Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 800 Xxtreme
Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion
Old 04-28-2013, 10:25 AM   #1 (permalink)
Default Heli goes crazy
My 800 went a little crazy yesterday. Everything looks fine but dont know what happened. You wont see it in the vid but it starts shaking like crazy. You will hear it though and its never done it before. http://www.youtube.com/watch?feature...&v=39B75svWi6Q Any idea's?
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is offline        Reply With Quote Quick reply to this message
Old 04-28-2013, 09:02 PM   #2 (permalink)
Sounds like the motor was kicking out.
Normally they let out a good squeel when there going out of sync , hard to tell if let out a chirp as you let off on the pitch.
What rpm are you at ?
Which version of software on esc ?
Batteries now / good ?
Anything in vbar log ?
Mabye post some info on the heli
build parts
batts
servo's
bec ?
first flight or several flights
tx
rx
vbar log
etc
Martin
Logo XXtreme 800 8917 / 256HV VBC
Logo XXtreme 700 on 14s 8917 / 256HV VBC NEO
Logo XXtreme 770 14s 8917/9188 VBC
Logo 600 8917/ 9188 4035-500 VBC NEO
rcmarty is offline        Reply With Quote Quick reply to this message
Old 04-29-2013, 02:59 AM   #3 (permalink)
Smile
Sounded like something slipping to me.
OWB??
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote Quick reply to this message
Old 04-29-2013, 11:18 AM   #4 (permalink)
Batteries now / good ? Thor (only a few flights)
Anything in vbar log ? Yes (Log being looked at)
build parts All stock
batts Thor
servo's MKS HV
bec ? No (Pulse Rx pack)
first flight or several flights (less than a dozen)
tx DX18
rx Two DSMX sats
vbar log being looked into
etc
Martin
This heli only gets a flight once in a while. The last flight before this happened it showed no signs of any issues. It was flipping/rolling and FFF just as smooth as can be. I am also having issues with my E5 (mini Vbar) and crashed my 450 (AR7200BX) but not sure if it was me or not. Starting to think it might be a Tx issue.
Old 04-29-2013, 08:51 PM   #5 (permalink)
Your other heli's doing the same thing ?
A bad pot on the throttle channel would sound like that
And as mentioned a slipping one way would also. This one is looking more plausable as you have some non issue flights.
Did you grease the oneway during the build ?
Try playing with the transmitter in the servo screen to see if you can get any random movements.
I'd assume spectrum has there issues sorted by now (bad pots on dx6i , teething issues with dx8, etc) and the dx18 being the flagship should have some better hardware inside (i assume).
The log will shed some light i think
Martin
Old 04-29-2013, 08:53 PM   #6 (permalink)
Any pics of the setup and wiring ?
Have you read the article about placing sats properly ? (archeli site )
When looking at the sat the left side wisker is the active antenna , the other side a ground reference ( aka lookin pretty). Need active antenna not blocked by CF
MArtin
Old 04-29-2013, 10:17 PM   #7 (permalink)
Smile
Could also have been a slipped pinion on the motor shaft.
Check it out for alignment and security.
JR X9503.
Old 04-29-2013, 11:02 PM   #8 (permalink)
Sound like is not using governor and is having issue with throttle curve !!
Mikado Logo 800XXtreme, Vbar 5.3, 813mm Edge Blades, 14S Kontronik Cool Kosmik 200HV.
ALIGN T-REX 550E DFC with 600 Boom, 603mm Edge Blades, Kontronik Heli Jive 120HV, Pyro 600-12, Mini Vbar 5.3 Pro, V3 Tail, Black Gears, Many KDE Upgrades.
Nelvick is offline        Reply With Quote Quick reply to this message
Old 04-30-2013, 01:36 PM   #9 (permalink)
Not running gov, sats are mounted right, Rx packs good. Both my 800 and 550 are acting funny. Although the 550 did it while I was inverted. Everything looks fine on the heli's. I will check the servo screen. Invalad file comes up when I try to post Vbar logs.
Old 04-30-2013, 09:32 PM   #10 (permalink)
if you change the name on the file from the default setting, add .pdf to the end
If the 550 is doing the same thing , that eliminates alot of the hardware.
I'd focus on the transmitter.
Do you have another tx to test with ?
Martin
Old 05-01-2013, 07:40 AM   #11 (permalink)
Here is the file.
Old 05-09-2013, 03:15 PM   #12 (permalink)
Originally Posted by Corvette & Copter Guy View Post
Here is the file.
*Looks at Sig*
On a completely different note did you know a Logo XXtreme 800 will fit into the back of a 2009 Corvette Z06 (As long as you have the canopy off) The tail just sits between the two seats!!
I had the XX, TDR and my Logo 400 with charger (But no Generator) in the back of my new to me Z06
Logo XXtreme, Kosmik, Pyro 800-48L Futaba 157s/256. Henseleit TDR, Pyro 700-52, 120 Jive, V-Bar 5.3, BLS253/251. Logo 600SE, Scorp 5020-450KV, 120 Helijive, Futaba 451s/251. Logo 400, Align 510MGs, JR 8900G, Kontronik Jive 80+ LV,Mini Pyro 400-14,
jtjohn1 is offline        Reply With Quote Quick reply to this message
Old 05-11-2013, 12:51 AM   #13 (permalink)
Originally Posted by jtjohn1 View Post
*Looks at Sig*
Thats funny. The hatch area of my vette has my custom sound system so its a little smaller. Trust me...I have thought about seeing how many heli's/planks I can fit it there and take to the field.
