MSH Protos MSH Protos Helicopter Support Forum |
04-13-2009, 08:59 PM | #21 (permalink) |
My 610 does indeed stop and wait, then restart a few times after the majority of the charge cycle. Thats how I know its close. It stops, checks the cell voltages, and I think discharges the high cell until they are closer matched then ramps up again. The fan kicks off and on during this final stage.
This is one I have had my eye on (Power Supply) for some time now. Whle I am working nicely at 15 amps external, 30 amps is enough to charge two 6S batteries (if/when I get a 610 dual) http://www.rcaccessory.com/index.asp...ROD&ProdID=353 $99.00 |
04-13-2009, 11:06 PM | #22 (permalink) |
HeliFreak Security Staff
IOTA 55 amp power supply on Ebay
you wont regret it same price as the pyramid give or take a few dollars
MSH Protos FBL SK720 Trex 600 14S A123 CCHV110 Actro 24-3 Trex 600 AP 12S A123 CCHV85 NEU 1912 1y Gaui 200 Trex 450 SE V2 Dedicated night Rig |
04-13-2009, 11:15 PM | #23 (permalink) |
Yup, the resting voltage checks are very clear in that graph. Wish I could read the posts from the forum the graph was originally posted in. That charge cycle obviously went through the CV, but maybe they balanced. If the charger can really do away with the CV portion of a charge, I think I will have to get one I would like to see a graph of such a charge cycle.
04-14-2009, 04:38 AM | #24 (permalink) |
I provided a link to a translated version of the web page in my earlier post so that you could read it!
On the Hyperion 0610/0720 chargers you can use the TCS feature to terminate the charge early. On the Junsi iChargers you can disable the balancing altogether if you like and you can set the termination voltage below 4.20V to abbreviate the CV phase.
Kenneth * MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300 * TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550 SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS) |
04-14-2009, 11:15 AM | #25 (permalink) | |
oops... Guess I misunderstood the eliminating CV part. I thought you guys were saying there was a way to charge at CC to full capacity, which would be way cool with a 5c charge rate. I did find this discussion while looking for a full CC graph: http://www.rcgroups.com/forums/showthread.php?t=930750 Looks like applying a voltage greater than 4.2 to a cell will damage it.
04-16-2009, 09:01 PM | #26 (permalink) | |
Have you gotten yours yet? Do they fit the Protos well? How do you mount them, stacked high or flat on their belly? Thanks a lot, Frank |
04-16-2009, 09:17 PM | #27 (permalink) |
So anyone try new packs yet?
I hope to try tomorrow and eagltree it.
Mini Protos BeastX Trex 450 Pro BeastX Protos 500... needs a Brain n00b3D |
04-17-2009, 09:21 AM | #29 (permalink) |
Just picked up mine.
Will fly them till I drop this weekend. Wesp |
04-17-2009, 09:46 AM | #31 (permalink) |
Will post pics and Eagletree.
I have one 6S 2600 pack and 2 3S 2600 pack to run in series. Off to solder my PowerPoles Wesp |
04-17-2009, 09:57 AM | #33 (permalink) |
And now we should also see how running 3s packs in series compares to a single 6s pack.
Steve Trex 450 Pro = MSH Prôtos = Logo 600 |
04-17-2009, 11:15 AM | #34 (permalink) |
Does a 6S 2600mah 35C Hyperion 3G fit in the Protos??
MSH PROTOS 500: Scorpion KV880 & 14t, YGE 60A ESC, 3xS9650, SPARTAN & S9254 |
04-17-2009, 11:35 AM | #35 (permalink) |
HP-LG335-2600-6S 22.2 2600 111mm x 36.5mm x 57.5mm 405.0g
Short little stubby lipo thing should work and the weight is just about right for CG'n
04-17-2009, 01:42 PM | #37 (permalink) |
The 2500, I did not think was much different in size that any standard 6s 2500. Not sure though.
04-17-2009, 01:46 PM | #38 (permalink) |
Belly? Velcro on the widest side, like the 6s2500 Evolite
04-17-2009, 01:58 PM | #39 (permalink) |
Geez, you know your stuff
I am used to the long and thin shape of the Outrage packs. Did not know that the Evolites had the shape of the new Hyperions. Evolite 2500 6S: 114 x 41 x 55 mm Hyperion G3 6S 25C: 111 x 36.5 x 55 mm Thanks a lot, Frank |
04-17-2009, 02:04 PM | #40 (permalink) |
Actually the Evolites have a strange configuration the cells are fat. However I really like them more than my EVO's, they seem to last longer. Its a shame I killed my two 6s3000 Outrage on my Trex 500, they fit nice and balance well on my Protos.
I hope these G3 will stand up to abuse... and when they say 4x life... do they mean 10 cycles or 50 cycles??
