (permalink)
Install the boom into the boom clamps, pushing it ALL the way to engage the dog bone into the delrin coupler.
Now pull it back out 1mm, just enough to relieve any rearward pressure on the tail drivetrain without disengaging the dog bone from the coupler.
After leveling the gearbox, tighten the boom clamps, securing the boom to the heli. There is no need to wrap the boom with electrical tape, or install sandpaper, the clamps will DEFINITELY hold this boom in place!!
Name:	295push boom ALL the way in.jpg
ID:	39808   Click image for larger version
Name:	296pull out 1mm.jpg
ID:	39809   Click image for larger version
Name:	298 tighten boom clamp bolts.jpg
Chris D. Bergen
Old 02-24-2008, 10:25 AM   #66 (permalink)
Our boom supports are aluminum, with delrin threaded inserts on the ends.
The supports are also threaded on the inside, use JB weld to secure the ends into the supports.
Attach them to the bottom of the lower frames, on the outside for maximum boom support, and to the horizontal fin clamp. Install the horizontal fin BEFORE tightening the clamp bolt.
Name:	300boom support set.jpg
ID:	39811   Click image for larger version
Name:	301boom support ends.jpg
ID:	39812   Click image for larger version
Name:	302use JB Weld to install.jpg
ID:	39813   Click image for larger version
Name:	305install horiz fin.jpg
Chris D. Bergen
Old 02-24-2008, 10:31 AM   #67 (permalink)
Install the vertical fin, using the remainder of the boom clamps.
Ensure the fins are straight, the vertical fin is vertical, the horizontal fin is horizontal.
(you'd be amazed by how many people don't know what this means.... )
Name:	307vertical fin parts.jpg
ID:	39815   Click image for larger version
Name:	309vert fin clamp 2nd halves.jpg
ID:	39816   Click image for larger version
Name:	311vert fin vertical.jpg
Chris D. Bergen
Old 02-24-2008, 10:43 AM   #68 (permalink)
The tail bellcrank is the improved one from a couple years ago. It uses 2 bearings and a spacer between the bearings for a free moving tail control system.
On this gearbox it gets a medium ball, then the bolt is threaded into the pitch arm, setting the tension on the bearings for freedom of movement and no slop, then is secured with a jamnut.
If an adjustment is needed, loosen the jamnut first, adjust the bolt, then tighten the jamnut again.
Name:	312tail bellcrank parts.jpg
ID:	39818   Click image for larger version
Name:	316tail bellcrank medium ball.jpg
ID:	39819   Click image for larger version
Name:	318tighten nut to bellcrank bolt.jpg
Chris D. Bergen
Old 02-24-2008, 11:12 AM   #69 (permalink)
The pitch slider is dual ball bearinged, the pitch plate is threaded onto the tube with a left hand thread, which keeps it secured without any JB weld. By the way, all assemblies that you find in our kit such as the pitch slider and tail gearbox are permanent assemblies, meaning it is NOT necessary for you to take them apart, loctite, and reassemble.
The fit to the shaft and the materials are such that it does require lubrication. Use a light machine oil such as 3 in 1 to ensure a free moving system. The shaft itself may require cleaning from deposits left when it was ground. A little 409 takes care of it.
The medium ball sits in the delrin cup of the bellcrank. If this joint is a little tight, use your ball link reaming tool to size the cup. It is possible to replace the cup if needed, it's threaded into the bellcrank.
Name:	319tail pitch slider.jpg
ID:	39821   Click image for larger version
Name:	320place pitch slider on shaft.jpg
ID:	39822   Click image for larger version
Name:	321pitch slider ball in cup.jpg
Chris D. Bergen
Old 02-24-2008, 11:26 AM   #70 (permalink)
The tail rotor system consists of a HD steel hub (standard, not an upgrade or aftermarket piece), aluminum tail blade grips (standard, not an upgrade or aftermarket piece) with 2 radial bearings already installed and a thrust bearing.
These are the new improved geometry grips, enhancing the tail control system.
The hub is installed onto the shaft with ONE setscrew, and loctite of course, with the setscrew seating into the divot on the 6 mm output shaft.
Name:	322tail blade grips parts.jpg
ID:	39824   Click image for larger version
Name:	323divot on tail output shaft.jpg
ID:	39825   Click image for larger version
Name:	324install tail hub.jpg
ID:	39826   Click image for larger version
Name:	323tail rotor hub.jpg
Chris D. Bergen
Old 02-24-2008, 11:38 AM   #71 (permalink)
The linkage between the pitch slider and tail blade grips are these shoulder bolts, eyelets and plastic links.
Some care here will make a tremendous difference in how your tail "feels" and how well your servo and gyro combo work.
The shoulder bolt is a precise fit into the eyelet, so some lubrication here is needed. Loctite is NOT a lubricant, so take great care to NOT get it into the joint when installing this assy onto the tail blade grip.
When I lubricate my tail output shaft daily, I also lubricate this joint with a drop of 3 in 1 oil.
Name:	325tail blade grips pitch links.jpg
ID:	39839   Click image for larger version
Name:	326shoulder bolt and eyelet.jpg
ID:	39840   Click image for larger version
Name:	327shoulder bolt eyelet LOCTITE.jpg
ID:	39841   Click image for larger version
Name:	328install shoulder bolt into blade grip.jpg
Chris D. Bergen
Old 02-24-2008, 11:54 AM   #72 (permalink)
The layout for the thrust bearings and installation of the tail blade grips.
Notice the shim/washer that goes in first, then the thrust washer that has the larger inner diameter, the ball cage, the thrust washer with the smaller inner diameter, and the securing bolt with washer.
Grease the ball cage before installation, and bolt everything up.
The bolts we use are a high grade bolt, and have only had one pop off due to EXTREME torque being applied to them (and this was some time ago....) We use this exact same system on our Industrial birds swinging 130mm tail blades without any reports of any problems. Your 95mm or 110 mm tail blades should be no problem!!!
Name:	329tail blade grip thrust bearings.jpg
ID:	39843   Click image for larger version
Name:	330grease thrust bearings.jpg
ID:	39844   Click image for larger version
Name:	331install tail blade grips.jpg
Chris D. Bergen
Old 02-24-2008, 12:17 PM   #73 (permalink)
Once installed, you will find some in and out play. This is normal and necessary. When the system is spun up to the appx 8,000 RPM normal operating range, the grips will be slung outward with ALL pressure being against the thrust bearings WHERE IT BELONGS.
Do not shim the play out. Doing so may cause some unintended consequences such as failing bolts, breaking output shafts, vibrations, etc, etc.
ID:	39851   Click image for larger version
Chris D. Bergen
Old 02-24-2008, 12:28 PM   #74 (permalink)
The special ball links we use for tail pitch control require trimming and setup.
First off, remove the ribs on the sides. In extremes of travel they MAY contact the tail blade grips causing a small amount of binding.
Cut the length of the link to 17mm.
Then thread them onto the eyelet.
Snap the link onto the pitch slider balls, noting the orientation, giving a leading edge control.
With the pitch slider centered on the output shaft, the horn on the blade grips should be pointed straight up and down. This is the improved geometry. When hovering, centrifugal force will be pulling on these horns straight out while keeping the proper angle on the tail blades for holding the tail still, relieving the workload from your very low torque tail servo.
It also gives a consistent feel to yaw commands both left and right.
ID:	39853   Click image for larger version
Name:	335cut to 17mm.jpg
ID:	39854   Click image for larger version
Name:	336thread onto eyelets.jpg
ID:	39855   Click image for larger version
Name:	338snap onto pitch slider balls.jpg
Chris D. Bergen
Old 02-24-2008, 12:38 PM   #75 (permalink)
The tail blades included are plastic, 95mm long. You can run up to a 110mm long blade for increased tail authority. They install the same way.
Place a shim/washer on either side of the blade and slide the whole affair into the blade grip, lining up the hole. Install the shouldered bolt (shouldered for strength, vs an all threaded bolt) and nut on the opposite side.
There are 2 schools of thought on how tight to make the blades. I tighten mine up enough that they won't fall under their own weight, but can still be moved by hand very easily. Others leave them very loose, depending on centrifugal force to pull them out. I am not aware of any problems either way.
Note the direction of rotation and the "leading edge control".
Also note the tail fin on the OPPOSITE side from the tail rotor....
Name:	339tail blades.jpg
ID:	39857   Click image for larger version
Name:	340insert blade into grip.jpg
ID:	39858   Click image for larger version
ID:	39859   Click image for larger version
Name:	342repeat note direction.jpg
Chris D. Bergen
Old 02-24-2008, 12:46 PM   #76 (permalink)
The tail pushrod is Carbon Fiber, for a variety of reasons, it's stiff down the length (doesn't bend easily, therefore doesn't require much support), it's lightweight, and readily available.
Carbon rods CAN split lengthwise, so we utilize an aluminum end on the OUTSIDE of the rod, preventing splits from starting at the ends.
Install the SHCS bolt from the inside of the cap, run the nut down and install the ball link, repeat for other end.
Name:	343tail pushrod parts.jpg
ID:	39861   Click image for larger version
Name:	344insert bolt install nut.jpg
ID:	39862   Click image for larger version
Name:	346install ball link.jpg
ID:	39863   Click image for larger version
Name:	347other end too.jpg
Chris D. Bergen
Old 02-24-2008, 12:54 PM   #77 (permalink)
Using JB weld, install one end onto the pushrod.
Snap this end onto the tail servo ball and with power appllied (gyro switch in non HH to center the servo), Hold it up to the other end where you have installed the rear cap onto the ball on the tail pitch bellcrank.
Mark where it needs to be cut, alowing room for the head of the bolt inside the cap, cut the rod and JB weld the cap onto it.
The ball links allow for fine tuning of the length of the tail control rod, but only to center the pitch slider onto the tail output shaft.
Name:	348JB weld one end.jpg
ID:	39865   Click image for larger version
Name:	349snap on to servo ball.jpg
ID:	39866   Click image for larger version
Name:	350snap on rear end mark rod.jpg
Chris D. Bergen
Old 02-24-2008, 01:04 PM   #78 (permalink)
Mounting the fibreglass canopy is the final step on assy of the heli. We suggest doing the actual cutting AFTER the canopy has been painted. The ears can be a bit flimsy after cutting the center out, which makes sanding the canopy a little difficult. If one is careful, it's not too much trouble, and it is suggested to seal the edges of the paint with CA after cutting. The cutout area is marked very lightly in the fibreglass, although the sanding and painting of the canopy may erase it. Make yourself a paper template prior to painting.
The initial holes are made with an 1/8th" drill bit, then the canopy is placed on the heli to verify that everything lines up. An adjustment can be made at this point by relocating the 1/8th" hole where necessary.
When you have them lined up, use a 5/16th drill bit, RUNNING BACKWARDS, to open up the hole for the rubber gromets. By running backwards the drill bit won't grab and tear the fibreglass or paint.
Install the rubber grommets, putting a drop of CA on the INSIDE to secure them and add to their lifetime.
Name:	351canopy parts.jpg
ID:	39868   Click image for larger version
Name:	352cutout top of canopy.jpg
ID:	39869   Click image for larger version
Name:	353trim inside of canopy.jpg
ID:	39870   Click image for larger version
Name:	356dremel with drum.jpg
ID:	39871   Click image for larger version
Name:	357 1 8th drill hole.jpg
Name:	359locate on heli.jpg
ID:	39873   Click image for larger version
Name:	360 open holes with 5 16th.jpg
ID:	39874   Click image for larger version
Name:	361install grommets.jpg
Chris D. Bergen
Old 02-24-2008, 01:12 PM   #79 (permalink)
This is everything included in your kit. We'll work on setups, blade installations, battery installations and speed control setups next.
We will have this bird at the Birmingham Funfly, and will be giving away a Magnum Tazer kit to some lucky registered pilot! So come join us for a great time at Dave Harkey's place. I'll let you fly this bird (if you can demonstrate that you can at least hover ), and show off all of the current offerings from Bergen R/C.
Name:	358locate on heli.jpg
Chris D. Bergen
Old 03-19-2008, 09:24 AM   #80 (permalink)
The Tazer 800 is now available, http://bergenrc.com/SearchResults.ph...042&Submit2=Go
Chris D. Bergen
