Go Back   HeliFreak > R/C Electronics Support > Robird G31
Robird G31 RobirdUSA Factory Support Forum
Like Tree4Likes
Old 01-04-2013, 09:25 AM   #261 (permalink)
Still considering the G31 over the ZYX-S...but still hoping someone can answer my question about the documented "bail-out" capabillity. I am very curious if that is a mis-statement or add-on or future capability.
cipioh is offline        Reply With Quote Quick reply to this message
Old 01-04-2013, 10:10 AM   #262 (permalink)
CIPIOH -
This basically means that the governor can be configured to have a bail out like some ESCs have. It is time based so that after about 8 seconds following throttle cut the governor will spin up faster for bail out. It reverts to normal start up once this time is exceeded.
I hope this helps you out.
Scott
RobirdUSA
SDedic214 is offline        Reply With Quote Quick reply to this message
Old 01-04-2013, 10:35 AM   #263 (permalink)
In other words, it does NOT have an auto-level or self-stabilizing feature.
Sent from my HTCEVOV4G using Tapatalk 2
Align 550e, Gaui X3
krefi is offline        Reply With Quote Quick reply to this message
Old 01-04-2013, 11:22 AM   #264 (permalink)
Thanks SDedic214, krefi. Much appreciated.
Old 01-05-2013, 04:02 PM   #265 (permalink)
You can now add me to the list of Robird owners...just placed my order with RobirdUSA. It's time to make it happen.
Old 01-05-2013, 07:02 PM   #266 (permalink)
You'll love it. Just take your time during setup and you should be problem free.
sent from my phone using circus midgets
Compass 7HV Gaui X5 Formula HD Cell 500
LawnDartHeli is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 10:44 PM   #267 (permalink)
+1 you won't be dissapointed. Plus you have lots of help here.
Atom500(FBL)., Gaui x4II (FBL) ;Trex450 sport (FBL). All with Ikon fbl gyro. AMA#1019423.
Tony .
tony521 is offline        Reply With Quote Quick reply to this message
Old 01-06-2013, 12:31 PM   #268 (permalink)
have 6 flights with my 250 dfc head and robird G31
Just amazing. I need to adjust the cylic for having more piro feeling
Align has it all !!!
englecam is offline        Reply With Quote Quick reply to this message
Old 01-06-2013, 02:06 PM   #269 (permalink)
Changed this to main thread.
Trex 500E, Tarot 450 Pro V2 on 6S with Robird + MKS92A and MKS95i, Trex 250SE, mCPX x 2, Phoenix, Dx8 (sold: Dx6i, HoneyBee FP V2, mSR)
toonttm is offline        Reply With Quote Quick reply to this message
Old 01-11-2013, 05:44 AM   #270 (permalink)
I got mine from HK
The package seemed different from what I have seen on youtube - it felt smaller and . I got 2 x SRx cables and a Hobbywing phase sensor included , but I did not get a screwdriver
ALIGN 450L
Polaris BEC | Nano-Tech 6S1P 1300mah | 360mm/68mm Blades | Robird G31 | TGY 306-G | KST 515MG | TGY K-Force 40A | NTM Rotor Drive 1700Kv
raja_mastana is offline        Reply With Quote Quick reply to this message
Old 01-11-2013, 03:29 PM   #271 (permalink)
Originally Posted by raja_mastana View Post
I got mine from HK
Robird released the newer G31 recently with new plastic packaging. Customers are getting 2 SRx1 adaptors and a phase sensor for the Governor functionality feature of the G31. They aren't supplying screwdrivers in the kits though so that's maybe something that HK had on the set as they were filming.
Old 01-11-2013, 09:09 PM   #272 (permalink)
Default Re: Robird G31 rollup
I just unboxed mine today, and posted the video. I apologize for the newbeeness...
https://www.helifreak.com/showthread.php?p=4617705
Build. Fly. Crash. Repeat.
Old 01-12-2013, 12:01 PM   #273 (permalink)
Thanks SDedic214
I am facing a small issue. Has anyone noticed a small interaction in the tail rotor during pitch pumps.
On the bench, when i give continuous +ve and -ve pitch, I notice the tail slider move a bit during the movement.
Has anyone else seen this?
ALIGN 450L
Old 01-12-2013, 12:03 PM   #274 (permalink)
Thanks SDedic214
That is tail pre-comp, completely normal. You can increase or decrease as needed.
Old 01-12-2013, 01:06 PM   #275 (permalink)
Hi LawnDartHeli, what is pre-comp?
ALIGN 450L
Old 01-12-2013, 01:12 PM   #276 (permalink)
It's compensation for pitch change for the rudder. It helps with tail hold on pitch pumps and hard collective maneuvers.
Old 01-12-2013, 02:57 PM   #277 (permalink)
Originally Posted by krefi View Post
Anybody else feel like the collective pitch is slow to respond, has high latency or something? I read on RCG that increasing the cyclic max rate might help - haven't had a chance to try it yet, but thought I'd check here for feedback as well. I'm using HS65's on a 450pro / dfc head, by the way.
YES I CAN'T GET IT TO FLY CORRECTLY!
I've been scratching my head and trying different things for over a MONTH now on this new 550 I built!
I've replaced several things including servos thinking that was the problem - it has an extremely slow collective, which creates almost a rubber-band like effect of slingshotting the heli up and down in the air as i'm trying to compensate! The person that sold me the Robird stated that he flew it multiple times and it was perfect on his 450, however it's just not working out correctly at all on my 550!
XL Power 520 / Spektrum DX6
PcChip is offline        Reply With Quote Quick reply to this message
Old 01-12-2013, 03:11 PM   #278 (permalink)
First I've heard of a problem like that. Can you connect heli to your pc and take some screen shots of all of your settings?
Old 01-12-2013, 04:22 PM   #279 (permalink)
I've been over all the settings a dozen times, the servos are all set up perfectly, the 8 degrees is perfect, the 12 degrees is perfect, swash compensates perfectly when tilted, and when I manage to get it into a hover the cyclic actually responds perfectly and crisply - very strange indeed! (I've also tried with analog, 125hz, and 333hz settings)
I thought the cheap servos I was using were just underpowered, but last night I spent $125 on some DS610's and an hour installing them, and absolutely no change! head is smooth, swash is smooth, it's just a mystery! ESC is YEP120hv governed by "GovStore", BEC is ccbecpro@6v
I'm thinking about just bypassing the Robird completely and going NoBar for a hover-test, to see if it's the FBL controller or something else, as I'm driving myself nuts with this
Old 01-12-2013, 04:46 PM   #280 (permalink)
What's your pitch curve in your Tx?
Does the collective move normal sitting in the bench?
I assume being a 550 size your using a full Rx, have you connected to it directly and seen if moves properly?
