Old 05-14-2012, 11:18 AM   #201 (permalink)
Originally Posted by krauley View Post
sorry about the bad picture there, but thanks for the reply. the link from the grip does indeed connection to an A ball on the swash.
as for my esp to DFC conversion, my swash only has the B balls on it, do i need change these out for the shorter A ball or will i be ok with the current setup?
appreciate it
The grips that attach to the swash from the dfc head need to attach to shorter size balls as discussed.
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 11:32 AM   #202 (permalink)
got it thank you sir
UH-60 EXI 500 DFC/3GX v5.0 ICE 75 Bec Pro w/4 blade main & tail rotors
Align trex 500DFC Pro w/AR7210bx Oxy 2 FE micro Ikon2 Talon 25 BA 8-1 servos
Oxy 3 Tareq Edition AR7210bx Edge lite 50 Kst 215's
PL6 w/Bump Controller-24v PS DX8 gen2
krauley is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 11:48 AM   #203 (permalink)
I bought Trueblood dampeners from the get go. Not sure if that's a good thing or not but it definitely has no play/wobble. Not that i could put them to the test anyways since i'm not attempting 3d yet...lol.
Also on a different subject i read that a lot had problems with getting "Blue" light on step "J" the 6 degree pitch setup part on the AR7200BX. I did too even with the shorter swash balls (was close but blue didn't light up till about 6.3) so i decided to go through my setup again. By setting my servo links measuring from center hole to center hole i had around 45mm in length (manual for the esp called for around 50mm) and using the 13.5mm holes on the servo arms. The DFC head links were pretty much bottomed out on both adjustable parts with both "A's" facing out. Then adjusted the servo's which all of them are pretty much centered till i achieved around zero pitch. Anything that was off i did not make adjustments on the links but through the controller on step "G" by moving the servo arms instead (minor tweaks like using a little trim). Finally after getting Zero pitch pretty much all around i redid the "J" setup and blue showed up after 5.5 so easily made 6 degree pitch with blue. Right on the money. Hope this might help a few but i'm sure each persons setup is different.
Did you make sure you swash was level when doing your adjustment in bold. Also, I tried moving to the 13.5mm holes on the servo horn and it bound agains the servo in step "L". You didn't have any of these problems?
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 04:32 PM   #204 (permalink)
Yes perfectly level swash. My adjustments are made to correct around .2 degrees of pitch with a rc logger digital pitch gauge (this thing is a godsend). Does it matter to be that slightly off...probably not but i'm anal like that...lol. If i'm off the adjustments are usually made on the alieron or pitch servo. Easier for me then giving the servo rod a slight twist. This way its hands free on heli and i can see the difference in real time versus wrestling the heli. On step "L" need to give left or right stick on the throttle till it doesn't bind. Each color represents different levels of movement. I couldn't get blue on that and it didn't stop binding fully till it was pink i think.
AMA #1039539
Old 05-14-2012, 09:09 PM   #205 (permalink)
I want to say it would be more important to have a blue light at "L" than it would be to have a blue light at "J". The manual specifically states that if you don't have a blue light at "L" to mechanically adjust the helicopter till you do. Then you ould hav to start over from "G" again.
MSH, Cyclone
Old 05-14-2012, 09:25 PM   #206 (permalink)
Says if the led is at purple or off to readjust.
So you made me go back and adjust...increased my 11+/- pitch to 12+/- and now have blue with no binding...lol. Quick and easy. Went through and redid those 3 steps...all blue and good to go.
AMA #1039539
Old 05-15-2012, 01:11 AM   #207 (permalink)
Mistake number one never order stuff from overseas! Still waiting on my DFC head I got of fleabay. guess I gotta fly with the regular fbl head till it gets here.
Slow & Steady!
nmdesertracer is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 02:44 AM   #208 (permalink)
Yea that was a bad idea. There are sellers on there selling it that are in the U.S. I would say that is more your fault that fleabay.
MSH, Cyclone
Old 05-15-2012, 07:25 AM   #209 (permalink)
Yeah I know rub it in!
Slow & Steady!
Old 05-15-2012, 05:32 PM   #210 (permalink)
And you saved how much money? Was that amount worth this much pain?
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 08:22 PM   #211 (permalink)
Originally Posted by Russell Skinner View Post
What blades are people flying with the DFC head?
Curtis Youngblood 430 Flybarless! Awesome!
TREX 500 DFC PRO , TREX 550E FBL V2, TREX 700E DFC, AR7200BX in all three, DX8
AMA #969521
billmjam is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 09:08 PM   #212 (permalink)
This is how I feel ----> But I did get a email today hopefully be in by friday.
Slow & Steady!
Old 05-18-2012, 12:51 AM   #213 (permalink)
In regards to the dampners... I don't remember the diff on my 500, BUT, I just built the 450 DFC head and the damps are a lot harder. I am talking about PVC like feeling vs. rubber like feeling.n
Goblin 700, Goblin 380, Gaui NX7, T-Rex 700N, T-Rex 450
iKon, because I am connected to my heli. Are you connected to yours?
RCHN #15
PauloG is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 10:35 AM   #214 (permalink)
Soft for sport flying and hard for 3du is recommended. Can never go wrong with the harder dampeners for either type of flying.
AMA #1039539
Old 05-18-2012, 11:02 AM   #215 (permalink)
On my 450 the stock DFC dampers were un-flyable with my setup. I run a lower headspeed, and it was wobbling just doing a stationary piro... Don't know about the 500, but as soon as cash flow allows for it, I plan to upgrade my 500
With the 3G setup I have been running for a year on my 500, the gray 70* dampers work the best at my headspeed of 2600? I was a fan of the KBDD on my 500 with a FB, but they were too stiff for my setup with the VBar and the 3G head...
snjbird is offline        Reply With Quote Quick reply to this message
Old 05-20-2012, 09:50 AM   #216 (permalink)
first step, move the balls in on all the servo arms, about 15 maybe 13mm will give you the right gain for the Ar7200Bx
Go through the steps in the manual, its all very simple
One tip, create a new model, 90 degree single servo swash, 100% endpoints, 0 sub trim, 0 trim. All the settings for these are done by the Bx. The only thing you end up setting in the radio are throttle and pitch curves
Kinda late in the game but i had followed this but on the Bx controller it should be set to 120 degree right not 90? I did set my remote to 90 and the Bx to 90 so i'm realizing it might be wrong...lol. It's flown fine though.
AMA #1039539
Old 05-20-2012, 11:04 AM   #217 (permalink)
Radio swash mix should be set to 90 deg 1 servo, BUT the BeastX should be set to whatever your swash physically is, ie 120 deg 3 servo on the TREx 500. Strange that you got through setup and that it is flying with a 90 deg setting in the BeastX.
VControl
Old hand at Planks
Peter
Old 05-20-2012, 11:10 AM   #218 (permalink)
Yeah...went thru all the setup menus again after changing it to 120 degree and all is well. It flew fine so i couldn't tell you why it didnt end in disaster. Haven't flown it yet since the change but i'm a flybarless newb and still not sure how it's suppose to feel in flight. It was touchy though.
AMA #1039539
Old 05-20-2012, 06:53 PM   #219 (permalink)
As Vinger said, 90 degree single servo in the radio, the 120degree CCPM in the beasts
RTFM
Dave
Old 05-21-2012, 12:16 PM   #220 (permalink)
RTFM
RTFM = Read The F*ing Manual ????
MSH, Cyclone
