Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 04-13-2015, 08:12 PM   #121 (permalink)
Default 317 heat
With my no contact gun its between 130 and 140 degrees F on a heat sink. Hope this helps.
SAB GOBLIN 630 COMPETITION / T-REX 800E PRO ,Castle ESC, Hacker, Scorpion, Thunder Power, Western Robotics, Bavarian Demon 3Sx, Microbeast, Futaba 18mz.
Fylers is offline        Reply With Quote Quick reply to this message
Old 04-14-2015, 06:14 AM   #122 (permalink)
Thanks...
still building;
KDS Chase 360 | Align Trex 600NSP | Align Trex 700E | Align Trex 700X
Sirolf is offline        Reply With Quote Quick reply to this message
Old 04-14-2015, 02:26 PM   #123 (permalink)
Originally Posted by Sirolf View Post
Thanks...
still building;
That is interesting, can't wait to see the end product.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 04-15-2015, 07:05 AM   #124 (permalink)
12S discharger/lipo heaterbox All-in-1
Old 04-30-2015, 06:27 PM   #125 (permalink)
Default Nice
Please let us see the end result.
Old 05-01-2015, 01:32 AM   #126 (permalink)
I will.. i like to share these things with fellow freakers.. right?
But for now still waiting on some parts to be CNC drilled..
Old 05-04-2015, 07:19 AM   #127 (permalink)
Don't want to appear like a right a*s* but remember to sleeve all soldered joints and make sure that each terminal cannot short to ground via the heatsink
Nigel.
A few little tiddlers ..SR, 300X, TRex 500E Pro with DFC, Trex 700DFC..... and quite a few Planks and Tanks !
nbells is offline        Reply With Quote Quick reply to this message
Old 05-04-2015, 07:53 AM   #128 (permalink)
All done after i took the photo's.. is all good now.
Thanks for noticing btw
Old 05-23-2015, 12:38 PM   #129 (permalink)
updates on my heater/discharger
Old 08-08-2015, 06:11 PM   #130 (permalink)
Well how does it work? Hopefully its finished.
Old 08-09-2015, 07:20 AM   #131 (permalink)
Yup... works excellent.
Look here for more info: https://www.helifreak.com/showthread.php?t=700049
Old 08-09-2015, 04:51 PM   #132 (permalink)
Extremely well done Sirolf , and I don't care what anybody says. I use mine all the time, this is a must have for electric flyers. Hands down!
Old 08-24-2021, 01:26 PM   #133 (permalink)
Default Discharger Option
Here is another option
https://www.rcgroups.com/forums/show...charger/page35
Post 520
Old 05-16-2022, 08:40 AM   #134 (permalink)
Originally Posted by Fylers View Post
Sorry, here is the correct page to 1st. post.
https://www.rcgroups.com/forums/show...iPo-discharger
Old 12-26-2022, 09:12 AM   #135 (permalink)
Many thanks to all that have contributed to this project.
This is what I came up with combining all our knowledge, The perfect discharger.
And perfectly self contained, no outside power needed to operate this unit(other than the batteries you wish to discharge).
The Cell-log 8 operates the trip circuit thru the relays from the power of the discharge batteries.
One 24v relay and one 18v relay with coils to handle 3s to 8s setups. Of course it's your choice according to your application.
Also the heat sink fan, and the case fan run from main pack thru National Semiconductors LM 317's per pic., using R1 and R2 to supply the correct fan voltages.
This unit is also capable of parallel charge setups with a Para board or just two batteries per pic. with a single parallel connector, at whatever amp setting you would like for your particular setup.
This unit uses amp settings instead of battery cell amount for selecting the discharge rate. Totally your choice of settings, can be just about anything from 1.5 amps to 30amps or more. Amps selectable with switches, and led's show switch position.
This is more versatile than having cell limits. My original schematic shows the trip circuit with load resisters, but all you have to do use the LM317's instead of the resisters at .23 cents each online.
Cost is around $17 , most parts in my garage from computers and years of saving.
I have been using this unit for a couple of weeks now, and it works perfect on my 6s and 4s batteries.
All my 1s-3s batteries discharge thru my TP820 with 100watts and 20 amps for discharge it's no problem for these packs.
Remember no series discharging with this setup. Separate batteries or short will result. Also, the unit is a 3-6s pack discharger, Thank you.
Old 12-26-2022, 09:24 AM   #136 (permalink)
Originally Posted by tggilkey View Post
I just finished building a discharger using Fyler's schematic in post 81. I have a problem with getting it to start with the Cell Log 8M. I may have fried the alarm but for a different reason than the common wrong way diode setup. I want to use this to discharge 2 5S packs (in reality a 10S pack) The relay, resistors for load, fans for cooling the heatsink, etc. are all sized to deal with the higher voltage -- and I made the assumption that because the Cell Log 8 had a 50V/500ma limit that I would be OK running a 10S battery through it. If it makes any difference I have version 2.0.8 of the Cell Log 8M.
When I first plugged in the balance lead (only space for one from one of the 5S packs) there was a spark that I was not expecting... The Cell Log still shows the cell voltages for the individual cells. The diode appears to be hooked up correctly. The pushbutton start works properly if the the alarm lead (removed form the Cell Log) is jumpered.
I have one uunused/new Cell Log 8 yet but don't want to try it until I get some collective wisdom from the contributors to this forum!
Ideas, suggestions, etc. will all be welcome. This has been fun to get the parts and think through, but I can see why charger builders don't make dischargers of any consequence that do what wwe want them to do.
Thanks, Tom
Remember no series discharging with this setup. Separate batteries or short will result. Also, the unit is a 3-6s pack discharger, current unit did not require series testing. Thank you.
