Old 03-11-2010, 07:05 PM   #41 (permalink)
I used a $6 2.5mm ID / 4mm OD 24" CF tube from LHS. I cut it down to about 14 5/16". In retrospect, 14 1/2" would have been the right length.
I cut 2" off each end of the stock pushrod and taped off 3/4" with masking tape. I sanded the exposed metal and washed it in acetone. I then applied epoxy to the pushrod ends and slid them in up to the tape.
It came out to about 7 grams with ball links.
edit: Dubro 2mm threaded couplers have an OD of 1/8".
trex 450: 350mm, 4s 2200, 450m 12T, hs5065mg, beastx+s9257, ice 50, 3000rpm, R6203SBE
logo 500se: 623mm, 12s 3000, xera 4025 560 15T, ds20-fmd, beastx+s9254, ice 80hv, 2000rpm, R6203SB
member ACM, AMA, AOPA
xatled99 is offline        Reply With Quote Quick reply to this message
Old 04-05-2010, 01:41 PM   #42 (permalink)
Nice job, man...thanks for the contribution!
Push the envelope...Watch it bend
T-Rex 600 E$P
T-Rex 500 E$P
MD500E/T-Rex450$E
DX-7
toolguy420 is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 02:25 AM   #43 (permalink)
Just curious.........what camera did you use to take this pic, and what lens?
T-Rex 450 SE V1, HS65MG, 9650, 325 CF, AR6100, 2200 FlightMax, 430XL/BL35X, GY401 ...SOLD
T-Rex 500ESP...SOLD
DX7...Still for sale
M.A.A.C. 78596 www.helicalgary.com
Ex President - Calgary RC Heli Club
helijack is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 07:20 AM   #44 (permalink)
Canon PowerShot SD780.
Old 08-04-2010, 02:55 AM   #45 (permalink)
Originally Posted by ken22golf View Post
I almost bought some CF rod from HK to make pushrods. Problem is HK ships them in a large box which adds 370grams to the shipping charge. $5 in CF costs $27 after shipping When I was ready to check out I was like and
Check out BPHOBBIES.com, they have an assortment of hollow / solid CF cheap. The CF I ordered along with a couple other parts only cost $7 to ship! As an extra bonus ill get it in 4-5 days instead of 17-20
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote Quick reply to this message
Old 08-04-2010, 06:56 AM   #46 (permalink)
Hey SNJ, dunno if you've been asked yet on the thread but would you be willing to hook a brotha up with a couple of those (ofcourse paid for). Lemme know, I'd buy a few off you.
T-Rex 700LE x2 T-Rex 600LE x2T-Rex 600ESP T-Rex 500ESP x2 ElyQ Vision 50 - OS55, B320
Flown via DX7
D Grade is offline        Reply With Quote Quick reply to this message
Old 08-04-2010, 09:05 PM   #47 (permalink)
PM sent.
snjbird is offline        Reply With Quote Quick reply to this message
Old 08-05-2010, 02:11 AM   #48 (permalink)
Thanks again SNJ! Ill get the measurements to you in the next week!
Flown via DX7
Old 08-22-2010, 08:44 AM   #49 (permalink)
I ordered some carbon tube Thick Walled 3mm OD, 2mm ID. I figure can slide 2mm rod down it and attach align links on the ends. (It is lighter than sliding the metal pushrod down it, which is a smidge under 2mm, btw). I also bought some 3mm rod to try that. Got it at bphobbies, local and cheap.
I used 2mm rod on one of my 450s and it works great. At a length of 15' or so tho for a 500, it'll bend similar to the metal pauhrod, thus looking to try 3mm tube and if that isnt stiff enough. I have the beam pushrod on another 450, but it strikes me as a bit weaker than the 2mm rod set up, but it works fine.
"The Great Santini"
Futaba 8FHGS; Logo 600 3D FBL:, 4035-500, 12T, 12S, Jive80+HV, Futaba 6203SB, Fullsize V-Bar 5.1pro (Vergnugenstabi), BLS 451+251; Align 500esp: TracX FBL, 14T, ICE75, Beastx v3
Santini is offline        Reply With Quote Quick reply to this message
Old 08-24-2010, 08:12 PM   #50 (permalink)
Default Ultimate best pushrod for 500
I ordered 3mm carbon rod from BP hobbies (3ft for $2.30). Cut the rod to the length of the metal pushrod. Take a hobby file and sand the end of the rod to make it narrower - I created a little shoulder. Take a small drill bit and increase the diameter of a standard align link. Coat the end of the rod in epoxy and fit the link on it. Make sure when you fit the second link it is angled properly for the servo horn and tail. This is very very stiff and will not bend.
Weight of std metal pushrod + 2 guides = 11.75 grams.
Weight of Santini's carbon replacement = 4.88 grams
Weight savings = 6.87 grams.
"The Great Santini"
Old 08-24-2010, 08:20 PM   #51 (permalink)
yup that what it's all about!
Old 08-25-2010, 01:29 PM   #52 (permalink)
I tried 2mm ID, and the original metal rod wouldn't fit into it, the 2.5mm ID was a little loose, but got the job done damn good.
JackdaWack is offline        Reply With Quote Quick reply to this message
Old 08-25-2010, 11:06 PM   #53 (permalink)
Great ideaa snjbird! I went with the 1st design except I used full size linkage rods instead of cutting one in 1/2 just to get a little more bite still lighter than stock not sure how much I dont have a scale. I went with blue heat shrink to accent my color sceme.
Name:	HK 500 GT 040.jpg
ID:	176322   Click image for larger version
Name:	HK 500 GT 042.jpg
rotorfan is offline        Reply With Quote Quick reply to this message
Old 08-25-2010, 11:17 PM   #54 (permalink)
I also bought 3mm tube (2mm ID) and I could indeed stuff the metal rod thru it w a little effort but I thought it was heavy, so I nixed that. Then I looked at using tube w ends, but I felt that tube was still pretty fragile/bendy, even the thick walled tube I felt needed more stiffness. That is when I chose 3mm rod as described which is stiff as hell versus tube.
"The Great Santini"
Old 08-25-2010, 11:44 PM   #55 (permalink)
Here you go Brotato's, a howto I did on another forum.
The CF arrived today, so here's a quick how-to of how I made them.
This rod has an OD of 3mm and an ID of 1.2mm. I got the 1.2mm over the 1.5mm that is also available as I liked the idea of the added wall thickness and the threaded rods are;
x
I then measured the rod and cut it a bit overlength by rolling it with a sharp knife, I then trimmed and dressed the ends with the dremel.
I had a drill bit handy, but was lucky in that when I inserted the threaded rod, it bit into the CF and cut it's own thread.
It would probably be OK as is, but I popped some CA in the ends and screwed the threads in.
This is all glued in and cut to length.
Idle hands and all that....
I then cut some heatshrink just for aesthetics.
Here it is installed, this thing is extremely rigid.
Weight savings.
Those guys who wanted one, I'll get them in the post this week.
Inverse is offline        Reply With Quote Quick reply to this message
Old 08-26-2010, 06:07 AM   #56 (permalink)
thats a 250.
"The Great Santini"
Old 08-26-2010, 08:01 AM   #57 (permalink)
I have fabricated them for all my E helis 250-600, on the 600 I added a guild, just to be safe... all the others are free floating! I stick with the wire and guides on my nitros, too many unpredictable harmonics to be a test dummy there!
Old 08-26-2010, 12:41 PM   #58 (permalink)
Originally Posted by fogger View Post
Either way you will want to come up with some type of support for the tail push rod. I tried this on my 600, the second version with a carbon rod ca'd over the stock pushrod. Watch my backwards on-board video on you tube and you will see the crazy oscillations the rod went through. Now I later found that I had a couple bad bearings in the grips which probably helped produce the vibes, but anyway watch it and you will see what I mean...
http://www.youtube.com/watch?v=AgZIJ3_8WiI
-Fog
That's a fairly conclusive experiment!
I've not had any trouble with the standard setup on either my 450SEv2 or 500ESP, but I've made a point of keeping the guides well lubed. That said, the guides do wear a bit and the guide holes have certainly enlarged. Does anybody make CNC guides with decent guide bushings?
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote Quick reply to this message
Old 09-12-2010, 09:46 AM   #59 (permalink)
Works perfectly. 3mm solid rod is uber strong - no flex, substantial weight reduction versus stock (this is the lightest home-brewed solution I've seen, 58% weight reduction and IMO anything that lightens the tail on a 500esp is a good thing...), no guides to bind, tail response is perfect, looks good, very simple to make (3mm solid rod, 2 links, epoxy, hobby knife, file or sand paper + few minutes), parts cost <$1.
(I did the same thing awhile back on two 450s w 2mm solid rod which works perfectly for that boom length. Here you need 3mm for this (500) length of boom to eliminate any flex. Hollow has too much flex, IMO, even using the thick-walled hollow.).
Name:	IMG_4715 servo Santini.jpg
ID:	179617   Click image for larger version
Name:	IMG_4721 tail side Santini.jpg
ID:	179618   Click image for larger version
Name:	IMG_4722 control rod santini.jpg
"The Great Santini"
Old 01-23-2011, 06:12 PM   #60 (permalink)
Would this work for the 500? http://www.heliproz.com/prodinfo.asp?number=125860
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote Quick reply to this message
