Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 12-08-2012, 11:16 PM   #1 (permalink)
Default A stretched nx4
A x5 tail boom and tt cut one inch longer than a nx4s and use a x50 Tail Control Rod Joint.You got to grind the tail rod to length.It comes out to be the same boom length as my logo400se and i run 473mm blades on it.
ID:	372388   Click image for larger version
ID:	372390   Click image for larger version
ID:	372392   Click image for larger version
ID:	372394   Click image for larger version
bobbyra is offline        Reply With Quote Quick reply to this message
Old 12-11-2012, 06:31 PM   #2 (permalink)
How's the weight balance on that?
You could get a Hurricane 550 rudder control rod and cut it down instead of splicing.
I was looking into it as well. alot of the Hurricane stuff is interchangeable as well. It was the base for the "X" series. I still have a hurricane and parts, been comparing
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is online now        Reply With Quote Quick reply to this message
Old 12-12-2012, 02:42 AM   #3 (permalink)
while i like teh idea of larger blades, how does it do CG wise ?
My stock is just about right with a 2200 2S Lipo on teh bottom tray and i don`t think i could get anything heavier there..
meatbomber is offline        Reply With Quote Quick reply to this message
Old 12-12-2012, 12:22 PM   #4 (permalink)
I had to use a 2600mah duralite to get the cg right.I went to fly it this weekend but my throttle servo took a dump got a new one so i hope it will be flying Sunday.
Old 12-26-2012, 01:06 PM   #5 (permalink)
Talking
I got to fly the nx4 with 473 blades.It flys great and it autos a lot better now.
Old 12-28-2012, 02:25 PM   #6 (permalink)
I can prove - the stretched version is running really well.
im4711 is offline        Reply With Quote Quick reply to this message
Old 02-21-2013, 03:17 PM   #7 (permalink)
Here my flight with my stretched nx4 with x5 boom , tail control carbon , tail blade 72.5 kbdd and edge 473 mm
2700 rotor head speed
[ame]http://youtu.be/4xA23utNvAA[/ame]
I prefere this setup !!! The nx4 is fly great
philou3110 is offline        Reply With Quote Quick reply to this message
Old 02-21-2013, 05:59 PM   #8 (permalink)
Nice flight.
Old 02-21-2013, 09:58 PM   #9 (permalink)
agreed nice flight, looks to be an easy stretch too
Phil did you cut the x5 boom down too
joallen001 is offline        Reply With Quote Quick reply to this message
Old 02-21-2013, 10:52 PM   #10 (permalink)
Nice flight man the nx4 doesnt looks so stumpy with the extended boom ..
what is the flight difference other than more floaty and better autos
i dont like the way that engine bogs down i think il stay with my 435 mm blades
also listening to the sound of that thing .. it sounds like its going to EXPLODE ! lol
Gaza-Davies is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 04:22 PM   #11 (permalink)
Awesome flight!!! Great cameraman!
tauseef
www.cuttingedgecnc.com
tauscnc is offline        Reply With Quote Quick reply to this message
Old 02-24-2013, 03:30 PM   #12 (permalink)
Thanks , i don't have cut the x5 boom
The motor was to lean on this flight
Old 11-23-2013, 10:04 AM   #13 (permalink)
@Bobbyra - I recently put the edge 473mm blades on my NX4 - no need to stretch when using stock tail blades..
Flies nicer and definitly autos better - lol
I's say adding longer blades ( 460-473mm ) on the NX4 is almost a "must" do....
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 10:53 PM   #14 (permalink)
It'll cruise around better, but you'll be able to bog it easier too.
Team Old Mate - He's a good bloke
timmytron is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 07:18 PM   #15 (permalink)
I have edge 473 and sab 80mm tails in the x4ii without any issues at all. The NX4 I've just got will be the same, stock boom.
As soon as the edge have dried up completely I'll go 450 halos.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 07:38 PM   #16 (permalink)
Is the stretch necessary to run 465's?
I know on the X4II you can run them without modifications ... and they are almost the same helicopter. Anyone know?
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 12:00 AM   #17 (permalink)
No need to stretch at all for 465 ...
BTW it should be nice if Spinblades was including some washers in their pricey blades !.... They are needed and they are not provided ... kinda lame IMO ....
Flydynamics is online now        Reply With Quote Quick reply to this message
Old 03-22-2014, 04:05 AM   #18 (permalink)
Are you running Stock gear ratio on this flight??
cilipadi84 is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 09:20 AM   #19 (permalink)
They are included, but everyone misses them ... they are white and taped to the inside of the lid. I even missed them as well before Matt and JC pointed it out.
Check inside the lid of the box they came in ... check VERY carefully as they are incredibly easy to miss.
Old 03-22-2014, 01:34 PM   #20 (permalink)
I don't have mine anymore ... But I remember checking the package carefully .. never found them. In the X4 II forum, Matt Nasca is saying that spinblades 465 are NOT delivered with shims ... German made yeah !!!!!.... give me a pair of shim to be able to use your blades guys !.........
Glad you had some spare to give me Jeff ....
Flying sunday Jeff ... Want to see the NX4 in flight ... might be cold tho ...
