Old 01-17-2015, 01:36 PM   #1 (permalink)
Default kontronik sweet spot.
Hello, i have a simple question.
im updating and reconfiguring all my electronics / ESC / TX / FBL.
i have 3 different products form kontronik and will like to know whats the sweet spot for the throttle curve using MODE 4 ..
Koby 40lv / EOX Motor 2214-3S-4100KV / lynx 300. (is a blade 300x but i only use lynx upgrades)
Heli Jive 120HV / Pyro 650-65 / Goblin 570
Kosmik 160 (not the cool)/ Pyro 750-56c / Goblin 700
EDITED Answer.
Sweet Spot
Koby 40 60%-70%
Heli jive 120hv 60%-70%
Kosmik 160 80%
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 02:01 PM   #2 (permalink)
Which ESC? Kosmik or Jive?
TDR PowerCroco 1 / TDR 2 / TDR 3 / Forza 700 /
Diablo 700 14s / 700 12s / Logo 800 / 700 Extreme / Logo 600SE / Logo 690SX / Goblin 770 Carbon / Goblin 700 / BD3SX / Kontronik / Jeti DS-16 Red Racer #11..
chrisansilver is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 05:58 PM   #3 (permalink)
The 3 of them
Sweet spot koby 40
sweet spot Heli jive 120hv
Sweet spot Kosmik 160
Jeti DS-14 Edition
Old 01-17-2015, 06:57 PM   #4 (permalink)
Kosmik 80%
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 09:15 PM   #5 (permalink)
koby and helijive is 60-70%
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 09:46 PM   #6 (permalink)
ok so.
Sweet spot koby 40 60%-70%
sweet spot Heli jive 120hv 60%-70%
Sweet spot Kosmik 160 80%
thnx all.
Jeti DS-14 Edition
Old 01-19-2015, 06:47 AM   #7 (permalink)
Have just been setting up a Koby 55, and in the manual Koni recommend 80% for the throttle when using the gov.
Regards, Mark R (#248)
TRex 700E V-Bar NEO, BLS251, DS8915's, HJive120, JLog, VControl Carbon
TDR 710 CYs, V-Bar NEO, MPH83s, Jive 120, JLog, R2 Buffer, VControl Carbon
Logo600SX 600 CYs, V-Bar NEO, 8715s, Jive120, JLog, R2 Buffer, VControl Carbon
Wizza is offline        Reply With Quote Quick reply to this message
Old 01-19-2015, 07:47 AM   #8 (permalink)
its the same as the jive its 80% pwm but in order to get that you need to put 60% in your transmitter. it uses a formula to convert throttle percentage in transmitter to starting pwm.
starting pwm = (throttle percentage/2) + 50%
starting pwm is what needs to be around 80%
Richard Zappe
Old 01-19-2015, 10:46 AM   #9 (permalink)
This is an interesting thread, glad it came up. I've been running a 80% throttle on my KOBY 55 for as long as I've had it. I had no clue that it wasn't set up correctly but it's been flying great. Time to reset my radio to 60% and start testing pinions.
Kris
kjdubuque is offline        Reply With Quote Quick reply to this message
Old 01-19-2015, 11:06 AM   #10 (permalink)
one question about the Koby for calculating HS in mr mel calc, should i use for the GOV. Jazz/Jive (mode 4) or use Kosmik Mode 4???
Jeti DS-14 Edition
Old 01-19-2015, 11:59 AM   #11 (permalink)
jazz/jive
Richard Zappe
Old 01-19-2015, 12:17 PM   #12 (permalink)
Originally Posted by Wh1teAfr1can View Post
jazz/jive
Jeti DS-14 Edition
Old 01-19-2015, 08:55 PM   #13 (permalink)
Speaking of sweet spot, does it mean that the esc
Is working the most efficiently at those percentage
Including the motor or its only referring to the governor
Thks
jchen is offline        Reply With Quote Quick reply to this message
Old 01-19-2015, 09:16 PM   #14 (permalink)
Thks
both. it is the best trade off. ideally for efficiency you would want 100% throttle but that isnt good for the governor because you have no overhead. so you compromise by going 80% or so to get good governing at the best efficiency possible.
Richard Zappe
Old 01-19-2015, 10:19 PM   #15 (permalink)
Interesting... Thanks Richard...
Old 01-20-2015, 08:43 AM   #16 (permalink)
Hi Richard thanks but lets assume that we have a very strong motor
that doesn't bog than there's no need for governor right or we can reduce
governance by increasing the throttle percentage. Does this make sense ?
Old 01-20-2015, 08:51 AM   #17 (permalink)
yes the more powerful the motor is relative to helicopter mass the lower the headroom requirement is needed. this needs to be confirmed with logs for each setup and batteries will play a role in this also.
Richard Zappe
Old 05-17-2015, 10:59 AM   #18 (permalink)
Hello, on mr Mel do we need to activete "ATV IS AJUSTED" on the Jazz/Jive to calculate correct??
Jeti DS-14 Edition
Old 05-17-2015, 11:45 AM   #19 (permalink)
No do not adjust ATV or endpoints, was incorrect info waaaaay back then. Use the calc without ATV adjustment.
VControl
Old hand at Planks
Peter
Old 05-17-2015, 12:11 PM   #20 (permalink)
Jeti DS-14 Edition
