Old 02-01-2013, 05:59 PM   #161 (permalink)
Default New Futaba 14SG-Telemetry!
Originally Posted by skaluf View Post
The GPS sensors are in stock at Hobbico, so any Great Planes retailer can get one for you. FUTM0850 is the sku.
Steve
That's interesting. Tower has them listed as available early February still..
Anyone know of an online retailer that has them. My LHS doesn't do hobbico.
Alan Butler
Team Synergy
flyalan is offline        Reply With Quote Quick reply to this message
Old 02-02-2013, 07:41 AM   #162 (permalink)
Wow, when I go to Tower's site it says mid-Feb.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 02-02-2013, 11:00 AM   #163 (permalink)
Don't wait until it shows stock for the sensors. If you want one you need to order it. They fill back orders first and then if there is stock left they will reflect that on the website.
FWIW I've been using the GPS module for about 6 weeks now. I've flown it in a smaller (62-inch) 6S pattern practice plane, a 2M pattern plane, and my 3.7 meter thermal duration glider.
I have set up max and min alerts for a number of things and also set switches to announce the current value of a given parameter while flying. I rarely look at the screen until I land. When I do land I can see what the maximum and minimum values were for that flight. So far it does not record for later download, but you can still get good info.
The distance reading can be set for surface distance or slant range as well.
The R7008SB RX also sends RX voltage without any additional sensores and you can get motor pack voltage by buying the small wire sensor that is currently available (CA-RVIN-700) Stock number FUTM5551.
For the voltage you can set low voltage alerts and have it both vibrate and speak the alert voltage. Lots of options and some very interesting info can be obtained during flight.
Team Futaba - Kontronik
Futaba 32MZ/18MZ/18SZ/16SZ - CGY760 and 755
Phaedrus is offline        Reply With Quote Quick reply to this message
Old 02-02-2013, 08:06 PM   #164 (permalink)
DominicD, have you seen this yet?
http://www.rcgroups.com/forums/showp...&postcount=961
Later;
D.W.
Gettin old aint for sissies!
d_wheel is offline        Reply With Quote Quick reply to this message
Old 02-02-2013, 08:36 PM   #165 (permalink)
The Capi
I've known about the Robbe unit for awhile now, that's why I am excited about it slowly making its way over here.
Old 02-06-2013, 07:16 PM   #166 (permalink)
14SG was FCC approved today (2/6/2013):
https://apps.fcc.gov/oetcf/eas/repor...d=AZPT14SG-24G
Doug.
dvelez3 is offline        Reply With Quote Quick reply to this message
Old 02-06-2013, 07:40 PM   #167 (permalink)
Doug.
Very interesting tear down photos, test procedures, etc. After seeing all the PDFs, we're getting a bargain for these radios!
kingmeow is offline        Reply With Quote Quick reply to this message
Old 02-07-2013, 10:51 AM   #168 (permalink)
Formerly BarnStormer
Doug.
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 02-08-2013, 10:18 PM   #169 (permalink)
So will the models set up on an 8FGHS transfer directly to a 14SG?
Got mine preordered today.
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 12:33 AM   #170 (permalink)
Hi, I have transfered 15 models all with either MSH Brain or Vbar and on my 14SG they are identical and not one setting or calibration needed. Even Castle ESC have had the right endpoints. I did check and calibrate each one though to be sure.
You will need an SD card, transfer each model to card on the 8FG and then from card to 14SG.
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L
beans07 is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 02:00 AM   #171 (permalink)
Originally Posted by jamin_00 View Post
This highly advanced Futaba sensor allows you to measure the position ( longitude & latitude), distance, speed, rate of climb/decent and altitude of you aircraft using GPS data and the inbuilt atmospheric pressure sensor for accurate readings.
This system is only compatible with Futaba transmitters that have FASSTest telemetry capability such as the 18MZ and 14SG. Simply plug the sensor into the S-Bus2 Slot in your FASSTest RX and away you go.
• Speed Range: 0 - 311mph (Approx)
• Altitude Range: -700m - +5,500m (Approx)
• Vario Meter: -336 - +336mph (Approx)
Got mine on back order.
Cant seem to find anywhere where it mentions providing lat & long gps position, pretty useless without this info for me!
800 XXtreme, 700 Xxtreme, pimped to the max
2 x Logo 600 V-Bar, Pyro, Jive HV 90, 9451's, 9256
480 Xxtreme, Pimped, HVBK Serves, Best 500 out there!
Just gotta love that smell of electric flight :!: Align - NEVER
Klinger is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 02:57 AM   #172 (permalink)
http://www2.ripmax.net/Item.aspx?ItemID=P-SBS/01G
Also, am I able to use that sensor and one that coming out for the Kosmik too. Can I have more than one device on it and the radio can read both as the Kosmik have a device called TELLME which provides telemetry from the ESC to the 14SG
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 02-10-2013, 08:10 AM   #173 (permalink)
Just checked the UK importer and it now says June the GPS module is due!!
Sod that, I'll just get the GPS module for the Kosmik as that will be the same and no doubt much cheaper than the £150 or whatever it is lol.
Old 02-13-2013, 02:32 PM   #174 (permalink)
Default 14SG
Look what just arrived in the Hobbico warehouse.
Steve
Steve Kaluf
Hobbico
skaluf is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 04:29 PM   #175 (permalink)
Great News Thanks !!
Magneto is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 08:40 PM   #176 (permalink)
Wu Hu.
Hoping mine gets to Heliproz south soon.
Old 02-14-2013, 10:26 AM   #177 (permalink)
Default 14SG unboxing
Here is a link to a short unboxing video that we shot yesterday.
[ame]http://www.youtube.com/watch?v=TfNRJQ6kfqE[/ame]
Steve
Steve Kaluf
Hobbico
Old 03-09-2013, 09:55 PM   #178 (permalink)
Hi folks,
Just read through this thread. I've got my new 14SG and have a question. I noted the posts referring to the LiPo battery from Robbie. The manual in talks about an optional LiFE battery. It even comes with a spacer that's inserted in the battery compartment to allow for the LiFE battery as it's slightly smaller than the NiMH battery that comes stock.
I've not put enough time on my radio yet to have a good idea of what kind of run time I can expect from the stock NiMH battery but am wondering if it's really worth swapping to the LiFE?
Any opinions? (yeah, I know, dumb question, but that's where it's at! )
Thanks & Fly Safe,
Steve R.
Intrepid175 is offline        Reply With Quote Quick reply to this message
Old 03-09-2013, 10:32 PM   #179 (permalink)
I've had mine for about a month now, and am not considering the battery upgrade. There's really not that much difference in Mah of the packs and I got 8 flights on mine today + an hours worth of tweaking and bragging about its features and it was holding up fine. Thats more than enough time for me at any field any day. I dont use the stock charger tho, have made a plug adaptor to a digital charger so I can charge it in an hour or 2 if needed! Some people just feel the need to upgrade everything!
Old 03-09-2013, 10:38 PM   #180 (permalink)
Default Re: New Futaba 14SG-Telemetry!
Thanks Klinger. That's good to know. I do have a Hyperion charger that will do NiMH batteries but I think I'll stick with the factory charger for now. If I get the kind of transmitter times you are, it absolutely won't be a problem.
Fly Safe,
Steve R
Sent from my DROID RAZR using Tapatalk 2
