Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Like Tree2Likes
Old 02-23-2013, 05:50 PM   #41 (permalink)
Originally Posted by thebirdman View Post
Baby is in.................Will start after the completion of the rotormast V22
  • Flight Style: (Sport / Smooth 3D /
  • FBL System: New AR7200BX updated
  • Motor: Scorpion 4020-1350
  • Pinion:18-17-16t
  • Target Headspeed(s):2250-2450-2750
  • ESC: (Pheonix Ice 100
  • Governor: none
  • BEC: Caste/ Hypreron
  • RX Pack:
  • Cyclic Servos: Align DS515M
  • Tail Servo: Align DS615
  • Main Blades: Stock 500mm
  • Tail Blades: Stock
  • LiPos: Pulse 3700 45c, Nano 3850-65c
  • Anything Else: Scorpion Backup Gaurd, to be updated with the new align fbl
  • Oh yeh... Being canadian.....I went with the red and white
-Shane
[/QUOTE]
thebirdman is offline        Reply With Quote Quick reply to this message
Old 02-24-2013, 03:09 PM   #42 (permalink)
Looks like my FBL, servo and ESC/BEC choices are a bit different as most might use them.
Flight Style: Smooth 3D / Big Sky
FBL System: V-Bar full version 5.3 pro (had this from another heli)
Motor: Quantum 4120-1200
Pinion: 18
Target Headspeed(s): 2000, 2350 and 2650
ESC: Jeti Mezon 120
Governor: Jeti Mezon 120 internal governor.
BEC: Jeti Mezon internal BEC with up to 8.4V output (15Amp ESC) with 2 wires
RX Pack: N/A
Cyclic Servos: Graupner HBS 660 HV servos running at 8V
Tail Servo: Torq 9188 running at 8V
Main Blades: Stock SAB 500mm
Tail Blades: Stock SAB 80mm
LiPos: Pulse Ultra 4500 mA 45C
Going to setup the second Goblin 500 very similar while possibly using the Kontronik Pyro for it.
im4711 is offline        Reply With Quote Quick reply to this message
Old 02-25-2013, 04:46 AM   #43 (permalink)
Flight Style: Sport Flying
FBL System: Mini vbar 5.3
Motor: Scorpion Quantum 4120-1200
Pinion: 18T
Target Headspeed(s): 2400
ESC: Talon
Governor:
BEC: Internal
Scorpion backup
Cyclic Servos: Savöx 1250MG
Tail Servo: Savöx 1290MG
LiPos: Turnigy 4000 (40c)
Yaman is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 09:05 AM   #44 (permalink)
Flight Style:*Sport Flying/Smooth 3D*
FBL System:*mini v-bar
Motor:*Scorpion HK4020 - 1390
Pinion:*16T
Target Headspeed(s):*2800rpm
ESC:*Jive 100 LVGovernor
BEC:*7.4V Gryphon
Cyclic Servos:*Hitec 7245 HV
HVTail Servo:*BL 9188 HV
Main Blades:*Stock SAB
Tail Blades:*Stock SAB
LiPos:*Pulse Ultra 6s 3700mah
This is mine
huanbuihd is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 10:21 AM   #45 (permalink)
Flight Style: Sport Flying - Big Air - Light 3D
FBL System: Futaba CGY750
Motor: Scorpion HKIII 4020-1100
Pinion: 18T
Target Headspeeds: 2100-2300-2600
ESC: YGE 90LV
BEC: YGE Internal
Governor: CGY750
Rpm sensor: Hobbywing
Scorpion Backup Guard
Cyclic Servos: MKS DS9660A+
Tail Servo: MKS DS760
LiPos: Pulse 4500 45C
Paint job: Red/white
Gas Goblin 700 - Goblin 380
VBar Control - VBar NEO
Rubin RC - Gas Powered Helicopters - TRM Power
Matwes is offline        Reply With Quote Quick reply to this message
Old 03-04-2013, 10:21 AM   #46 (permalink)
  • Flight Style: Beginner Sport/3D
  • FBL System: Skookum SK720
  • Pinion: 16T
  • Target Headspeed(s): ~2300
  • ESC: Talon 90
  • Governor: SK720 with Eagle Tree RPM Sensor
  • BEC: Talon 90 built in BEC
  • Cyclic Servos: Graupner HBS660 HV
  • Tail Servo: Torq 9188 HV
  • Main Blades: SAB OEM
  • Tail Blades: SAB OEM
  • LiPos: Pulse Ultra 5000 mAH 45C
  • Anything Else: Skookum Power Bus, 2 Spektrum Sats
Sqwrly is offline        Reply With Quote Quick reply to this message
Old 03-04-2013, 11:17 AM   #47 (permalink)
Flight Style: Hard 3D
FBL System: Mikado Mini V-Stabi W/ DSMX Sats
Pinion: 17T
Target Headspeed(s): ~2750-2800
ESC: YGE 120LV
Governor: Mikado V-Stabi W/ YGE Built In Phase Sensor
BEC: Internal YGE
Tail Servo: MKS BLS980
LiPos: GensAce 6S 4000mah 60C
Norman Ross Jr.
Mikado USA -- Insane Canopy -- Scorpion Motors
futurase is offline        Reply With Quote Quick reply to this message
Old 03-04-2013, 10:08 PM   #48 (permalink)
Goblin 500 - Yellow/ Black
Flight Style: Sport Flying - very light 3D
FBL System: MSH Brain
Motor: Kontronik 600-12
Pinion: 17T
Target Headspeeds: 2200-2400-2600
ESC: Kontronik Jive 100+ LV
BEC: Jive Internal
Governor: Jive
LiPos: Pulse 4100 45C; Thor 3800 45C
Anything Else: 2x Spektrum DSMX Sats
• SAB Goblin 500: MSH Brain, Kontronik Jive & 600-12
• MSH Protos 500: Stretched, MSH Brain
• MSH Mini Protos: Stretched, MSH Brain
west5500 is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 09:22 AM   #49 (permalink)
Yellow/Black Goblin
  • Flight Style: Smooth 3D
  • FBL System: MSH Brain
  • Motor: Quantum 4020-1200
  • Pinion: 19T
  • Target Headspeed(s): 2500, 2700
  • ESC: Talon 90
  • Governor: Brain
  • BEC: Talon
  • RX Pack: N/A
  • Tail Servo: Futaba BLS251
  • LiPos: Glacier 30C 4400
  • Anything Else: Spektrum DSMX Satellites
Compass | MKS
[ eXo | Chronos ]
jaofos is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 10:04 AM   #50 (permalink)
ady
  • Flight Style: Hard as i can
  • FBL System:GT5
  • Pinion: 20T
  • Target Headspeed(s): flat out ?
  • ESC: YEP 100
  • Governor: YEP
  • BEC: gryphon 15a
  • RX Pack: N/A
  • Cyclic Servos: Align DS510M
  • Main Blades: 473 edge
  • Tail Blades: 85kbdd
  • LiPos: zippie 40c 4000 and A spec 4000
  • Anything Else: its the red one
ady is offline        Reply With Quote Quick reply to this message
Old 03-14-2013, 01:07 PM   #51 (permalink)
FBL System: Vbar Full size 5.3 Pro
Motor: HK3-4020-1350
Pinion: 17T
Target Headspeeds: 2200-2400-2850
ESC: Castle Talon
BEC: Castle Talon
Governor: Castle Talon
Tail Servo: BLS251
LiPos: Glacier 4000mAh 30C
NeL3D.com
Nelson Rodriguez is offline        Reply With Quote Quick reply to this message
Old 03-21-2013, 11:11 AM   #52 (permalink)
Here is what I have purchased. My goal is to just fly this machine like a full scale machine would fly. At my age the hand/eye coordination is not going to allow me to EVER fly 3D.
RWW
Goblin Red/White
  • Flight Style: Sport / Big Sky
  • FBL System: Spektrum AR7200BX
  • Motor: Quantum 4115-1200
  • Pinion: Stock
  • ESC: Castle Talon 90
  • Governor: Internal (Castle Talon 90)
  • BEC: Internal (Castle Talon 90)
  • RX Pack: n/a
  • Cyclic Servos: Savox 1250mg
  • Tail Servo: Savox 1290mg
  • Main Blades: SAB Stock main blade
  • Tail Blades: SAB Stock tail blade
  • LiPos: Turnigy Pulse 3700 45c 6s
  • Anything Else:
whitehedr is offline        Reply With Quote Quick reply to this message
Old 03-21-2013, 03:48 PM   #53 (permalink)
ady
  • FBL System:GT5
  • Pinion: 18t
  • ESC: YEP 100
  • Governor: YEP
  • BEC: gryphon 15amp
  • RX Pack: N/A
  • Main Blades: 500 SAB
  • Anything Else: its the red one , now with yellow front
More tweaks
Old 03-21-2013, 04:32 PM   #54 (permalink)
  • Flight Style: 3D
  • FBL System: Spartan Vortex
  • Motor: Kontroniks Pyro 600-11
  • Pinion: 18T
  • Target Headspeed(s):2400-2600
  • ESC: YGE 90LV
  • Governor: YGE
  • BEC: Internal YGE 5.7v
  • RX Pack: n/a
  • Cyclic Servos: MKS DS9660A+
  • Tail Servo: MKS DS760
  • LiPos: Gensace 4000mah 30C
  • Anything Else:
JR Forza 450 | Align Trex 550 V1 | Henseleit TDF | Henseleit TDSF
Varelco is offline        Reply With Quote Quick reply to this message
Old 03-24-2013, 08:03 AM   #55 (permalink)
Flight Style: 3D
FBL System: Fullsize Silverline VBAR with 5.3 Pro
Pinion: 19T
Target Headspeed(s): 2800 at 66% throttle
ESC: Kontronik Jive 100 LV (v.13) (no cooling fins needed)
Governor: Jive mode 4 (endpoints not adjusted)
BEC: Kontronik integrated BEC
Tail Servo: MKS HBL 980
Main Blades: stock
Tail Blades: KBDD Extreme 84.5mm
LiPos: Revolectrix 60C-5000-6S
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot
jmackey is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 11:19 AM   #56 (permalink)
Default Red & White
  • Flight Style: Hard 3D
  • FBL System: Mini V-Bar
  • Pinion: 17T
  • Target Headspeed(s):2750-2800
  • ESC: Kontronik 100LV
  • Governor: Jive Mode 4
  • BEC: Kontronik Internal
  • RX Pack: N/A
  • Cyclic Servos: Futaba BLS153
  • Tail Servo: Jr MP82G
  • LiPos: Thunder Power 4400 65c (700g)
  • Anything Else: AUW 2004g (w/ Battery Tray) & RTF 2704g
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 04-01-2013, 08:01 PM   #57 (permalink)
Default What's your Goblin 500 Setup Thread
This is what I have
Talon
Beast
3717 servos
6080G tail servo
KDE 1450
16 tooth pulley
Thunder Power g8 45c 4400
"Just Fly It"
AMA 819728
Lzfalcon is offline        Reply With Quote Quick reply to this message
Old 04-07-2013, 08:12 PM   #58 (permalink)
well im starting the build tomorrow
yellow and black
quantam 4120-1200 19t pully
jive 100lv endpoints uncalibrated v13
bec jive @6v
bls 153 cyclic
bls 251 tail
mini vbar 5.3 pro
6303 sbus
mains stock sab 500mm
tails stock sab 80mm
thunderpower G8 70c 4400
target headspeed 2600-2750
flight style moderate to hard 3d
futaba fanboy
should be a blast,my first gobblin
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 04-09-2013, 12:02 PM   #59 (permalink)
Goblin Red & White
Flight Style: Smooth 3D / Speed
Motor: Quantum 4120 1200KV
Pinion: 16T
Target Headspeed(s): 2300/2400/2500
ESC: YGE 90HV
Governor: YGE Gov store
BEC: Gryphon GSR-5045
Tail Servo: Gaui GS-502
LiPos: Gen Ace 4000Mah 25C
SYNERGY 516
Mikado LOGO 550
Mikado LOGO 700
SMJT is offline        Reply With Quote Quick reply to this message
Old 04-09-2013, 01:03 PM   #60 (permalink)
Motor: Quantum 4120-1200 (Goblin Edition)
Pinion: 18T or 19T
Target Headspeeds: 2200-2500-2700
ESC: YGE 100LVVB
BEC: Gryphon Polaris
Governor: MSH Brain
Rpm sensor: Hobbywing or "vbar signal"
Sweguy is offline        Reply With Quote Quick reply to this message
