View Poll Results: Are you happy with your 3G?
Yes 109 60.89%
No 30 16.76%
Undecided 40 22.35%
Voters: 179. You may not vote on this poll
Old 09-10-2010, 03:10 AM   #1 (permalink)
Default Happy with your 3G?
Are you happy with your 3g?
Yes, no, undecided?
Compass 6HV, TotalG, BLS251, DX7S.
Kasama Srimok, Scorpion HK-4525-520KV, TotalG, BLS251, DX7S.
...and the rest...
Corrari is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 04:03 AM   #2 (permalink)
Very happy with my 3G which I've had since first release.
My 700n is rocksolid.
Standard wiring configuration too. Nothing wrong with the small wires/power bus as far as I'm concerned.
New addition is a 550e 3G which I will enjoy tweaking.
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro | JR DSX9 Limited
Team RCBits | Team Lynx
HiroboFreak is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 01:06 PM   #3 (permalink)
YESSIR! Had It since the 6 and 700 le kits came out(avtually about 2 weeks before they hit the market) and cut my teeth on the 600 first. Heck of a learning experience. Wouldnt give it up for anything in the world. (and YES......ive flown PLENTY other systems. ) Just....like......3g personally. PEACE!
jondabear is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 01:16 PM   #4 (permalink)
I am undecided. I just put the sensor on 4010 tape/copper plate/4010 tape sandwitch. I haven't tested it yet, so if it doesn't tail kick on me, then I am satisfied. Any tail kick at all = unsatisfied, and will DIRECTLY result in the 3G system being in the trash can...
Blade 350QX - BNF with GPS for $399 tons of fun.
T-rex 700E V-BAR V2-B Tail, DFC Head system, Outrage 9188 tail, 610's, Quantum 4530-500, slant gear. Scorpion Commander V 130A with SBEC, Running V-Bar gov - the best governor combo ever. Maiden Flight: 6/5/2010 - Still on stock frame & blades as of Dec 2013.
Mike3DPro is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 01:25 PM   #5 (permalink)
Very happy thanks.
It's all in the setup
TRex 600N CGY750, TRex 600N 3G, TRex 500 VBar, TT Mini Titan VBar
Flybarless is more
serpent887 is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 03:03 PM   #6 (permalink)
Working great on a 600 ESP V2.1.
needmorparts is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 03:21 PM   #7 (permalink)
Sort of... The system is better than folks say; get the heli setup well and the system works very well. However I have traced two weird behaviors on spin up (resulting in minor rebuilds) to their crappy plugs.
The plugs rely on little wires acting as pins. If the wire/pin gets pushed in a bit in the sensor female plug, you can get an intermittent connection that really kills. I am thinking about directly soldering the 4 conductor cable into the sensor (like the Spartan gyros).
Thoughts, or best on another thread?
eXo 500, Goblin 380, Oxy3
tgilton is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 04:28 PM   #8 (permalink)
Undecided as after weeks of playing with the setup I haven`t actually flown the heli properly.
Tag wag in the hover and in forward flight which I suspect is vibration related is the problem.
Flying again tomorrow to test it out after another sensor pad change.
Still got the 3M tape to try and also running the heli with fixed endpoints.
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 ——
malc1 is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 04:50 PM   #9 (permalink)
i am very happy with it:--})
kjetil 79mod norway TREX 700 3G FBL
TREX 700 BeastXFBL
TREX 600 3G align
JR 11X
airskipper is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 05:18 PM   #10 (permalink)
I've got 5 flights on my new 700 LE 3G. I couldn't be happier! Other than an almost insignificant tail issue, I've never seen a heli be easier to dial-in to my liking.
redwingsfan71 is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 06:39 PM   #11 (permalink)
I converted my 700e conversion to 3G....excellent results. Went out and bought another for my 600E a few days later. Both fly like on rails and are quick and stable. Not sure why a few have had problems, all I know is when they 1st get it...upgrade to the current software, then back the gains down to 10:oclock....It will fly great at the default settings...provided the heli was setup properly to begin with. Tweak from there if needed. I fly some 3D and big air...
MA Whiplash-BeastX Fusion 50 3G FBL Trex 700E 3G FBL
Trex 600E 3G FBL (#1) MD500E fun scale Trex 600E 3G
Trex 450 SE V2 Trex 450 SE (Night Flyer)
AMA# 50163
Hangarace is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 07:41 PM   #12 (permalink)
I'm happy with mine for the most part. If you do your homework and figure out how to tweak it properly you will have good results. Do I think it is the best system out there? No. But it isn't as bad as people have lead it to be. I honestly have to say, mine is flying better than I thought it would.
Felt is offline        Reply With Quote Quick reply to this message
Old 09-11-2010, 12:15 AM   #13 (permalink)
+1 Hangarace!
Old 09-11-2010, 06:15 PM   #14 (permalink)
Default Nice to know reasons for failures
It would be another more complicated poll, but I suspect many of the 3G "failures" are set-up issues or problems caused by the extra electrical demands of direct-link torque loads. The question is: How many dissatisfied Align 3G users were first-time FBL users? Perhaps the same problems would have arisen whatever FBL electronics they used.
Thoughts? - especially from dealers or people who sell/support heli buyers and see other people's problems?
Nelson P
npomeroy is offline        Reply With Quote Quick reply to this message
Old 09-11-2010, 07:13 PM   #15 (permalink)
I didn't care for the tale twitch on both my helicopters, I decided not to go with the update but after reinstalling my Spartans the system works fairly well.
Hindsight being 20/20 I would have gone with another Vbar for the cost.
JR9303 / JR9503 / Futaba10CHP
Old 09-12-2010, 12:42 AM   #16 (permalink)
Originally Posted by npomeroy View Post
I suspect many of the 3G "failures" are set-up issues or problems. The question is: How many dissatisfied Align 3G users were first-time FBL users? Perhaps the same problems would have arisen whatever FBL electronics they used.
Nelson P
Very well written, my thoughts entirely, at last some sensible reasoning.
Flybarless is more
Old 09-13-2010, 12:41 AM   #17 (permalink)
I have the 3G Version 2.1 on my 700E and love it. Easy to setup and fly's like it's on rails. Unreal inverted stability in gusty winds.
This is my first FBL and I was really worried with the bad rep it had in the early releases, but it looks like they have gotten most of the bugs out in V 2.1, and it can only get better.
rogersrick123 is offline        Reply With Quote Quick reply to this message
Old 09-13-2010, 12:47 AM   #18 (permalink)
Can those who have it set up perfectly please post up their sensor pad arrangement?
May help those of us who are still having problems.
Old 09-13-2010, 12:48 AM   #19 (permalink)
Have you read the sticky at the top of the 3g forum regarding this?
...and the rest...
Old 09-13-2010, 12:59 AM   #20 (permalink)
Nelson P
Good call. This is my first FBL.
...and the rest...
