Old 07-08-2012, 11:45 AM   #1 (permalink)
HSC
Default SK540 governer furstration, help !!!
******************************************** PROBLEM SOLVED ************************************************
Hello boys !
Hear is my setup : Gaui X2, YGE 30, SK 540, hs5065ciclic, DS 95i, original Scorpion, Hyperion phase TP 850 65c.
I try ewery posible way to get governer to work, but no luck soo far, werry furstrating...
I setup ewerything like wizart say but I get no success....
I have set ESC to mode plane fast, in the start I get a litle kick, but I can live with this
The rpm s nicely locked too 2500, first desired speed (i get bog too 2400 at 14 deg of pich ).....
Then I swich to idel 1 desired speed 3200, get to that area speed on head 3200, but when I put full pich, I get bog down too 2400, so I gess governer not locked, then I swich to idel 2, rpms doo not change a bit, but they should too 4000....
The diferent colores on rpm windows in software showind that idel is swich too higest rpms, but stays on 3200 and bog too 2400.......
What em I missing hear.?????
Help !!!!
Regards
A je to ?
HSC is offline        Reply With Quote Quick reply to this message
Old 07-08-2012, 11:51 AM   #2 (permalink)
#1 don't use plane mode in the ESC
use a heli mode.
#2 do you have the proper gear ratio set?
and #3 are you sure with your gearing you have the proper headroom for the gov to maintain what you want?
CeeveeSiN is offline        Reply With Quote Quick reply to this message
Old 07-08-2012, 12:57 PM   #3 (permalink)
HSC
Hello !
Same situation with heli mode, ewen worst ( lawsy reactions).
Gear ratio has enough headroom ( works pretty much fine with YGE governer )
Gear ratio in SW is set 120/15*6/2...like wisart say...
If I decreash rpms on 1500 governer holds too, buy if i goo ower 2400 I get a lots of boging....
Heli can only hover, nothing more....
A je to ?
Old 07-08-2012, 01:04 PM   #4 (permalink)
=] use a hobbywing platinum......
Old 07-08-2012, 01:17 PM   #5 (permalink)
HSC
Why not YGE ?
Where is the problem ?
It is only soft statrt or is something else ?
Regards
A je to ?
Old 07-09-2012, 12:28 AM   #6 (permalink)
HSC
OK !
I will try Hobbywing this afternoon then.....
Will report back....
A je to ?
Old 07-09-2012, 03:33 AM   #7 (permalink)
Old 07-09-2012, 12:21 PM   #8 (permalink)
HSC
Hello !
Mee again........................
Today I have tryed 2 diferent "dump" conrolers.......
1.st one hobbywing ( original gaui 22A), prety nice softstart,
2.nd Align 18A original from Trex 250, preppt nice soft start too...
Well the case wass ewen worst, there was only 1 level of rpms and not governated at all....
What i em doing wrong ??? Is there maybe governer bug in SK 540 software ????
Otherwise great device i have tuned pretty much with YGE internal governer, and I like it werry much soo far....Only this stupid governer problems....
P.S.My hyperion senzor is good I have 2 of them and governer do not work with either.... When I pluge it too E - meter works perfect....
A je to ?
Old 07-09-2012, 12:33 PM   #9 (permalink)
there is no bug I have it working perfectly on 2 different helis.
1 electric 1 nitro.
are you sure you even have the gov engaged?
there is a checkmark that says manage collective or something like that right next to the RPMs if that is not checked it's not turned on.
also checking that will enable the gain for the gov.
Old 07-09-2012, 02:45 PM   #10 (permalink)
=] https://www.helifreak.com/showthread.php?t=428191
Old 07-09-2012, 04:06 PM   #11 (permalink)
HSC
Hello !
Soo the pich managment hook must bee on ???
I have this hook disabled all the time...
Regards
A je to ?
Old 07-09-2012, 06:10 PM   #12 (permalink)
Yes, manage collective on
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 07-09-2012, 11:30 PM   #13 (permalink)
HSC
Hello !
Soo this colective managment window must bee hooked If wee want too governer work at all....
Can someone please screen shoot setings for governer.
Is there maybe some PDF or something for setup governer ?
A je to ?
Old 07-10-2012, 02:51 AM   #14 (permalink)
HSC
Hello !
It is mee again , this thing real do not let mee sleep....
I was thinking in there must bee done some calibration of trotle on the spped controler- hooked to SK 540 ? , to SK 540 know where are the endpoints of the controler.....
Regards
A je to ?
Old 07-10-2012, 03:08 AM   #15 (permalink)
=] we use the gov wizz to set this up.....
Old 07-10-2012, 04:45 AM   #16 (permalink)
HSC
I understand ...
- But I would like to know how the neutral pulse of speed controler should bee set....
- For exsample OFF position of speed controler is 0,95 ms , full position of sped controler is 2,00ms
Regards
P.S. or maybe governer have anything too doo with PPM satelit reciver wich I em ussing ( Jeti )
A je to ?
Old 07-10-2012, 02:17 PM   #17 (permalink)
HSC
Hello !!!!
I must say THANX BOYS !!!!!, It works with all speed controlers...
Problem gone, governer works like no governer in my arsenal and I have a lot of JIVEs.
The problem was not hooked colective managnent window, why is this no asigned in any manuals or even in setup video, or visart ???
I have some smal wag in tail, but wee will managed this....
Othervise GREAT device and I higly recomended too anybodey over other similar devices........
And I have some smal question or if someone have a link to manuals where is this described, what purpose or function have this windovs : "OVERRIDE" and "DISABLE WITH TAIL BANK 2"
A je to ?
Old 07-10-2012, 02:35 PM   #18 (permalink)
=] "collective management" is optional, this has no effect on the gov function other than to enhance it.
tail 2 disengages the gov, this is for nitro users.......
Old 07-10-2012, 03:02 PM   #19 (permalink)
Hey,
It's really strange that your deep bog-out is depending on the "collective management" checkbox.
What this checkbox does is to overwrite the collective input receiving from the Tx with a smaller/smoother one IF the rpm drops too low.
It seems that your power components (gear ratio, motor, ESC, battery) are not able to deliver the performance you are intending to fly with your collective stick-input on your Tx.
Anyway... You're happy so we are
"disable with tail bank 2" is explained by georgi.
"override" is the amount of rpm value that is added when bog out appears. So if you set your bank to 3000rpm and override to 100 as soon as your rpm starts to drop the SK tells the ESC to hold 3100rpm. You should not go below 100 for the override.
If you use the professional data logger you can see this rpm change in the log - I'm not sure if this is a feature of the SK540 though. My SK720 does it
Soko
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 05:19 PM   #20 (permalink)
My governor is still 150 rpm off...its so weird...
It flies great though...I just set it to 2350 to get 2200.
This log also has a funny event in the end where my telemetry alarm shuts down my DX8 in the end for a split second...but thats another story
But check the rpm...nice and steady on 2200.
And i am totally fine with the vibration level now..
Maybe someone can have a look in the setup file too.
I have no idea what could be wrong.
The math works, the Hyperion sends the signal to the SK720 and the TM1000, I even checked it with an optical sensor.
Its bang on 2200 but the gov is set to 2350/2400
Scorpion 4025 HKIII 10 poles 112/12 gear 9,333x10/2=46,66
ArguZ is offline        Reply With Quote Quick reply to this message
