Old 03-21-2015, 07:16 AM   #1 (permalink)
Default Powerjive 120hv won't initialize using 6s
Just got a brand new powerjive. I'm using a single 6s pack on a agile 5.5 for now. Using a mini vbar and stock motor. No beeps or red lights when I plug in main battery.
acwise32 is offline        Reply With Quote Quick reply to this message
Old 03-21-2015, 08:30 AM   #2 (permalink)
The ESC needs to be programmed! When you pull the Jumper tones will be heard!
Magneto is offline        Reply With Quote Quick reply to this message
Old 03-21-2015, 09:07 AM   #3 (permalink)
I pulled the jumper still nothing happened
Old 03-21-2015, 09:28 AM   #4 (permalink)
I need more info is the motor connected, Do you have a linear throttle curve in normal for programming and Th.Hold off? Please check the jumper to see that the metal contacts are present and plugged into the data port lined up with the arrows. Is the master cable plugged in correctly to the ESC and REC/FBL?
Old 03-21-2015, 09:36 AM   #5 (permalink)
Yes to all your questions. I was wondering if just using one 6s 5000mah bat was my problem
Old 03-21-2015, 09:46 AM   #6 (permalink)
A Jive can be programmed with a 6s battery! Do you have a different motor to test
Old 03-21-2015, 09:51 AM   #7 (permalink)
Is your VBAR powering up successfully?
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot
jmackey is offline        Reply With Quote Quick reply to this message
Old 03-21-2015, 09:57 AM   #8 (permalink)
Yeah the mini vbar works perfect
Old 03-21-2015, 01:26 PM   #9 (permalink)
Tonight I will hook up a different motor. I gots to figure out this issue
Old 03-22-2015, 08:47 AM   #10 (permalink)
I guess I got a bad esc out of the box. I've tried everything except to plug in 12s to it.
