Go Back   HeliFreak > R/C Electronics Support > Xnova Motors Support
Xnova Motors Support Xnova Motors Factory Support
Old 05-20-2014, 02:23 PM   #21 (permalink)
All Xera motors have two bearings at bottom and one at top. They will last long without maintenance. Spring washer is not something new, other motor manufacturers used them too. From angle on your photo it isn't clearly visible if your motor have equally spaced magnets. We talk about 0.2 to 1mm difference in magnet spacing. It will be better visible if you you do photo with direct look in can from end of shaft under right angle. I seen four Xera 4530 cans ( two was my own ) and none had equally spaced magnets.
swalko is offline        Reply With Quote Quick reply to this message
Old 05-20-2014, 02:56 PM   #22 (permalink)
hmm sorry never seen that, but still wondering how is this possible when they use a crown to center.
aniway, just seen this video,
i think the performance is kind of WOW,, they say temp is around 50C,, this must first be beaten,,
Xnova XTS-4530-525KV ,Wicharid Ridbamrung, Gaui X7 (2 min 46 sec)
silverbullet is offline        Reply With Quote Quick reply to this message
Old 05-20-2014, 06:31 PM   #23 (permalink)
thanks for the photo's.
yup they did nice job on rewind.
I guess someone reading this forum
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
HeliFX is offline        Reply With Quote Quick reply to this message
Old 05-20-2014, 07:59 PM   #24 (permalink)
CHC Benefactor
Originally Posted by silverbullet View Post
ok this is the 4530-525kv,
what is see:
1.
3 Bearings ,2on top 1 at bottom.
2.
They add this spring washer, actually never seen this before,they say it will reduce noise and lifetime.
motor really spin very smooth and quied.
3.
Magnets are very clean glued in, and nice secured with a crown.
4.
Stator is nicely done, handcrafted, looks they spend alot of work for this, winding looks nice also.
i cant see the magnets are any off like swalko said,specially with a crown its impossible,, AND at least they dont falling off from the can,like on some 800USD motors, if you know hat i mean
Looks very nice. What size bullets does it come with?
Old 05-20-2014, 10:29 PM   #25 (permalink)
Default Xnova XTS 4535-460kv 4+5YY (1,5mm thick wire)
^^Doesn't you put them on.
Team aircapitalheli.com
Travis(twill)
Aircapitalheli.com
Xnova motors and kbdd blades
Twill is offline        Reply With Quote Quick reply to this message
Old 05-21-2014, 01:09 AM   #26 (permalink)
powercroco is offline        Reply With Quote Quick reply to this message
Old 05-21-2014, 06:30 AM   #27 (permalink)
CHC Benefactor
Indeed. However, was just checking as it seems like they might have been included.
Old 05-21-2014, 06:42 AM   #28 (permalink)
It comes with 6mm bullets.
Envoyé de mon iPad à l'aide de Tapatalk
pitounet is offline        Reply With Quote Quick reply to this message
Old 05-21-2014, 08:39 AM   #29 (permalink)
CHC Benefactor
Old 05-22-2014, 11:46 PM   #30 (permalink)
there are also more fotos if you have fb.
https://www.facebook.com/radarflightschool
Old 06-24-2014, 05:45 PM   #31 (permalink)
Hi, what do you guys think about the copper fill of the stator ?
Old 07-24-2014, 09:30 AM   #32 (permalink)
About to try a 4535-460 in a 700e v3 using a 13T/110T gearing. Yes swapping in a 160A ESC. (-: I also have a 4530-500 that I will try. The 4539 is 535g. The 4535 is 620g.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 07-24-2014, 01:10 PM   #33 (permalink)
We'll I have seen you fly in some videos. I'm curious as to what you think of it. You can really push it so let us know.
Travis(twill)
Aircapitalheli.com
Old 07-25-2014, 02:15 AM   #34 (permalink)
A flight video. It is a 4530 not a 4535.
http://www.youtube.com/watch?feature...&v=j_z-Wib1_-A
Old 07-25-2014, 09:11 PM   #35 (permalink)
nice video for sure..
goblin 700 stillwater TWill KBDD XNOVA XTS 4535-520 (3 min 31 sec)
TitaniumFreak is offline        Reply With Quote Quick reply to this message
Old 09-19-2014, 09:36 PM   #36 (permalink)
No need to photo, which is very in accurate in showing whether stator is well assembled, or centered, or magnets are symmetrically placed. The best way is to feel and count number of coggings per revolution, and the strength of the cogging.
perfectly manufactured 12N10P motor (width of teeth head ≈ width of magnet), will have 60 evenly strong coggings per complete revolution. My two plettenberg orbit has perfectly 60 evenly strong coggings. 3 scorpion HKIII4035, only one is kinda perfect 60 coggings; other two has 60 coggings, but not evenly strong.
Till now, i have never seen a 12N14P motor with 84 equally strong coggings....sad. normally they would show 14 coggings, or no clear coggings, indicating something is not symmetrical.
oh, just in case anyone does not know:
number of coggings = minimum multiple of "P" and "N".
but this is just a general rule, when width of teeth head is roughly equal to width of magnets.
when magnets are significantly wider than teeth head, there might be more coggings. for example, 12N8P should have 24 coggings per revolution, but when width of magnets reaches ~1.5X width of teeth, there could be 48 coggings.
STSD
modisc731 is offline        Reply With Quote Quick reply to this message
Old 09-22-2014, 01:22 AM   #37 (permalink)
You probably mean the Least Common Multiple, donīt you?
Lada1 is offline        Reply With Quote Quick reply to this message
Old 09-23-2014, 03:54 AM   #38 (permalink)
Yes.
STSD
Old 10-04-2014, 02:50 PM   #39 (permalink)
Just noticed Xnova is really doing some useful work. Though it is simple equation, finally can see some useful parameter of motor on manufacturer's webpage.
http://www.xnovamotors.com/xnova-4530-450kv/
Best efficiency of a motor at certain voltage is achieved when copper loss = iron loss
iron loss ≈ Io*V
copper loss = Rm*I^2
best efficiency current I = (Io*V/Rm)^0.5
STSD
