Old 10-23-2014, 04:10 PM   #21 (permalink)
Originally Posted by HighFreq View Post
All people that have probs with oneways are using 13T and 14T or having probs even on 15T with bigger oneway?
Corrado
I had a 16t crack and bought 3 replacements, the 1st replacement couldn't hold on and i have had 8-10 packs on the second.
When the updated pinions are out I will install it and stop worrying if this is the flight it will fail.
Team Lynx Heli Field Rep
XL Protos 380
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 10-23-2014, 04:27 PM   #22 (permalink)
Are we talking about the Protos or the Mini?
Corrado
www.msheli.com
HighFreq is offline        Reply With Quote Quick reply to this message
Old 10-23-2014, 04:29 PM   #23 (permalink)
The Mini, my 500 is out of commission for the winter while I overhaul it.
XL Protos 380
Old 10-23-2014, 10:43 PM   #24 (permalink)
Wow, that is pretty impressive wear you have.
I'll check the shafts we have in our warehouse. Those are hardened and shouldn't wear to that point.
400 flights are not few flights but still shouldn't wear to that point.
Here's mine in less than 400 flights. It definitely wore out faster than the short shaft adapter which still wore out faster than the 5/32" rod stock I used to custom-make my own short adapter insert.
I've heard a couple cases with 15T slipping but that's because of oil contamination.The 6mm shaft/OWB it runs are much more robust (450-size heli mainshaft OWB). I think the problem with 4mm shaft/OWBs (250-size heli mainshaft OWB) is that it's hard to synchronize the 2 OWBs to even out the load. The top one always grabs 1st and takes the most load.
Old 10-24-2014, 12:14 PM   #25 (permalink)
Hmm both bearings wore evenly on mine but maybe the top did go first and the bottom one was doing all the work until it wore out.
I've been talking the protos 500 Mines stretched with 13 tooth pinion, 95% of my flights were at 2450rpms 12.5* pitch .
Prôtos Max v2 ~ brain,castle,MSh,Bk
Goblin 700c ~ Ferarri carbon,Ikon,Castle,Quantum,Torq
Goblin 500 ~ Bx,castle,Scorpion,Kst
MSH USA team pilot
01ws666 is offline        Reply With Quote Quick reply to this message
Old 10-24-2014, 01:17 PM   #26 (permalink)
If I kept flying that long shaft it'd wear out the bottom OWB location as well.
That shaft has seen some 14T and 13T about 60/40 of its life. I fly my stretch with 470mm blades at 2250-2400 with 11.5-12* pitch.
