Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree1Likes
Old 05-19-2012, 04:37 PM   #41 (permalink)
airframe
v2 model/fbl
align 550 mains and 90mm tails
kde main thrusted bearings
kde gyro mount
align anti rotation bracket
align tail servo mount
power system
scorpion hkIII 4025-1100
700 112 main slant m1
12t pinion
thunderpower 65c 5000 6s
yge 120lv w/heat sink
electronics
ds 610 cyclics
s9256 tail
western robotics super mini bec set to 6v
fullsize vbar 5.2 pro using vbar gov
flight notes
4:30 of mild 3d,funnels,hurricanes,tic tocs,piro flips.
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 07-11-2012, 12:39 PM   #42 (permalink)
Default My Trex 550
Airframe
  • Kit: Stock FBL
  • Blades: Thunder Tiger 550mm
  • Tail blades: KBDD 92 mm (Orange)
  • Landing gear: 550
  • Fins: Stock
  • Canopy: Align upgrade
Power system
  • Motor: Viper VSH6013
  • Gearing: 700 164t : 15t (Mod .7)
  • ESC: ICE 100
  • RX power: CC BEC Pro
  • Main pack: Flightmax 5000mAh
Electronics
  • Cyclic servos: HITEC 546MGs
  • Tail servo: Futaba - Futaba 9254
  • Gyro: TAROT ZYX
  • RX: Spektrum 7100
  • Radio: Spektrum DX7
Gaui X5v2 - Scorpion 4025-1100 | GAUI 100A | Protek 170SBL | Protek 270SBL | AR7200BX
Gaui NX5 - O.S. Hyper 50 | Align DS530 | Align DS535 | AR7210BX
Blade 180CFX | Zeal 155
Spektrum iX12
hoelshot is offline        Reply With Quote Quick reply to this message
Old 07-23-2012, 09:22 AM   #43 (permalink)
Airframe
  • Kit: stock FBL V2
  • Blades: EDGE 553mm
  • Tail blades: Align 85 mm
  • Landing gear: standard 550 (rear) and F3C (front)
  • Canopy: stock Align
Power system
  • Motor: X-Era 4020/2y-1000kv
  • Gearing: 112t : 12t
  • ESC: Kontronik JIVE 80+HV
  • Main pack: Bilowy Power X5 5200mAh 50C 6S
Electronics
  • Cyclic servos: Align DS610
  • Tail servo: Futaba BLS251
  • Gyro: HC3-SX
  • RX: Futaba 6203SB
  • TX: T8FG Super
Upgrades
  • OMG carbon fiber frame 2mm
  • OMG vertical fin
  • OMG tail boom support brace
  • OMG frame stiffener
  • OMG adjustable motor mount
  • OMG battery mount
  • OMG tail boom clamp
  • Align tail servo mount
  • Align anti-rotation bracket
  • Align metal tail pitch assembly
  • Heli Option quick release canopy clip
  • Heli Option integrated main shaft block
  • Quick canopy mount
T-Rex 550E V2 FBL / HC3-SX / X-Era 4020/2y 100kv / Jive 80+HV
T8FG Super (Mode 2)
dreaming about TD Rigid
insomnia is offline        Reply With Quote Quick reply to this message
Old 07-26-2012, 07:07 AM   #44 (permalink)
Default trex 550 vbar trouble!?
3 main cogs n 3 pair of tail blades later i still cant set up the vbar
its just the tail part, it looks correct of the ground, end points look right but when i spool it up and get it off the floor, it just wants to spin around in circles. ive tried reversing the rudder in the tx and on the vbar itself through the computer and it still wants to spin. i dont get it!?
its vbar 5.2 and is the standard align tail servo for the 500e.
summa1988 is offline        Reply With Quote Quick reply to this message
Old 07-26-2012, 07:30 AM   #45 (permalink)
When you give the radio right rudder input is the slider on the rudder going toward the tail? If it is hold the heli so that the canopy is toward your left and then with your right hand push just the tail of the heli away from your body, the tail slider should move toward the boom again.
Align Trex 700 V3 DFC HV - Vcontol Touch ¦ Mikado Logo 200 ¦ SAB Kraken 580 ¦ Align Trex 500X ¦ Sab RAW 500
Raydee is offline        Reply With Quote Quick reply to this message
Old 07-26-2012, 11:24 AM   #46 (permalink)
This thread is for "TRex 550e setups, specs and upgrades" only. Please make your own thread for your problem. Thanks.
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 07-27-2012, 12:12 PM   #47 (permalink)
sorry, i wrote this on my mobile n didnt notice it was in the wrong place, i ment to write 550 not 500 aswell.....ups
cheers raydee, ill look at that when my replacment parts come
Old 07-29-2012, 03:59 PM   #48 (permalink)
Default 8 degrees error - HELP!!
The swash plate is level - the swash arms are parallel (90 degrees) - the collective is at center stick (50% on the DX7) - the blade-holder connecting links are 80mm long (per the manual) but the blade holders have 8 degrees pitch instead of 0 degrees pitch.
What in the world am I doing wrong?
captJac is offline        Reply With Quote Quick reply to this message
Old 07-29-2012, 09:34 PM   #49 (permalink)
https://www.helifreak.com/showthread.php?p=3559911
Make sure that you're using a linear pitch curve 0 to 100%
Adjust the pitch links to give you 0 deg.
The lengths in the manual are ball park values, in addition to some manuals having typo errors - make sure you check the link lengths in the Chinese text line.
https://www.helifreak.com/showthread.php?p=3714219
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote Quick reply to this message
Old 07-30-2012, 02:17 AM   #50 (permalink)
Airframe
  • Kit: Stock FBL
  • Blades: Mavrikk 550 and 515mm
  • Tail blades: Stock 90mm
  • Landing gear: Stock
  • Fins:Stock
  • Canopy: Align stock
Power system
  • Motor: KDE 600XF-1175
  • Gearing: Helical 112T main gear, 12T pinion
  • ESC: ICE 100
  • Main pack: Thunder Power 6s 5000mAh 65 and 45C
  • Bec: Castle Creation BEC Pro
Electronics
  • Cyclic servos: Align DS610 @ 7v
  • Tail servo: MKS HBL 980 which is friggin awesome
  • FBL: 3GX v 2.1
Radio and RX
  • Futaba T8FG
  • R6208SB
Specs (flight notes)
  • Flight style: Mild 3D
  • Head speed: Governed 2300/2400/2500rpm
  • Flight time: 4-5 min
Upgrades & mods
  • DFC Head and Swash
  • Magnetic canopy clips
  • Thats it, and it flies great with serious mumbo!
diggyduo is offline        Reply With Quote Quick reply to this message
Old 07-31-2012, 07:45 PM   #51 (permalink)
Airframe
  • Kit: Align V1/V2
  • Blades: Edge 553mm
  • Tail blades: Edge 86mm
  • Landing gear: Align 700 FC3
  • Fins: Stock X's 2
  • Canopy: Canomod
Power system
  • Motor: KDE 600XF-1175kv
  • Gearing: KDE 700 115t main gear & RevCo 14t pinion
  • ESC: ICE 100
  • Main pack: Thunder Power 6s 5000mAh 65C
Electronics
  • Cyclic Servos: Align DS610 @ 6v
  • Tail servo: MKS BLS980
  • FBL: AR7200BX
Radio and RX
  • Spektrum DX8
  • AR7200BX
  • Flight style: Mild 3D/Hard 3D
  • Head speed: Governed 2400/2500/2600rpm
  • Flight time: 4 min
Upgrades & mods
  • CHP 2mm Frames
  • Align DFC Head and Swash
  • KDE Main Rotor Holder Arms
  • KDE Verticle Stabilizer & Tray
  • KDE Performance Tail Upgrade V2
  • KDE OWB
  • V2 Tail Control Rod
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 07-31-2012, 08:14 PM   #52 (permalink)
I just got mine, used, from a friend, who builds beautifully! I had flown it before and liked it.
Airframe
Kit: Stock FBL V1
Blades: Align 520mm
Tail blades: KBDD 84.5mm EE's
Landing gear: Stock
Fins: Stock tail and no horizontal
Canopy: Stock
Power system
Motor: Stock Align
Gearing: Stock 170T main gear, stock 16T pinion
ESC: CC Ice 100
RX power: WR Super Hercules BEC
Main pack: Turnigy 5000 mah
Electronics
Tail servo: Align DS60
FBL Unit: AR7200BX
Flight style: Hard sport flying and 3D
Head speed: have not tached it yet
Flight time: 5min
Amp draw: Have not measured it yet.
Upgrades & mods
TracX Head
I am hoping to take it out and really fly it in the next couple of days (I just test hovered it a short time ago.
Old 10-02-2012, 04:01 PM   #53 (permalink)
My build, nothing unusual here.
Airframe
Kit: Stock FBL V2.1
Blades: Align 520mm
Tail blades: Align Stock Tail Blades
Landing gear: Stock
Fins: Lynx 700 sized Orange Tail fin
Canopy: Stock
Power system
Motor: Stock Align 600MX 1220KV
Gearing: Stock 112T main gear, stock 11T pinion
ESC: CC Ice 100 V2
RX power: CC BEC Pro V2
Main pack: Sky Lipo 4400 30c, Sky Lipo 4400 40c, Gens Ace 5300 30c
Electronics
Tail servo: Align DS650
FBL Unit: Skookum SK540 using 2 DSMX Sats.
TX: DX18 (Just got it Sat.) upgraded from DX8.
Flight style: Sport Flying currently, working up to inverted.
Head speed: 2400-2500rpm at 90% flat curve.
Flight time: 6min on all packs above. They come down with 3.77-79 volts per cell on average.
Amp draw: avg of 45-55amps.
Upgrades
Tarot 2mm side frames and bottom plate. That's it!!
Rockarruda is offline        Reply With Quote Quick reply to this message
Old 10-07-2012, 02:52 AM   #54 (permalink)
Cool Love machine
Airframe
Kit: Stock FBL V1
Blades: NHP 530mm
Tail blades: Align 90mm
Landing gear: HT Unbreakable
Fins: Lynx Orange Tail fin
Canopy: Canomod Smash
Power system
Motor: KDE 600XF 1175kv
Gearing: Stock 170T main gear, 17T pinion
ESC: YGE 100LVVB
RX power: internal BEC
Main pack: Zippy 4500mAh 45C
Electronics
Cyclic servos: Futaba BLS451
FBL Unit: Vbar blueline fullsize
Governor: Vbar using YGE built-in phase sensor
TX: DX8
Flight style: Some kind of 3D
Head speed: 2100-2500 rpm
Flight time: 4.5min, about 30% left
Amp draw: ?
Upgrades
Align DFC head (w v2 blade grips)
Lynx main shaft bearing block
KDE front gyro plate
KDE anti-rotation bracket
QuickUK magnetic canopy lock (T600N)
White paint
other "unnecessary" upgrades:
KDE battery plate
KDE frame boom support brace
KDE tail fin holder
KDE tail servo holder
MicroHeli boom support holder
MicroHeli tail link support
Align aluminium tail-pitch arm
Home-made boom support stiffener
(Belt drive, haven't mounted it yet)
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 12-17-2012, 01:27 PM   #55 (permalink)
Airframe
Kit: Stock FBL V2
Blades: align 520 mm
tail blades: Align 90mm
Canopy: stock
Power system
Motor: KDE 600mX 1220kv
Gearing: Stock 112T main gear, 11T pinion
ESC: cc 100
RX power: cc pro BEC
Main pack: pulse 5000mAh 45C
Electronics
Cyclic servos: Futaba BLS255
Tail servo: Futaba BLS256
FBL Unit:futaba cgy 750 V1.3
Governor: internal cc
TX: futaba 18mz
Flight style: forward flight someday moving up to 3D yessssss
Head speed: 1950-2150-2300 rpm
Flight time: 7 min
Amp draw: ?
Upgrades
Lynx Frame plates
KDE battery plate
Futaba 18 mz, CGY 750, Kontronik esc, BK, Torq or futaba servos, align 550 dfc, align 600n dfc, align 700n dfc, Sab Goblin 500, Sab Goblin 630, Sab Goblin 700,Sab Goblin 700 Comp, Sab Goblin 770.
rovers 550 is offline        Reply With Quote Quick reply to this message
Old 12-27-2012, 10:22 PM   #56 (permalink)
Airframe
Kit: Align V2
Blades: Mavrikk 2Q G5 PRO 515mm WC Flybarless
Tail blades: Stock
Fins: Stock X's 2
Canopy: Canomod
Power system
Gearing: KDE 700 115t main gear & RevCo 13t pinion
ESC: Jive 80HV
Main pack: Ultra Pulse 6s 5000mAh 45C
Bec: WR BEC Pro
Electronics
FBL: Vbar
Radio and RX
Futaba 18mz
R6302SB
Flight style: Sport/Mild 3D
Head speed: Governed 2300/2500rpm
Flight time: 4 min
Upgrades & mods
Fusano 2mm Frames
Align Dual Point Attachment Tail Slider
Team Self
MKS Servo USA
ManiaX Lipos
Nycatt is offline        Reply With Quote Quick reply to this message
Old 12-31-2012, 07:34 PM   #57 (permalink)
Default My Chopper
here it is..
Airframe
Stock out of box
Align Trex 550E V2 3GX
Power System
Stock Motor
Electronics
Stoock speed controlr, castle cc bec, stock head servos, savox SH-1290MG tail servo, Venom 50c 5000, Specrtrum DX6i with ar7610 reciever
Specs
Set up for intermidate to advanced
Stock blades
stock head
Upgrades
Savox 1290mg tail servo
Aluminum tail servo mount
glued two stock tail blades together for less vibration
sickwhip20 is offline        Reply With Quote Quick reply to this message
Old 01-12-2013, 10:50 AM   #58 (permalink)
Default Re: TRex 550e setups, specs and upgrades
Glued two stock tail blades together ? How do u mean
Elliott000 is offline        Reply With Quote Quick reply to this message
Old 01-12-2013, 11:05 AM   #59 (permalink)
I think he means two vertical tail fins.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2
taoY is offline        Reply With Quote Quick reply to this message
Old 03-01-2013, 11:37 AM   #60 (permalink)
Default TRex 550e setups, specs and upgrades
Airframe: Trex 550e
V1 stretched 600 boom
Aluminum lipo tray (tarot)
Aluminum AR bracket
CF UK tail push rod
600 tail grips
Servos:
DS610's cyclic
DS655 tail
ESC:
Talon 90 ( using internal BEC) 6v
And 4" extension wires with 4mm bullets to 5mm bullets
Motor:
BL600MX 1220kv (6s setups)
Gyro:
AR7200BX w/ dsmx sat
Telem:
TM-1000 w/ lipo voltage & motor temp
Soon head speed sensor
Blades:
RJX 520's / Edge 553's
Gearing:
Main gear 170 tooth
Pinion. 17 tooth
Lipos:
6s 4500 mah 30c
TX:
DX8 ( I love it) wayyyyyy better than my previous DX6i.
NANO CPX,TREX 500e,TREX 550 FL STRETCHED DX8 W/TELEM
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
