Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Electric
MA Electric IonX2, Razor and Furion Support forum
Old 11-01-2010, 04:51 PM   #181 (permalink)
Originally Posted by src053 View Post
wow the edges look super smooth.
did you do majority of cutting with the dremel?
Yep, all done with the Dremel. I just used one of the 32mm reinforced cut-off wheels to get the main shape, then used the flat side of that to do the more precise final grinding.
dauste is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 05:30 PM   #182 (permalink)
So I think you can see why they need some trimming down, could have had these a lot sooner, I was just too proud to ask someone which ones to get!
Also shown on page 37 of the manual
Zeal Rotor Blades
Team Horizon Hobby
Brian James is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 05:41 PM   #183 (permalink)
Shown, but you don't tell us what they are though. (LOL, I know depends on what servos you use)!
Anyways I think I did a better job than your drawn ones!!
I had the dubious pleasure of having to dust the whole thing off before I took those pictures. If the batteries I ordered take much longer to arrive, I'm going to splash out on some a bit closer to home! Can't wait much longer to get this thing in the air.
Old 11-02-2010, 03:02 PM   #184 (permalink)
http://www.readyheli.com/MIK4021-Car...a_p_35281.html
No mess. no fuss.
pcskyhi is offline        Reply With Quote Quick reply to this message
Old 11-02-2010, 04:30 PM   #185 (permalink)
Ha! There you go, I know what to order next time!
Old 11-02-2010, 09:33 PM   #186 (permalink)
NERD
Originally Posted by pcskyhi View Post
Thank you for this link!!!! I ordered a set for my Stratus. Was going to start grinding away on some wheels for it tomorrow and was not looking forward to the mess, but I would much rather use something like this if it slip fits on as good as the wheels. It has the same 20mm spacing.
Norman
Fun times and good friends.
Thrasymedes is offline        Reply With Quote Quick reply to this message
Old 11-03-2010, 07:35 AM   #187 (permalink)
The benefit to the wheel is that you can choose where to mount the ball as you have to drill your own hole. This eliminates the need for sub trim.
Zeal Rotor Blades
Team Horizon Hobby
Old 11-03-2010, 08:17 AM   #188 (permalink)
Why is everyone deathly afraid of sub-trim? In a modern radio, it is probably just another number in a calculation that the radio is going to compute regardless of the value.
prototype3a is offline        Reply With Quote Quick reply to this message
Old 11-03-2010, 10:58 AM   #189 (permalink)
Not "afraid" of it at all, but using it may add steps when leveling the swashplate throughout the rest of the travel. Not a big deal at all. I use JR servos, and don't have the option of the "big futaba wheel", so I end up using sub trim myself.
Zeal Rotor Blades
Team Horizon Hobby
Old 11-03-2010, 11:23 AM   #190 (permalink)
I would like to see those Mikado horns in person because they look pretty sweet.
Brian, I wasn't calling you out or anything. I thought maybe I would get an intelligent answer here. It just seems like the majority of heli pilots despise sub-trim with no reasonable explanation. How does sub-trim add steps when leveling the swash?
My procedure is....
1. Level servo horns with sub-trim/repositioning.
2. Adjust linkages to level swash at an appropriate height.
3. Adjust individual channel travel limits to level the swash at max and min collective.
Old 11-03-2010, 01:44 PM   #191 (permalink)
My procedure is....
Yeah, no problem The way you describe is about as good as it gets! I also add a couple mixes to get rid of interaction as well.
Zeal Rotor Blades
Team Horizon Hobby
Old 11-03-2010, 07:52 PM   #192 (permalink)
NERD
Just the way some of the older equipment used to operate I believe, so people passed down that knowledge and it has been an assumed best practice. With the newer equipment sub trims are just another useful tool with no real negative impact imho. My setup process is exactly the same with also some mixes to get the swash level all through the throw like Brian does. It usually doesn't take much. Also, subtrim doesn't move on a large scale on my Futaba 10C, +15 subtrim doesn't equate to +15 on the servo menu, more like +3. Subtle but useful.
The biggest thing for me though in those type servo arms is not having to friggin' grind the things every time. Nothing better than grinding on yet another wheel, trying to shape it and then cleaning up the dust. Feels too much like wood carving... I like plastic for the sake of my servos, and the fact that they press on snugly to the servo splines, but I don't like the grinding. Ack!
Norman
Old 11-03-2010, 09:12 PM   #193 (permalink)
I was thinking earlier that if one were... creative... that you could probably rig up a powered servo and a dremel to sort of automate the grinding. But, yeah, I usually try to avoid that sort of non-sense too. However, on one of my helis we took a six spoke horn and removed three so it looks like a Y. Looks pretty cool and the one arm that might get in the way isn't there to do so.
Old 11-04-2010, 06:07 AM   #194 (permalink)
I have heard from many people that Min Air has quality products backed by great customer service, and so far not only is this kit going together at a great pace, but also top notch quality. I am having so much fun putting this bird together I should of bought 2
fenwayrick is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 07:35 AM   #195 (permalink)
Don't worry Rick after you fly it you will buy a second one!
Rich Molinaro
Rich M is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 08:02 AM   #196 (permalink)
Aww man! About a week too late. I also went the dremel route. I knew someone made a horn at 19.5mm - 20mm that would work on Futaba's.
Thanks for the link.
TBS Discovery
Rave 450 FBL - miniVbar
Trex 500 ESP FBL - Beastx
Trex 600 ESP FBL - Beastx
adroc3905 is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 10:02 AM   #197 (permalink)
I actually use the Mikado horns also. They are nice and beefy and they engage very far down on the horn. Much easier than making your own.
Rich Molinaro
Old 11-04-2010, 04:52 PM   #198 (permalink)
+1. Here are some of the arms I use for Futaba servos when things need to be really strong:
Left top: the Mikado 20 mm Futaba arms.
Right: the even stronger (and longer if needed) Du-Bro servo arms.
Left bottom: core-rc.com alloy arms, these are in fact intended for r/c racing cars.
Dave, fantastic heli !!!
Logo 800 - TDR 14S - TDR 12S - Logo 500SE - Logo 400 - Furion 450 6S mini-V - 300X - 150S - mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner - F27D Evo
redbird300 is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 05:37 PM   #199 (permalink)
Thanks Raf, I knew I should have asked you about the arms.
I actually quite enjoyed grinding the wheels down though, nothing like a bit of fabrication to while away the hours!
Saying that, I've still got a bit of titanium sheet left and have been eyeing up the tail fin!!
Old 11-05-2010, 09:05 PM   #200 (permalink)
Anybody knows the pitch range on the marks built into the blade Grips??
Thanks,
epc2.
epc2 is offline        Reply With Quote Quick reply to this message
