Old 01-17-2015, 05:59 PM   #1 (permalink)
Default 3GX Signal Noise Causing servos to twitch and ESC to start. Help!!
This question seems to have been asked many times before, but I have not been able to find a straight out answer on how to fix this. I recently upgraded the 3GX to version 5, the latest and greatest. And I noticed that there is this intermittent noise coming from the 3GX that causes the servos to twitch intermittently and the ESC also gets a signal for a split second that makes it spool up. It is just for a split moment and makes the main rotor blades move. Is there a fix to this?
Thanks.
Ed
Roban B407 Scale 700
ikon2, Align 130HV ESC, Align 800MX 530kV, Castle BEC Pro, DS820 HV Servos, Radiomaster TX16S
egiraldo911 is offline        Reply With Quote Quick reply to this message
Old 01-18-2015, 10:02 AM   #2 (permalink)
This has been the known issue since 3.x. Remove the blades and/or disconnect the motor connection(two of the wires) when going through DIR set up. Servo twitch happens on the ground and have not seen any issue flying. Make sure you have an external BEC if you are using stock ESC. 3GX is very demanding and a good supply of power to the unit will resolve a lot of unexplained issues.
nameci is offline        Reply With Quote Quick reply to this message
Old 01-18-2015, 03:45 PM   #3 (permalink)
I have had the same issue. Mostly I just work through it. Blades off or disconnect two motor wires as suggested.
"...And yet, for you, every setback is an advantage, an opportunity for learning and glory." Epictetus, 35 AD, Greece.
meowguy is offline        Reply With Quote Quick reply to this message
Old 03-28-2015, 12:00 AM   #4 (permalink)
Originally Posted by nameci View Post
This has been the known issue since 3.x. ... Servo twitch happens on the ground and have not seen any issue flying. Make sure you have an external BEC if you are using stock ESC. 3GX is very demanding and a good supply of power to the unit will resolve a lot of unexplained issues.
I just installed a new 3GX with v5 and can see and hear an occasional twitch on the swash servos every couple of minutes or so. Do you mean that .Still have not gone into the air so I canīt tell if its still there after airborne but canīt see why it shouldnīt be. External CC Bec here.
I have heard about twiches and wag that go away after reflashing with v5. Might that be the solution?
Mateyhv is offline        Reply With Quote Quick reply to this message
