Old 06-23-2012, 11:19 AM   #41 (permalink)
Originally Posted by Groucho_ View Post
I was assuming that there would be a new heat sink from kontronik that one could bolt onto the surface of the kosmik...
So this isn't so?
Datasheet says there will be an additional heatsink to be sold but I have not seen a partnumber for it yet, so I guess it's not out.
Should be less need though since it has the design it has.
http://heli.dacsa.net
Old 06-23-2012, 06:49 PM   #42 (permalink)
Mr.Mel,
I own three HeliJive 120's now..I assume that operations will be the same as far as programming and setting up the new Kosmik??
#1 - Compass 7HV, Scorpion 4530 , VBAR, Kosmik 200
#2 - Logo 700
G200driver is offline        Reply With Quote Quick reply to this message
Old 06-24-2012, 12:39 AM   #43 (permalink)
Originally Posted by G200driver View Post
Mr.Mel,
slightly different but mostly the same, you have basically only 1 heli mode, and then you set options using ProgDisc.
Old 06-24-2012, 01:16 AM   #44 (permalink)
Originally Posted by Jays200 View Post
I got this overnight
Gee I hope Perth RC got my pre-order in fast...I will be spewing if I miss out on the first bunch...anyway Jays I will get to watch you fly yours some more before I get mine up in the air if that's the case :-)
Then again gotta wait for the Pyro motor as well .... patiently waiting in the mean time :-p
Madryan is offline        Reply With Quote Quick reply to this message
Old 06-24-2012, 11:40 AM   #45 (permalink)
Thanks Mr.Mel... Glad I ordered the prog disk
#2 - Logo 700
Old 06-25-2012, 09:33 AM   #46 (permalink)
Do I actually need the ProgDisc or should the one Heli mode take care of most of my needs (I have never messed with the jives I have I just set it to whatever mode I want and off I go)
Logo XXtreme, Kosmik, Pyro 800-48L Futaba 157s/256. Henseleit TDR, Pyro 700-52, 120 Jive, V-Bar 5.3, BLS253/251. Logo 600SE, Scorp 5020-450KV, 120 Helijive, Futaba 451s/251. Logo 400, Align 510MGs, JR 8900G, Kontronik Jive 80+ LV,Mini Pyro 400-14,
jtjohn1 is offline        Reply With Quote Quick reply to this message
Old 06-25-2012, 02:16 PM   #47 (permalink)
I have a Prog Disc 2, is this OK?
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 06-25-2012, 03:43 PM   #48 (permalink)
If PD1 or 2 makes no difference, both are functionally identical and updatable.
Hope you really meant ProgDisc and not Card.
I cannot reply (crazy cookie) but edit: ProgCard w/ the KOSMIK? No, sorry..
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 06-25-2012, 03:51 PM   #49 (permalink)
Oh crap, I meant Prog Card, d'oh.
Prog Disc on its way then lol
Old 06-25-2012, 11:51 PM   #50 (permalink)
Mr. Mel,
Currently run a 2S Lipo pack for power on my Heli with my Helijive 120 instead of using the HJ BEC. What are is your recommandation for my new Kosmik 200? I'm running HV servos. Do you feel comfortable using the BEC on the Kosmik set at 7.4volts and no bufffer pack?
Jim
#2 - Logo 700
Old 06-26-2012, 11:04 AM   #51 (permalink)
Just in time for my Scorpion 4530-540LE!!! No more shut down! Watch that Gobbler go!
How are you planning on mounting the kosmik in the goblin?
Sent from my GT-I9000 using Tapatalk 2
Goblin 700, Gaui X7, 600EFL, DX8
Sharpedge is offline        Reply With Quote Quick reply to this message
Old 06-26-2012, 11:13 AM   #52 (permalink)
Not sure...I've been hoping that it's going to fit! On the road now, hopefully I'll be able to anwser soon...
I'd think that if the HJ 120 with a heat sink on it will fit(use the top hole for the battery tray), that the Kosmik should fit with no problem..
Jim
#2 - Logo 700
Old 06-26-2012, 02:49 PM   #53 (permalink)
Kosmik is wayyy bigger than a Jive120 w/heatsink from what i've seen. It absolutely dominates the front of an Logo700 and even makes the YGE 160 look small. YGE 160s will barely fit in a Goblin without the heatsink so I don't think there's a chance to get a Kosmik into the Goblin's ESC plate without some modifcation. Might be able to mount it on the bottom where the rx pack would mount.
ID:	327266   Click image for larger version
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 06-26-2012, 03:44 PM   #54 (permalink)
It fits into a Goblin. I just asked Marcial from Kontronik. He saw it on the weekend on an airshow in Switzerland.
Tom
Tom (j-log.eu)
Old 06-26-2012, 03:45 PM   #55 (permalink)
Someone mentioned today it comes with no wires or connectors supplied at all.
Is that the case???
Old 06-26-2012, 04:03 PM   #56 (permalink)
Is that the case???
Called a store over on this side of the pond (FastLads) as it is so new they did not know so they got one out the box. They said it had cables and bolts in the box.
Old 06-26-2012, 11:34 PM   #57 (permalink)
It comes with cables but not mounted
Old 06-27-2012, 12:25 AM   #58 (permalink)
Mr Mel,
What are your thoughts on running the Kosmik ESC as compared to running 2S 7.4 for servo power?
#2 - Logo 700
Old 06-27-2012, 01:22 AM   #59 (permalink)
Perfect, thanks
Old 06-27-2012, 01:26 AM   #60 (permalink)
Anyone seen the heat sink for it?
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
