Like Tree9Likes
Old 01-21-2014, 09:36 PM   #321 (permalink)
Default DIY Night blades
LEDs came in the mail today. Didn't take much to wire these up. The hardest part was ordering all the supplies.
This is gonna cost me.
aburkhardt is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 09:24 AM   #322 (permalink)
Default Clear coat blades for nitro protection?
Hey guys, just finished building one of my 710 blades for my 700N. Thanks for all the useful info posted here making my build go smoothly.
Question I have is should I clear coat the blades to protect the copper tape, LED's and resistors from nitro and exhaust?
Katanadude is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 10:26 AM   #323 (permalink)
Yes. I used a 2 part clear. It will help the components stick and protect then from solvents in the exhaust. This was by far the most expensive supply. I think you can buy a 2k clear rattle can for about 20 bucks. Don't forget to clear coat the canopy too!
Sent using Otto correct.
Old 02-26-2014, 08:08 AM   #324 (permalink)
Very good, thanks aburkhardt.
Old 04-01-2014, 12:23 AM   #325 (permalink)
Default Re: DIY Night blades
Hi guys, I've been inspired by you and I've done my 1st night blades for my t-rex 450. Yesterday I just tested the ballance of blades when turned on the heli for a lower speed.
I have 2 LEDs on each blade (top and bott). Using 100mAh lipo.
Here you can see pics.
Odesláno z mého GT-N7100 pomocí Tapatalk 2
djsmeegy is offline        Reply With Quote Quick reply to this message
Old 11-10-2014, 05:02 AM   #326 (permalink)
Very tempting to make one for my 700!
muscleflex is offline        Reply With Quote Quick reply to this message
Old 11-10-2014, 05:27 AM   #327 (permalink)
Ok sorry for asking but why do we only need the resistors on the red LED?
Old 11-10-2014, 07:19 AM   #328 (permalink)
It is a good idea to have resistors on all LEDs. They are very nonlinear. Every color has a certain on-voltage. If that on-voltage is much less than 4.2v then the resistor can eat the difference instead of killing your battery.
If you have multiple colors in parallel then lower voltage colors like green and yellow may cause blue, purple and white to dim if the lower voltage colors don't get a resistor. Every color gets a different value. Usually choose a reaistor that puts you at 10-20mA but it really depends on that LEDs specs.
Gaui NEX6 600mm Blades w/ HK4 4025-1100
Dead heli's flying: Compass 7HVU, 6HVU, Atom 5.5
RIP Compass
electronjunkie is offline        Reply With Quote Quick reply to this message
Old 04-08-2016, 03:35 PM   #329 (permalink)
About to order some 0805 leds and 1/8w resistors. My biggest concern is figuring out how to solder all that in series on the blade.
Old 04-08-2016, 03:46 PM   #330 (permalink)
I wire mine in parallel.
T-Rex 500 ESP GY401/9254, DS510 x 3, Align 425D,Turnigy 6s 2650-3000, Align 500L
T-Rex 450 GY401/9650, HS65MGs x 3, HC CF blades
Blade 400 GY401/9650, HS65MGs x 3, HC CF blades, Zippy 2200 20c x7(shared), Turnigy 2836-3700 Motor, CC35 in Fixed End Point mode, Turnigy 3A UBEC
E-Flite Blade mSR (stock) -- E-Flite Blade mCX (stock)
clkandcjk is offline        Reply With Quote Quick reply to this message
Old 04-08-2016, 03:59 PM   #331 (permalink)
Resistors should be in series with the LED
I turned my brain on for 3 seconds, I can leave a gap in the tape on top and on bottom. For top side lights, led goes on top, resistor on bottom. Opposite for bottom side lights
Old 04-09-2016, 03:09 PM   #332 (permalink)
Not seeing a whole lot of posts here about connectors.
What are people's thoughts on using the 3 pin arrangement versus something like a JST or micro dean's, molex etc?
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 04-09-2016, 05:22 PM   #333 (permalink)
I use the batteries that are made for the Blade nano series helicopters and bought matching pigtails to solder to the copper tape
Old 04-09-2016, 06:45 PM   #334 (permalink)
On 425mm blades it looks like? I was thinking of using a smaller pack, like the 100mah Proto-X battery
Old 04-09-2016, 07:19 PM   #335 (permalink)
Yes, 425mm for my Trex 500. Those batteries look very similar. Whatever you do, consider that the blades will be spinning at high speeds that can pull connectors apart. Note that my configuration causes the centrifugal force to keep the connector pushed on the battery. What size blades are you doing?
Old 04-23-2016, 10:21 PM   #336 (permalink)
My copper strip is wide enough to put two leds in parallel. Might try to do that to increase the brightness
These leds seem so tiny, I'm not sure how bright they'll be
Anyone do this? Or one is good enough
Old 04-27-2016, 11:05 PM   #337 (permalink)
Welp, all soldered up. 2 LEDs per stripe. Call it redundancy. It does double my current draw, but I still figure I can get at least 3 flights out of a 150mah battery. I will do a could of test runs before flying them.
With that said, I'm going to order a couple of Nano CPX batteries to toss on the blades, and try to find some heat shrink.
Next step is to CA the leds. Just a drop per led? On the side between the blade and LED? Should I clear coat the blade after that?
Old 04-28-2016, 09:32 AM   #338 (permalink)
I didn't use CA on mine. I just hit the blades with a couple of coats of spray polyurethane to seal everything up.
HeliFreak Support
Graupner MZ-32
Old 04-28-2016, 10:49 AM   #339 (permalink)
For my gassers that get fuel residue on the blades, I like to hit up the critical junctions with some thin CA then one thin coat of clear. The CA is fuel proof and I don't use two part clear.
The LEDs on the blades will be plenty bright. On my canopy I went from 3 cell to two cell, too bright is not good.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 04-28-2016, 01:53 PM   #340 (permalink)
I was worried the clear would make the blades unserviceable. But they should be long life anyways.
For now I plan to do a preliminary balance using solder to get the blades close to the same. Then I'll clear it and install batteries before doing a final balance. These blade will probably weigh 4lbs each when I'm done haha
