Old 12-29-2012, 01:47 PM   #101 (permalink)
so i guess a little bit everything
I like the work done on the shaft - never real thought about the predetermined break point with a C-clip --- very true
certainly does make it a weak point
Originally Posted by powercroco View Post
no, it is not the same motor, but similar ... to rs-e (backiron); hacker (stator holder); pyro (fan) and scorpion (magnetic ciciut regarding hammerhead/magnet ratio)
n spec of 5+4 YY is 510/V (post #13)
(you should read all the first posts of this thread!)
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
HeliFX is offline        Reply With Quote Quick reply to this message
Old 01-11-2013, 04:42 PM   #102 (permalink)
Recently i've rewound one of Quantum 4530. This is a very "courios" motor, like a Xera 4530, and with some similar expect. Selected winding are 4+5x1.4YY for 520 Kv value.
ID:	382883   Click image for larger version
ID:	382884   Click image for larger version
ID:	382885   Click image for larger version
ROCK 'N ROLL
www.gmaurobrushless.it
GMAURO is offline        Reply With Quote Quick reply to this message
Old 01-11-2013, 09:27 PM   #103 (permalink)
Based on the stator shape, teeth/slot ratio, magnetic saturation in the stator may never happen even at high amp...How exactly to determine the best ratio of teeth/slot considering magnetic saturation and weight? or what would be the amp limit for a given teeth/slot ratio?
STSD
modisc731 is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 06:51 AM   #104 (permalink)
Default Quantum 4530-YY 419Kv 6+5 1.32mm
Before:
After:
Copper increase: 38%
Kv changed from 443 to 419rpm/V (YGE 18deg setting)
Resistance unchanged: 12.8mOhm
Next to his baby brother:
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16
_Dekker is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 10:08 AM   #105 (permalink)
Very nice Dekker!
I am struggling right now with my Xera 4530 and 1.5mm wire. No tools I currently use will fit properly to flatten the wires. Have to think of some sort of alternative or maybe re-think the approach.
belcom is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 11:55 AM   #106 (permalink)
Mooi Bert, lyk fantasties!
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Stolla is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 12:22 PM   #107 (permalink)
Do Quantum motors have better stator coating than Xera? On Xera it is paper thin and pretty easy to damage or even peel off.
Old 06-28-2013, 02:41 PM   #108 (permalink)
Baie dankie/ thanks
The Q4530 coating is the thinnest compared to Align/Kontronik and quite fragile on the outer edges. You have to take that into account, or it will certainly damage in those areas.
To me the removal of the original wind was more of a problem, it took me longer to get the original wind off than to put the new one on (I wanted to count original turns). It is really very well fixated on these motors with some sticky glue/varnish that is impregnated into the whole winding. Trying to remove the winding in a hurry will also cause to damage the stator coating quicker.
Old 05-19-2014, 03:04 PM   #109 (permalink)
Bumping an old thread, but how does one set the proper endplay on one of these Quantum 4530 motors?
I just installed a new one on a build, and the vibration analyzer in my SK-720 went crazy, triggering a high frequency vibration alarm at about 410 Hz (24600 RPM). The spectrum shows the majority to be "up-down" vibration (i.e. along the motor shaft), with no significant components in the lateral or for-aft directions. The bearings don't feel "notchy", so I'm thinking it might just an excess endplay issue (even though I can't feel any endplay by tugging on the stator/can with my hands).
I suppose I can press the shaft farther into the can, but then I don't think I can reattach the c-clip. How do you motor winders deal with this issue?
NRPY is offline        Reply With Quote Quick reply to this message
Old 05-19-2014, 03:10 PM   #110 (permalink)
Sometimes changing the settings on the ESC will solve vibration problems, see the thread about the Pyro600 motor with vibes.
https://www.helifreak.com/showthread.php?t=617154
VControl
Old hand at Planks
Peter
Old 12-24-2014, 02:29 PM   #111 (permalink)
Default Use paper on this one...
Done one of those. same pattern as the first one Ralph did. Was real fun winding until...
Can definitely say the coating is too weak - I was on a trip when i winded it and couldn't check for shorts with a megger. A multi-meter showed no shorts, but when i got home i discovered one coil shorted on the 1000V test Definitely use paper on this one!.
So had to un-coil that one and put paper on the corners. Also put 3 layers of varnish beneath the coils and the stator (glue to the corners) from fear of future shorts. Hope it will hold.
Here is the data after winding 1.4mm (4+1)+4, if it helps someone:
R=0.0096 mOhm.
N-spec = 524 (castle. high) (517 for both partial motors).
Io = +-3.5A
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
