Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
05-15-2012, 08:24 AM | #1 (permalink) |
Can the data log show you if the gov is hitting 100%
Hi Guys
As above really. Can it show you weather the gov is running out of headroom either under heavy disc loading or through out the flight as voltage drops (i know RMP decay will show the latter) Cheer
6hv (fb) 7hv DX8 |
05-15-2012, 12:28 PM | #2 (permalink) |
=] one way would be to map stick inputs to headspeeds, mostly we will know the correct pinions for our heli's and the desired RPM's.
05-15-2012, 02:40 PM | #3 (permalink) |
I don't think so. For headroom analysis, you need to see your ESC's PWM output. When the PWM hits 100%, you've run out of headroom.
Jive ESCs have the JLog2. Not sure what other ESCs have for monitoring PWM. |
05-15-2012, 07:27 PM | #4 (permalink) |
If you are using the SK governor, then a log of outgoing throttle would allow you to tell, significant time spent at 100% signal to esc would mean the governor was having trouble. It should be possible to change the software on the SK to log that sor of information as well.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
05-15-2012, 08:25 PM | #5 (permalink) | |
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
05-16-2012, 05:03 PM | #6 (permalink) |
Thanks for clarifying guys! I wonder if this would be a possible update?
Sent from my ifad
6hv (fb) 7hv DX8 |
05-16-2012, 06:31 PM | #7 (permalink) |
Email SK with the suggestion, im sure they dont have time to read every thread on here...
