Hitec Gyro/Servos Hitec Gyro and Servo Support |
10-26-2008, 04:50 PM | #1 (permalink) |
Gyro issues with Hitec head servos
Hi Guys,
I have recently set up a 600 Nitro Pro kit. I used a 401/9254 combo for the tail and Hitec 7965MG servo's for the head. For some reason if the hitec servos are loaded or buzzing the tail servo will vibrate. Doesn't seem to be an issue in flight. (almost 2 gallons through it so far). It does concern me a bit that the gyro is picking up the noise. If I grab the blades and carefully adjust the pitch so that the head servos quit buzzing the tail servo also settles down. I was wondering if anyone else noticed this or had a fix. Also I am running a spektrum DX7 / AR7000 radio. (soon to be a Futaba fasst system and hoping that the Futaba doesn't have the same issue.) Later
Conway V Scene From Above Photography www.scenefromabove.ca Gaui X7 Cameraship |
10-26-2008, 04:59 PM | #2 (permalink) |
Can't help you on the Servo problem but i did have a hitec 635HB on throttle that would lock up full throttle because of the Nirto vibrations. try full throttle on maiden flight with a full tank of fuel. Thankfully i was running very rich. Going to a Futuba 9254 as soon as it get back from Futuba.
Cheers, Glenn Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's |
10-26-2008, 05:16 PM | #3 (permalink) | |
10-26-2008, 05:41 PM | #4 (permalink) |
Is your 401 mounted on the gyro tray above the front servos? i had this problem but really bad with the align servos - tried the gyro isolation plates but made no difference.
had to move the gyro back onto the boom block.
Sponsored by - Team Align UK- CSM - MKS Servo's UK - Kontronik Drives T-rex 700E v2 - 700E DFC |
10-26-2008, 05:57 PM | #5 (permalink) | |
I do have it mounted right up front. I don't really want to move it back because of the amount of exhaust residue in that area so I will try the plate first. Also am going to check where I ran my wires. I think that I ran the Gyro and servo wires together. This will give me something to do at work tomorrow. LOL Thanks Again.
10-26-2008, 06:24 PM | #6 (permalink) | |
