Old 03-29-2015, 04:46 PM   #1 (permalink)
Default Alternating green and red blinks on kosmik?
Hey guys, my mostro is flying just fine but after I land most of the time I have alternating red and green blinking lights. I can't find any info on what this might be so I'm hoping someone here knows.
Thanks!
180cfx, Align 450L, Goblin 500, Rush 750, Avant Mostro
Lynx Team Pilot
Pitch-Itch is offline        Reply With Quote Quick reply to this message
Old 03-29-2015, 05:01 PM   #2 (permalink)
Thanks!
Means a warning during use. Take the card out and open the error.txt file and take a look should be the last entry.
My guess would be getting close to either the temp or amp limit.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 03-29-2015, 05:13 PM   #3 (permalink)
Ok I'll check it out. I hope it's not over amp. Don't know what I could do to lower amperage.
It probably isn't over temp. So it's gotta be over amp. If it is I'm lost on what to do. I wasn't even flying that hard today.
Lynx Team Pilot
Old 03-29-2015, 05:50 PM   #4 (permalink)
Where do you find the error file? All I have on the card are DAT files.
Lynx Team Pilot
Old 03-29-2015, 08:46 PM   #5 (permalink)
ok then it may just be on the last log file. so open it up in note pad and see if you see any warnings
Richard Zappe
Old 03-30-2015, 05:20 PM   #6 (permalink)
Opened every log I have from yesterday and I don't have any error codes that I can see at all.
Where would these error logs be? They don't show up in logviewer, and they don't show up in notepad.
Surely someone affiliated with Kontronik has to know where their own logs write to?????
Lynx Team Pilot
Old 03-30-2015, 09:41 PM   #7 (permalink)
pm me and i will give you my email address so you can send me one of the logs.
The warnings are typically on one of the lines where they occur in the log so open it and do a ctrl-f and search for warning.
Richard Zappe
Old 03-31-2015, 05:05 PM   #8 (permalink)
Doing the search worked. Man, do they hide the warnings in a sea of text or what?
I am getting overcurrent #2 warning.
Only problem, I have ZERO clue on how to reduce the current levels without limiting how hard I fly.
I don't know what to do from here. My temps are fine. I'm just getting amp spikes (Imot, not Ipeak) of just over 300 amps.
Of course, shortly after the highest current spikes I get the highest temps, which peaked around 70c.
Lynx Team Pilot
Old 03-31-2015, 05:51 PM   #9 (permalink)
What motor are you using?
Richard Zappe
Old 03-31-2015, 06:39 PM   #10 (permalink)
Kde 700xf 505kv
Lynx Team Pilot
Old 03-31-2015, 07:38 PM   #11 (permalink)
Kde 700xf 505kv
Are you running it on fixed or auto timing? KDE motors are known to have large amp draw on pretty much any speed controller.
Richard Zappe
Old 03-31-2015, 07:43 PM   #12 (permalink)
Auto timing. Should I switch to fixed timing?
Lynx Team Pilot
Old 03-31-2015, 07:54 PM   #13 (permalink)
That is a way to reduce amps. Or more collective management. which esc is this on a 160? They should have a recommendation on KDE's site about what fixed timing to run it on.
Richard Zappe
Old 04-01-2015, 07:25 AM   #14 (permalink)
They recommend 5-15 degrees. I guess I will go fixed timing at around 12 degrees and step down from there as needed.
Lynx Team Pilot
