Old 08-26-2012, 06:33 PM   #1 (permalink)
Default What tail servo to use
I am using Spektrum H3000 servos on my Blade 450x and like them a lot. I didn't change the tail servo, but want to now. Do you use the same servo on the tail, or are they different? Seems like I see one type of servo on the cyclics and a different one on the tail. I looked a Spektrum's site and don't see a "tail" servo that is matched to the H3000's. Could anyone tell me the theory about this, and should I just use another H3000 on the tail?
thanks,
Guy
Logo 800 // Logo 700 12S/14S// Logo 690 // Logo 400 // Mostro 700E's// Whiplash 700E// Gaui NX7 // Gaui NX4 // Gaui X4 // Gaui X3 //Goblin 570 // Trex 250 // TBS Discovery /Naza M2 // Jeti DS-16 // V Control // Jlog // BD3SX// VBar Neo// Lifetime AMA
guyguerra is offline        Reply With Quote Quick reply to this message
Old 08-26-2012, 07:39 PM   #2 (permalink)
I am in the same boat as you are. The H3000 would probably work fine on the tail but is a little bit slow for a tail servo. The only real difference between a cyclic and tail servo is that the cyclic's generally have more torque with the trade-off of being a little bit slower. The tail servo is generally faster but with less torque.
The stock Blade 450 tail servo is rated at 0.03 sec/60° @ 4.8V while the Spektrum H3000 is rated at 0.09 sec/60° @ 6V. So 3 times slower but with 3 times more torque at 30 ounces compared to 11.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote Quick reply to this message
Old 08-26-2012, 08:17 PM   #3 (permalink)
Not familiar with Blade 450X, so will assume it is a standard flybar head assembly, rather than flybarless.
Here's the deal about tail servos. Yes, the tail servo needs to be faster than what most folks use on cyclic (servos attached to your swashplate for elevator/pitch and aileron/roll control). The reason is any servo getting it's signal from a gyro must be faster than the gyro. Otherwise the gyro will be making a new change before the servo is finished correcting for the last change. Chaos ensues.
Generally for beginner and gentle sport flying, a tail servo needs to be at least 0.11 sec (at 4.8V) or faster. The more aggressive you fly, the sloppier your tail will get until you get a faster servo. I just changed from a Futaba 0.11 sec on my tail to a 0.08 sec and the tail holds much better. Doesn't sound like much difference, but it's 27% faster.
Cyclic servos don't have to move any faster than your fingers can move the stick, so will do fine at aprox 0.12 sec or even 0.13, or faster. I like to use metal gears on cyclic servos because crashes tend to put more force onto the cyclic servo gears that could strip non-metal gears. Again, as your flying becomes more aggressive, you'll need faster servos to keep up with you, but that's probably a long way off.
Hope this helps.
Beachcomber is offline        Reply With Quote Quick reply to this message
Old 08-26-2012, 08:21 PM   #4 (permalink)
The 450X is FBL by the way.
Old 08-26-2012, 08:48 PM   #5 (permalink)
The henge and turnigy servos get great reviews. Bin using a power HD on my tail which is strong. It's all metal if your looking for that. $22 at club heli.
Speedster00 is offline        Reply With Quote Quick reply to this message
Old 08-26-2012, 08:48 PM   #6 (permalink)
I just learned a lot. I thought they were different, but didn't know why. Thanks for the clear explanation. Is there a tail servo that you like, or a few that you can recommend? Is it safe to assume that you can mix manufacturers on the tail servo to the cyclic servos? I didn't see a spectrum tail servo on their site, so might have to use Futaba. I'll do some research based on what you outlined.
Thanks,
Guy
Old 08-26-2012, 08:52 PM   #7 (permalink)
Both of my helis have different servo brands. One uses turnigy HVs on cyclic with an MKS on the tail. The other one has a Power HD on the tail and I'm about to replace cyclics with hitecs. No problem mixing brands.
Old 08-26-2012, 09:09 PM   #8 (permalink)
If possible, it's simpler if all your servos can run at the same voltage (6V, ideally, rather than 4.8V). If the cyclics are OK at 6V, but the tail can only take 4.8V, you can install a device to step-down the tail to around 5.2V. But 6V will typically make for a faster servo with more torque anyhow, so a 6V tail servo is nice.
Old 08-27-2012, 06:26 AM   #9 (permalink)
Oops. Thanks for the correction. My comments above about tail servo still apply, but since you're heli is Flybarless, then the cyclic servos need to as fast as the tail, because they are also getting their signals from gyros.
You can use a different brand on the tail, compared to the brand you are using for cyclic, but it's a good idea for all three cyclic servos to be the same brand and model, since they are all working on the swashplate together as one CCPM system (cyclic collective pitch mixing).
As for brand, I don't have a favorite to recommend. Still trying to figure out how much extra I'm paying for the brand name like Futaba or Hitec, vs higher labor costs and similar materials.
Old 08-27-2012, 09:27 AM   #10 (permalink)
Also, most people run mini size servos on the tail and micro on the cyclic. The mini servos are a good bit larger than micro.
WTMorgan is offline        Reply With Quote Quick reply to this message
Old 08-27-2012, 01:18 PM   #11 (permalink)
I have read in a few different threads that Spektrum H3000 servos are re-labeled Savox servos, just like Align servos are re-labeled Savox servos, maybe different models/specs between Align versions and Spektrum ones. If you like Spektrum H3000 servos, you may want to try out matching tail servos made by Savox.
nameci is online now        Reply With Quote Quick reply to this message
Old 08-27-2012, 01:46 PM   #12 (permalink)
Lightbulb
Didn't know that. I'll look them up, Thanks
Old 08-27-2012, 08:44 PM   #13 (permalink)
thanks,
Guy
depends on what you want to spend
futaba 9257 is a old faithful for alot of heli's, the goteck 9257 clone is about 12-14.00 if you shop around and is faster than the futaba counter part, I have been testing one for a month it for the 13.00 I paid for it so far its the best tail servo I've used. Just remember no mater what anyone says do NOT run any 9257 above 5v
Henge 922 works good for about 16.00 tested one for 2 months benched it for the goteck testing
this servo at 5v is ok for a tail and great at 6v but almost 2x the cost of the goteck 9257
http://www.alofthobbies.com/kst-ds115-servo.html
Bottom line is how deep is your wallet
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 08-28-2012, 07:32 AM   #14 (permalink)
Satgod - where did you get your goteck at? Also, do you know if theres any problem running this servo with Logitech 2100? I only ask because I know most people run the 9257's with the GY401 gyros. Thanks
