Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 10-23-2010, 11:13 AM   #1 (permalink)
Default New Habu 32 DF ARF from E-Flite
E-flite takes ARF ducted fan performance and engineering to new heights
with the Habu 32 DF. Designed around the E-flite Delta-V® 32 80mm fan
unit and 2150Kv DF32 brushless motor, its hyper-efficient intake and exhaust
ducting allows this potent combo to produce large amounts of thrust when
powered with a high-C 6S Li-Po pack. And it does so without resorting to
drag-inducing cheater holes. The result is a sport EDF with exhilarating speed
that will give even experienced jet jockeys goose bumps.
As the first Platinum Series E-flite® ducted fan, the Habu 32 DF also boasts
a level of fit and finish that is every bit as impressive as its performance.
Its sleek fiberglass fuselage comes pre-painted and integrates the vertical
stabilizer. The fully-sheeted wings and horizontal stabilizers are reinforced
with carbon blade spars and covered with genuine UltraCote®. The control
surfaces are hinged for you. Just add the optional E-flite electric retracts (sold
separately), and you’ve got a sport jet that truly stands out from the crowd.
Features
Designed for a direct bolt-in fit for the E-flite Delta-V 32 power system
Wings and Stabilizers are removable using carbon blade spars and aluminum sockets for easy transport
Painted fiberglass fuselage and a vertical fin with high quality UltraCote covered wings and stabilizer
Designed to fit the E-flite 15-25 sized electric retracts
Fully sheeted wings and stabilizers
Flap Ready
Access hatch for the fan unit and a canopy hatch for easy battery access
Plastic cockpit deck
Specs list for EFL8075
Wingspan 40.5 in (1030mm)
Overall Length 49.5 in (1250mm)
Wing Area 392 sq in (25.3 sq dm)
Flying Weight 7.05 - 7.40 lb (3.20 - 3.35 kg)
Motor Size DF 32 Brushless Motor, 2150Kv
Radio 5+ Channel Radio system
Servos Micro Servos (8 required)
Trim Scheme Colors Ultracote - Deep Red, Silver, Pearl Charcoal
CG (center of gravity) 100-115mm back from the leading edge at wing root
Speed Control 80 Amp brushless
Recommended Battery 6S 22.2V 5000mAh 30C LiPo, 10AWG, EC5
Flaps Yes
Retracts Optional
Control Throw (Ailerons) Low: 7mm Up/Down, 10% Expo; High: 8mm Up/Down, 15% Expo
Control Throw (Elevator) Low: 8mm Up/Down, 10% Expo; High: 10mm Up/Down, 5% Expo
Control Throw (Rudder) Low: 15mm Left/Right, 5% Expo; High: 20mm Left/Right, 12% Expo
Control Throw (Flaps) 11mm take off and cross wind landing; 25mm landing
Approx. Flying Duration 4.5 minutes
Scale Sport Jet
Minimum Age Recommendation 14 years
Experience Level Advanced
Recommended Environment Outdoor
Assembly Time 10-15 Hours
Is Assembly Required Yes
Planes: Crack Yak, Habu, F-27Q Stryker, T-28D, UM P-51D, P-51 BL, UM SU-26XP, P-47D, UMX Beast v1 & 3D, UMX Sbach 342, UMX Extra 300 3D, UM F-27Q Stryker, H9 Mustang 40, UM Mosquito, Sky Angel 650mm Mustang/550mm FW190, FMS B-25, 64mm Mig-15 XG11 DX8
ElIntocable is offline        Reply With Quote Quick reply to this message
Old 10-25-2010, 11:48 AM   #2 (permalink)
At least it's not grey & blue, that one should actually be visible in the sky. My Habu tends to vanish in the sky in certain orientations.
Ace4 is offline        Reply With Quote Quick reply to this message
Old 10-25-2010, 06:22 PM   #3 (permalink)
I'm only flying a GP Escapade now, but this might be my next plane. I considered the foamy Habu but wanted something with retracts and a little bigger. Can't wait to see one of these in person. Are there any cost estimates (ready to fly) yet?
AMA# 902812
More stuff than there is time to fly it.
AFjetmech is offline        Reply With Quote Quick reply to this message
Old 10-26-2010, 11:15 AM   #4 (permalink)
People on rcgroups seemed to be thinking the all-up cost will be close to $1000, which doesn't seem that far off considering the foam Habu is $400 w/ receiver. I think the $1k was including retracts, which that post makes it sound like the kit won't come with them, probably to keep the kit cost lower.
Old 10-31-2010, 10:29 AM   #5 (permalink)
The LHS is saying between $300 and $400 for the airplane and MAYBE a fan unit... Then you have to put a 6s 5000 lipo, motor, ESC, servo's, rx, retracts, etc etc in it... If you don't have the batts already, your looking at atleast $1000...
Comparf Eurosport
1/7 F-14D
Rave 450, scorpion -10, DS285MG, 3500G, Spartan, 4s 2200 outrage, 6100e, 350mm radix
lookin for another Vibe 50
invertmast is offline        Reply With Quote Quick reply to this message
Old 11-10-2010, 11:13 AM   #6 (permalink)
the guys at iHobby confirmed that the plane will NOT come with a fan unit, and will be 1000-1200 all up cost if you already have a radio system.
Even with the hefty price tag, the plane is gorgeous, and a great step in the direction of turbines if you eventually plan to go that route.
700N - Microbeast
MSH Protos - Microbeast
www.ilheli.com
stg099 is offline        Reply With Quote Quick reply to this message
Old 11-10-2010, 09:26 PM   #7 (permalink)
I like it.. but i dont like it THAT much..
Comparf Eurosport
1/7 F-14D
Old 11-21-2010, 09:29 AM   #8 (permalink)
Me WANT.
Terry
AMA#47402, IRCHA # 3395
Old 12-05-2010, 08:29 PM   #9 (permalink)
Should be a nice jet, but eflite needs a slap in the head. Nothing worse than showing off a new product and then saying you can't have one for at least three months.
Trex 500 CF
Trex 600N TT Redline 53 / Outrage Hyper pipe
Trex 700 OS-Align 91 / Align pipe
philjac94 is offline        Reply With Quote Quick reply to this message
