Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Electric Conversions
700 Electric Conversions Align T-REX 700 Electric Conversions
Old 12-16-2009, 06:51 AM   #261 (permalink)
Team Taco Member
Originally Posted by salvedor View Post
thanks I bought sk360 and rjx flyarless head. I know v-bar is much better but its more expensive so I want to try with sk360
I had this setup on 3 of my previous heli's so let me know if you need help setting it up..
bpd964 is offline        Reply With Quote Quick reply to this message
Old 12-16-2009, 09:50 AM   #262 (permalink)
thanks bpd964. I will contact with you
salvedor is offline        Reply With Quote Quick reply to this message
Old 12-16-2009, 10:08 AM   #263 (permalink)
Is it confirmed that the KDE electronic pinion support DOES NOT work with the Helidirect/RJX e-conversion?
I know I heard somebody else on HF who couldn't use the EPS with the RJX conversion (I think it was because the RJX motor mount has 2 motor mount screw holes and the EPS requires 3). Perhaps you could drill and tap the third hole--but it may be easier to purchase the KDE motor mount & EPS ($29 + $39 respectively) and not use the RJX motor mount that comes with the conversion.
That's my plan anyway...
Attention Deficit Helicopter Disorder
ADHDJeff is offline        Reply With Quote Quick reply to this message
Old 12-16-2009, 10:21 AM   #264 (permalink)
Team Taco Member
Thanks.. I will try and find the motor mount plate.. Too bad the person didn't tell that it wouldn't work with my conversion kit when I was talking to him on the phone about my order.. The EPS is already on it's way to me..
Old 12-16-2009, 07:12 PM   #265 (permalink)
Default Suggest to this combo Esc & brushlss .. is too cheap
I want to build a Trex 700e to AP and I need your opinion about this combo:
http://www.centuryheli.com/products/...&currentid=345
Work fine to a Trex 700 E?
Please let me know
Cascarlos is offline        Reply With Quote Quick reply to this message
Old 12-16-2009, 10:37 PM   #266 (permalink)
Please let me know
It looks like that ESC is only rated for 10S so if you want to run 12S batteries like all of the other 700E conversions--that kit will not work.
Old 12-17-2009, 10:48 PM   #267 (permalink)
I used the KDE plate and the EPS on my LE build no issues. After reading your issue and looking back at the pictures of the RJX motor mount it should be a VERY simple fix for you.
You can just drill the third hold in the RJX motor mount, there's no tapping or real precision that's needed here as they're just "through-holes" for the bolts to go down into your motor.
On my KDE motor mount, I had to enlarge the holes from 3mm to 4mm, I just screwed it down to a small block of wood then used the drill press to mill out the holes. Should be just as easy to make a new hole. If you don't have, or have access to a drill press. A regular drill should do the trick just as well, maybe use a small needle file to smooth it out.
Hope this helps...
-Mark
Name:	EPS mount.jpg
[COLOR=Navy] #FutabaUSA , #XLP, #SpinBlades
MarkFlysHelis is offline        Reply With Quote Quick reply to this message
Old 12-17-2009, 11:02 PM   #268 (permalink)
Team Taco Member
I swear you were reading my mind because I am currently at my work bench wondering if I should drill or not.. Thanks man.. I'm going in..
Old 12-17-2009, 11:10 PM   #269 (permalink)
WAIT !!!!!!!!
DONT DRILL 2 HOLES, YOU ONLY NEED ONE !!
Old 12-17-2009, 11:15 PM   #270 (permalink)
Team Taco Member
.... Yeah.. I'm only drilling a hole big enough to fit the one screw. Don't want to weaken the mount.. I'm also just going to drill a slightly elongated hole and not a slit from either end.. Thanks..
Old 12-17-2009, 11:17 PM   #271 (permalink)
Shew...Good deal, post up a pic when you're done !!
Old 12-17-2009, 11:20 PM   #272 (permalink)
Team Taco Member
Sure will..
Thanks again.. Really appreciate the help..!
Old 12-17-2009, 11:48 PM   #273 (permalink)
What would happen if you used the EPS but didn't drill that 3rd hole or use the 3rd bolt?
Wouldn't it still work because the direction of pressure on the pinion is away from the main gear so the EPS (by virtue of it resting on the motor plate) would still prevent flex?
Old 12-18-2009, 12:01 AM   #274 (permalink)
Team Taco Member
I'm not totally sure but I think the extra hole adds that much more rigidity and security to the pinion support to ensure that it doesn't twist, slide or tilt. I guess it's tougher to tilt with 3 points than it will be with just 2. I guess with only 2, you can still or rock a bit pushing that much power...
Old 12-18-2009, 12:15 AM   #275 (permalink)
Yeah, I guess drilling the 3rd hole is "cheap insurance".
Old 12-18-2009, 09:01 AM   #276 (permalink)
Team Taco Member
Made the hole and elongated it a little to give me a little bit of pinion travel because i'm not sure how much I will need. If I need to elongate the hole more, I can do it pretty easily to get the correct mesh.
Old 12-18-2009, 09:38 AM   #277 (permalink)
Team Taco Member
After cutting pinion and installing extension..
ID:	129368   Click image for larger version
ID:	129369   Click image for larger version
Old 12-19-2009, 04:01 PM   #278 (permalink)
Hi,
Here is my 700E with the brand new canopy.
I use custom motor shaft and bearing holder.
Joker
ID:	129585   Click image for larger version
ID:	129586   Click image for larger version
ID:	129587   Click image for larger version
joker is offline        Reply With Quote Quick reply to this message
Old 12-19-2009, 04:08 PM   #279 (permalink)
Team Taco Member
What kit are you using?
Old 12-20-2009, 02:24 AM   #280 (permalink)
Hi Bpd964,
This is the Heli-Chris frame.
Joker
