MSH Protos MSH Protos Helicopter Support Forum |
12-29-2014, 11:21 PM | #341 (permalink) |
Nice piro flips CH. The stick movements were a nice touch.
SAB Black Thunder Sport SAB Goblin 570 // 500 Sport SAB Goblin 420 OXY 3, LYNX Heli Innovations Team Pilot |
12-31-2014, 01:08 AM | #342 (permalink) | ||||
Thanks. Weather was better today so I re-did the vids with better flying.
Human Slow-mo piro flips
Stronger pack (too bad cams stopped mysteriously missing the hard flying parts so I had to restart)
mCPx'es/130X/3D-foamie: ugly mods 300X: fast beater/trainer, Protos stretched: trainer but can also go fast FPV250 5.8G, nQx FPV, Oh also Trex 450DFC |
02-17-2015, 03:32 PM | #343 (permalink) |
Mr Tailhappy Protos Max flight
Friend of mine is getting used to the protos max,
https://www.youtube.com/watch?v=fAc5zetRkjg I hope you like it. B |
03-22-2015, 05:30 AM | #344 (permalink) | ||
Mr TailHappy's crazy demo flight at Rotor Live 2015
Awesomeee!!
04-21-2015, 10:52 AM | #345 (permalink) | ||||
Talking about visibility mod, this started off as a worth-some-laugh activity but after a few iterations (the GOBLINg, the Ribblin, and now) "Jasmin" actually turns out pretty good.
Really helps visibility from afar. Keeping it on for longer than I originally expected.
05-03-2015, 01:06 AM | #346 (permalink) | ||||
...and then there's "Pistachio". More lightweight solution, 12g vs 40g.
Here's an interesting comparison of the same flight shot with 2 different cameras from different perspective. My cap-cam has a longer zoom which shows more details on the heli and its attitude. But because of the longer zoom, often times the stationary object background is not in frame which means you lose the sense of speed and change of speed of the heli. My friend shot the flight from farther away with wider zoom (mainly to test the higher than full HD resolution). And because of the wider zoom, it's more of a stationary aim which means stationary objects are always in view for easy reference to speed and change of speed. Different perspective but both have the merits for enjoyment.
05-10-2015, 11:00 PM | #347 (permalink) | ||||
For curiousity I flew my Revolution 430mm blades with my setup/settings for 470 blades today. That means only 2450rpm HS with 13T. Definitely not punchy or responsive as with 470 blades but flyable, good for practice flying.
430 blades at 2450
Back to 470 blades at 2300
08-20-2015, 09:18 PM | #348 (permalink) | ||
First flight filmed on my Protos, nothing too amazing. I need to spend some time on the cyclic it is really mushy feeling and in the wind dolphins. I also need to up my auto bail out spool up rate it's way too slow at the moment.
Team MSH USA - Cyclone Blades MSH Prôtos 380 Brain 2 MSH Prôtos Max V2 Brain |
08-20-2015, 10:20 PM | #349 (permalink) |
Regarding auto bailout, your problem is with the YGE heli soft-start which is always triggered once it sees zero throttle. I don't know about the Brain but vBar has the "idle" option for auto bailout. When you auto vBar doesn't cut throttle all the way. It'll maintain motor speed at the lowest possible so the YGE won't trigger soft-start when vBar resume throttle. another option is to set auto at 10% throttle or whatever the lowest for the YGE to not trigger soft-start.
08-20-2015, 11:46 PM | #350 (permalink) | |
08-21-2015, 12:47 AM | #351 (permalink) |
It's weird that the Brain will even allow setting bailout ramp up speed this slow. Soft-start speed this slow makes sense, but bailout ramp up speed this slow? vBar can't even set bailout ramp up speed just soft-start spoolup speed. I wish vBar sllows adjustable bailout ramp up speed. Pre-set is too fast.
08-21-2015, 01:08 AM | #352 (permalink) | |
Nick, crank that sucker up. This thing is a belt not a gear/pinion. So you aren't going to melt your main gear |
08-21-2015, 08:45 AM | #353 (permalink) | ||
08-21-2015, 08:54 AM | #354 (permalink) |
Good old Castle! I think Alex starts around 50? And we're running stupid high numbers on the Max. But the drivetrain there is more robust
08-21-2015, 02:13 PM | #355 (permalink) | |||
08-22-2015, 10:02 AM | #356 (permalink) | ||
Sweet flight doublech! I need to work on my funnel transitions as they stink. Love the way this P500 flies, but I'm switching to an iKon on it.
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis |
09-26-2015, 10:25 PM | #357 (permalink) | ||
Another geriatric p500 flight today. Wonderful weather for flying and the now iKon equipped heli is flying great.
02-08-2016, 05:43 AM | #358 (permalink) | ||
years keep going so the mighty protos 500
my Prôtos twins & Acrobat Shark ............... |
04-22-2016, 09:15 PM | #359 (permalink) | ||
Nothing special, but I'm excited to get it in the air! Got the maiden flight in today and all seems to be good. Was just hoverin it around for the first pack.
Stretched Blade 270CFX w/Custom Scorpion+3Digi MSH Stretch Carbon Protos 500+Custom 770kv Scorpion 4015+80A YEP+BrainV1 https://www.youtube.com/c/RCBound#699RCHN |
04-23-2016, 12:12 AM | #360 (permalink) | ||
Again, nothing special. Just hovering it around and listening, watching for anything that may be obviously setup wrong. No clue what head speed I'm running, I did a Gov Store with a 4V/cell pack and set a flat throttle curve to 65% for this flight.
Flight starts around 2:45 What you see happen at about 4:10 is an issue with the OrangeRX sat I believe. I'm also running a Spektrum sat so I fully expected this issue to go away. So far the issue is strictly when running at 11ms and with the 3Digi failsafe turned on. The engineers/programmers have already implemented a change that should solve the issue. I need to get the updated firmware. I will be switching to 22ms to avoid the issue in the mean time.
Stretched Blade 270CFX w/Custom Scorpion+3Digi MSH Stretch Carbon Protos 500+Custom 770kv Scorpion 4015+80A YEP+BrainV1 https://www.youtube.com/c/RCBound#699RCHN Last edited by RCBound; 04-23-2016 at 11:29 AM.. |
