Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 02-12-2012, 12:47 AM   #1 (permalink)
Default Venture .60
Went to are local (well some what local) anual RC fair today and SCORED this Bruce Thorpe venture .60 kit for $60 No lazer cutting here all machine cut and looks flippin great WOW cant wait to start!
Name:	Venture .60 001.jpg
ID:	288798   Click image for larger version
Name:	Venture .60 002.jpg
ID:	288799   Click image for larger version
Name:	Venture .60 003.jpg
ID:	288800   Click image for larger version
Name:	Venture .60 004.jpg
ID:	288801   Click image for larger version
Name:	Venture .60 005.jpg
rotorfan is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 09:50 PM   #2 (permalink)
Got started today what quality for a non lazor cut kit. Everything fitting together very nicely. Gonna run dual servos on the ailerons so I drilled holes in the ribs to allow for the servo wire. and tubing for my airspeed telemetry.
Name:	Venture .60 010.jpg
ID:	289051   Click image for larger version
Name:	Venture .60 011.jpg
ID:	289052   Click image for larger version
Name:	Venture .60 009.jpg
ID:	289053   Click image for larger version
Name:	Venture .60 006.jpg
Old 02-13-2012, 09:39 PM   #3 (permalink)
Bruce Thorpe kits are excellent, and they fly great...awesome score!
What are you gonna power it with?
HeliDirect.com Team Pilot/Rep
Align T-Rex 700LE FBL, OS 91HZ-R, Hatori SB-20, Beast X
Align T-Rex 600LE FBL, OS 55HZ, Beast X
Outrage Velocity 50N2 FBL, OS 55HZ, Beast X
memosteve is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 10:00 PM   #4 (permalink)
Power is gonna be supplied with an OS .61 also gonna attempt to cowl in the nose. Got a bit more done today.
Name:	Venture .60 019.jpg
ID:	289405   Click image for larger version
Name:	Venture .60 018.jpg
ID:	289406   Click image for larger version
Name:	Venture .60 021.jpg
ID:	289407   Click image for larger version
Name:	Venture .60 025.jpg
Old 02-16-2012, 01:12 AM   #5 (permalink)
A bit more progress. Finished as much of the wing as I can for now and started on the fuse. Some of the fuse tabs were a bit tight and some a bit loose but no big deal, just used a small file on the tight ones and will pay a bit more attention to alignment and squareness before final gluing. What a great kit.
Name:	Venture .60 035.jpg
ID:	290154   Click image for larger version
Name:	Venture .60 036.jpg
ID:	290155   Click image for larger version
Name:	Venture .60 029.jpg
ID:	290156   Click image for larger version
Name:	Venture .60 040.jpg
Old 02-16-2012, 11:05 PM   #6 (permalink)
Well off to Oregon until Tuesday so the build will halt until then. Got the fuse glued up today and finished the turtle deck still have to do the wing mounting blocks front deck and drill the holes for the fuel lines throttle linkage etc. etc.. The stringers were a bit wavy so I had to fudge the notches one way or the other to make them straight.
Name:	Venture .60 041.jpg
ID:	290428   Click image for larger version
Name:	Venture .60 042.jpg
ID:	290429   Click image for larger version
Name:	Venture .60 046.jpg
ID:	290430   Click image for larger version
Name:	Venture .60 047.jpg
Old 02-17-2012, 10:28 AM   #7 (permalink)
Looking good...
Old 02-21-2012, 02:27 PM   #8 (permalink)
Old 02-24-2012, 10:19 PM   #9 (permalink)
Opted to go with the stock split landing gear so I reinforced the area and moved it forward 1/4" to hopefully eliminate the possibility of nose overs that Ive been told about. Fuse ready to have the nose cut off to prepare for my cowl build tomorrow. Fiberglass tape applied to wing.
Name:	ture .60 004.jpg
ID:	293054   Click image for larger version
Name:	ture .60 008.jpg
ID:	293055   Click image for larger version
Name:	ture .60 009.jpg
ID:	293056   Click image for larger version
Name:	ture .60 011.jpg
Old 02-25-2012, 05:10 PM   #10 (permalink)
well chopped the nose off. and the rough build of the new cowled nose. used 1/8" balsa for the sides and 1/2" for the bottom with 1/2" tri stock on the bottom to make sure its plenty thick since most will go away during shaping and sanding. Used 1/2" tri stock to support top cross member. Now while its all drying I will build a 2" ring from 1/8" light ply for the front since im using a 2" spinner. And a sanding block to attach to the motor shaft so I can sand the front smooth and flat. Sounds good anyway...lol
Name:	venture .60 048.jpg
ID:	293221   Click image for larger version
Name:	venture .60 049.jpg
ID:	293222   Click image for larger version
Name:	venture .60 050.jpg
ID:	293223   Click image for larger version
Name:	venture .60 051.jpg
ID:	293224   Click image for larger version
Name:	venture .60 054.jpg
Name:	venture .60 055.jpg
ID:	293229   Click image for larger version
Name:	venture .60 056.jpg
ID:	293230   Click image for larger version
Name:	venture .60 057.jpg
Old 02-25-2012, 10:23 PM   #11 (permalink)
And the nose shaping begins.
Name:	venture .60 058.jpg
ID:	293324   Click image for larger version
Name:	venture .60 059.jpg
ID:	293325   Click image for larger version
Name:	venture .60 060.jpg
ID:	293326   Click image for larger version
Name:	venture .60 061.jpg
ID:	293327   Click image for larger version
Name:	venture .60 063.jpg
Name:	venture .60 065.jpg
ID:	293329   Click image for larger version
Name:	venture .60 066.jpg
ID:	293330   Click image for larger version
Name:	venture .60 067.jpg
Old 02-26-2012, 11:45 PM   #12 (permalink)
nose is starting to take shape. Still alot more to go but getting there.
Name:	venture .60 071.jpg
ID:	293758   Click image for larger version
Name:	venture .60 072.jpg
ID:	293759   Click image for larger version
Name:	venture .60 073.jpg
ID:	293760   Click image for larger version
Name:	venture .60 075.jpg
ID:	293761   Click image for larger version
Name:	venture .60 077.jpg
Name:	venture .60 078.jpg
ID:	293763   Click image for larger version
Name:	venture .60 079.jpg
ID:	293764   Click image for larger version
Name:	venture .60 080.jpg
Old 02-28-2012, 12:49 AM   #13 (permalink)
More work on the nose today gettin close still a bit more sanding. Started stab,elev and fin today also.
Name:	venture .60 084.jpg
ID:	294110   Click image for larger version
Name:	venture .60 085.jpg
ID:	294111   Click image for larger version
Name:	venture .60 087.jpg
ID:	294112   Click image for larger version
Name:	venture .60 090.jpg
ID:	294113   Click image for larger version
Name:	venture .60 092.jpg
Name:	venture .60 093.jpg
ID:	294115   Click image for larger version
Name:	venture .60 094.jpg
ID:	294116   Click image for larger version
Name:	venture .60 095.jpg
Old 02-29-2012, 11:10 PM   #14 (permalink)
Tail starting to come together. Decided to go with the stock tail wheel set up. Should finish the tail fin fairing tonight
Name:	venture .60 097.jpg
ID:	294735   Click image for larger version
Name:	venture .60 098.jpg
ID:	294736   Click image for larger version
Name:	venture .60 099.jpg
ID:	294737   Click image for larger version
Name:	venture .60 100.jpg
ID:	294738   Click image for larger version
Name:	venture .60 101.jpg
Name:	venture .60 102.jpg
ID:	294740   Click image for larger version
Name:	venture .60 103.jpg
Old 03-01-2012, 10:33 AM   #15 (permalink)
Love the Miller can!
Old 03-01-2012, 11:39 AM   #16 (permalink)
Thanks memo
Old 03-01-2012, 10:48 PM   #17 (permalink)
Default Progress
Everything dry fitting good,still even more sanding to do on nose and tail fairing but getting there. Time to figure out aileron servo mounts in the wing since I went with dual set up instead of stock single,I know what bay there goin in just need to get placement right and build mounts then I can place ailerons. Gettin there slow but sure.
Name:	venture .60 104.jpg
ID:	295039   Click image for larger version
Name:	venture .60 107.jpg
ID:	295040   Click image for larger version
Name:	venture .60 109.jpg
ID:	295041   Click image for larger version
Name:	venture .60 110.jpg
ID:	295042   Click image for larger version
Name:	venture .60 111.jpg
Name:	venture .60 113.jpg
ID:	295044   Click image for larger version
Name:	venture .60 114.jpg
ID:	295045   Click image for larger version
Name:	venture .60 115.jpg
Old 03-06-2012, 11:51 PM   #18 (permalink)
Still progressing Just been doing misc. stuff like mounts for ailerons in wing and sanding control surfaces will post pics soon. Got my color scheme picked out and covering on the way. Also decided Im gonna run smoke on this one! Stay tuned.
Old 03-07-2012, 11:02 PM   #19 (permalink)
Aileron mounts done besides making the slots a little neater. I think Im gonna need a little longer horns, If anyone has some for hitecs let me know.
Name:	venture .60 117.jpg
ID:	296851   Click image for larger version
Name:	venture .60 118.jpg
ID:	296852   Click image for larger version
Name:	venture .60 119.jpg
ID:	296853   Click image for larger version
Name:	venture .60 120.jpg
ID:	296854   Click image for larger version
Name:	venture .60 121.jpg
Name:	venture .60 122.jpg
ID:	296856   Click image for larger version
Name:	venture .60 123.jpg
ID:	296857   Click image for larger version
Name:	venture .60 124.jpg
Old 03-09-2012, 10:51 PM   #20 (permalink)
Now I decided to do up the turtle deck. Still have plenty of sanding to do but I think It will work, just need to build per plans and fly... but still waiting for covering to show up and weather is shit here in Wa. so something to do.
Name:	venture .60 125.jpg
ID:	297359   Click image for larger version
Name:	venture .60 126.jpg
ID:	297360   Click image for larger version
Name:	venture .60 127.jpg
ID:	297361   Click image for larger version
Name:	venture .60 128.jpg
ID:	297362   Click image for larger version
Name:	venture .60 129.jpg
Name:	venture .60 130.jpg
