mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
03-21-2012, 11:53 AM | #1 (permalink) |
Soldering Technique
Can someone explain in detail the best method (step by step) to solder the brushless signal wire to the tiny resistor on the 3in1? I've watched some videos but don't know how to apply it to something so tiny without burning it.
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo |
03-21-2012, 11:56 AM | #2 (permalink) |
I just tin the yellow wire, place it on the resistor then just touch for a second with the soldering iron, then hold the wire in place until everything is in place. Never had a joint fail.
Blade 130X Xtreme-Production
Blade mCP X (Bl) Blade Nano CP X Prôtos 700 |
03-21-2012, 12:00 PM | #3 (permalink) |
At what temp?
03-21-2012, 12:01 PM | #4 (permalink) |
I did the same thing. Also use a very bright light (and magnifine glass) to help see the tiny resistor.
03-21-2012, 12:08 PM | #5 (permalink) |
I think it's around 700. At least that's what my 40 watt iron claims to put out.
03-21-2012, 12:10 PM | #6 (permalink) |
Using a pair of tweezers to hold the wire (or any of these small parts) gives you fine control over placement on these tiny structures. I highly recommend getting a set of needle and curved tweezers to work on this bird.
mCPxBL // HP05s 9t // XP12a (BLheli 5.0) // HP03t 8800/XP3a 5.0 - Plantraco // Hyperion 550's Frankenstein 450 (align/exi/hk) |
03-21-2012, 12:23 PM | #7 (permalink) |
Thank guys! Great tips!
I just ordered one of these: http://www.amazon.com/X-TRONIC-MODEL...350269&sr=8-11 after suggestions from another thread. I have the Walkera 10A ESC and my Spin 16.3k should be here soon. Looking forward to having the brushless ESC directly on the 3in1. This is to setup my first Non PNP brushless kits. I just want to be super careful with my v1 board! I'm not the best at soldering. (lack of experience) Thanks for the info
03-21-2012, 12:25 PM | #8 (permalink) |
My soldering starion is set to 550 degrees. I use a piece of scotch tape to hold the wire into position and touch the tip to the spot for just a second. With a magnifying lamp you can see when the solder flows. I just got done doing one a bit a go.
Team Newb pilot All my helis and quads were lost in a tragic boating accident. |
03-21-2012, 02:31 PM | #9 (permalink) |
What type of glue are you guys using for strain relief?
I've switched over to soldering paste instead of traditional solder wire. It's made soldering sooooo much easier on this tiny thing. |
03-21-2012, 02:36 PM | #10 (permalink) |
I use 5min epoxy and am happy with that.
03-21-2012, 02:44 PM | #11 (permalink) |
I just use hot glue.
03-21-2012, 03:04 PM | #12 (permalink) |
Parma servo tape.
03-21-2012, 03:12 PM | #13 (permalink) |
Kapton tape here
03-21-2012, 03:34 PM | #14 (permalink) |
Scotch tape to hold the wire. That is great idea. I am going to try that.
I have been using those helping hands but not very effective on wires. |
03-21-2012, 04:06 PM | #15 (permalink) |
I have a few.
03-21-2012, 04:53 PM | #16 (permalink) | |
Just some thing to consider. You can also get this SMC rework station for
a little bit more: Cheapest one is $79 with all good reviews. (The only minor complain is due to the dude did not read the Manuel). http://www.amazon.com/REWORK-SOLDERI.../dp/B004ZB9D4O It come with digital control iron as well. SMC rework station can blow hot air, it is a lot more useful on those SMC component than iron. I just get the X-TRONIC rework station myself. Now the Weller WESD51 seems a bit redundant now. Quote:
03-21-2012, 06:45 PM | #17 (permalink) | |
03-21-2012, 06:47 PM | #18 (permalink) |
I agree with you. If you are getting a $70 solder station, you might just
as well get the smc rework stations for a about $12 more. |
03-21-2012, 07:06 PM | #19 (permalink) |
Man that thing is sweet!
Would love a combo Iron and Hot air gun. Unfortunately I already own a good iron, so it would be redundant. Maybe I need to hint a future B-day present to the wife...Along with the 300X .
MSH PRÔTOS Rave Ballistic 635 |
