Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > Belt CP
Belt CP E-Sky Belt CP
Old 10-16-2012, 11:44 AM   #21 (permalink)
Originally Posted by cofl1001 View Post
Guess what I just did? OMG
I went in the underground parking where I practice my hovering, and I think I managed to adjust my tail servo so I don't have it spinning anymore. Then I keeped in a nice hover, landed, throttle to minimum(closed), then I thought: let me switch to mode 1 on my gyro, I switch it then a loud noise like something shredding plastic....
I hit the idle up...yes, I'm the biggest noob, how could I do this ???
I think that on idle up by having the throttle to minimum I had -7 degrees negative pitch pushing the heli into the ground? I guess.
Now I have to change the gear
Any guiding regarding this? Do I have to remove the main blades and open the chassis in half?
Please post any useful links regarding this since I couldn't find any clear info that I could digest...
Thanks again
I promise you that you are not alone. We should ask Tom, and you could ask me. Tom was far less fortunate than you and I were. I have done it more than once, and like you just ended up with a shredded main gear, which actually is no big deal. I'll leave it to Tom to describe his misfortune, as I doubt I could do it justice. By the way, after you have been in the hobby for a while you will find that shredding a main gear is something that happens all the time, it just happens in different ways when you start out.
In the early days, if I had little tip overs, then the main gear was stripped. This was fixed by upgrading the gear, but soon after I found new and better ways to crash, such that an upgraded gear was of no benefit anyway. Once I got better, so did my crashes, and at this point I could go back to the stock eSky gear, as it didn't matter what I had on, I just stripped them anyway. In other words, you stop hitting idle up by mistake, and you stop tipping over as you take off or land, so the only way to spoil the gear is to pile it in, and when you do that it always goes, so the cheaper eSky gears became an option again.
In all my days, I have never, ever, stripped a tail drive gear. The slightly smaller one under the main gear, so if you are going to stock up on spares, do not put one of those on your list. On the odd chance that you do break one of those, then I guess you'll have to wait, but the odds are not worth carrying one in advance. I never bother with them for any of my helis, and if I did break one, well, that's the chance you take when you work out what spares are required to be in stock. The maingear, is one such item that you should have in stock. I usually have two or more in stock, or to put it another way, when I get down to two I will re-order. There are upgrade options, and in the begining they are well worth considering.
Once you have checked the link, and followed the advice, you will be able to swap one out in double quick time, especially after you have done it 100 or so times, lol.
Cheers
Sutty
Regards, Sutty
Old 10-17-2012, 10:49 AM   #22 (permalink)
I broke three of them in fairly quick succession. One probably indirectly a casualty of a stripped main gear. The two after, I have no idea why they went. All three suffered a single tooth breaking off completely. The daft part is, the leftover "root" of a broken tooth looks just like the tooth is still present until you really get a light shining in at just the right angle. The clue is the ticking noise and weird tail behaviour. I have two "in stock" but haven't broken any more since (sod and his law, as I have two spares!).
Belt CP/Blade 400 hybrid with RDTS mod
Blade mSR, Blade mSR-X, Blade mCP X (V1), Blade Nano CP X & QX
Buzzfly BE (aka Walkera 4#3B)
wulfrun is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 11:05 AM   #23 (permalink)
Go figure! There's always one, lol. Bet you never break another one again and didn't have them in stock when you did, lol.
Regards, Sutty
Old 10-17-2012, 01:01 PM   #24 (permalink)
Gee, me break a main gear? Thanks, Sut!
Honestly, I've stripped main gears on just about every heli in my fleet.
Look at it this way, it's a perfect opportunity to inspect your bearings.
To change it, it's a pretty simple and straight forward process.
Pop off all your links to the swashplate from the servo's.
Pull out the jesus bolt from the gear.
Remove the locating pin from the swash or the guide, and lift the whole shaft and all off.
Just be sure you don't twist the link eyes and everything should assemble the same. Get into the practice of double checking your set-up, though. Good insurance.
The 450 EFlite main gear is more durable, maybe less wobble, too.
If you go that route just make sure you get the one with the bearing installed.
I absolutely hate the stock main gear.
Make damn sure you set the back lash when changing out the main gear or you'll be in for a world of hurt.
Loosten up the motor to the frame, put a piece of paper inbetween the main and the pinion gear, push the motor up against the main and tighten back up.
Afterward, rotate it by hand and see if you can detect a high spot where it gets rough. This signals you that the main gear is not concentric.
If you find it is not concentric, the repeat then process with the main gear at that high point, so it has enough clearance.
When you rotate the paper out of the main gear, examine it for tears in the paper. If there is then you are too tight.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel,
PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv.
Tomstoy2 is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 01:38 PM   #25 (permalink)
Of course I didn't have spares when I broke them - like I said, Sod and his law
Keeping two spares almost guarantees no more break...
Old 10-17-2012, 02:31 PM   #26 (permalink)
+1 to the blade 400 gear, with bearing. Always ran smoother, and a little stronger than the stock gear
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head
T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG
E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades
TRex600N, Kasama Head, OS50SX
copterboy is offline        Reply With Quote Quick reply to this message
