Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Old 11-23-2014, 02:45 AM   #101 (permalink)
Originally Posted by Soccerjay View Post
That's no doubt I have a local buddy you flys the smack out of his goblin 500 with a talon 90 and Kst 515's which have earned a bad rep of failing (both) he has had hundreds of hard flights and nothing. It is possible that some things seen as unreliable are because only the people that have problems post about it. Just another take on the problem, but me I'm taking the high road with bk servos and going safe with a hw 100a v3. My .02c
I don't think you can speak of "going safe with the HW 100 V3" or with any other brand ESC because it can also fail. It's really a matter of luck to, hoping that your ESC doesn’t have a weak spot during build. As I mentioned earlier the story of the YGE 90lv V2 that exploded when the guy connected the battery. It remains a piece of electronics where incredible amounts of amps must go through and it is a relatively small and lightweight electric device, it's a recepi for failure if its not well made and tested. And of course I hope your ESC is doing well! But let's not worry to much and use a ESC which feels for you good to use and have fun flying it. In the beginning I had my doubts about the Talon but I did some heavy testing with it now and it's working great so far, the gov does a good job and the bec voltage is stable at 6v. So I try not to worry to much and fly the Talon just like all others ho hase a Talon, and there ar a lot of them (fingers crossed)
We Men Need a Second Hobby, Besides Women
Futaba, Vbar, Kontronik, Align, IKON, 3GX, Vario, WR Hercules
Mikado, Scorpion, BeastX, Gens Ace, Goblin, Hyperion, JetCat Turbine, APS, BD3SX
www.modelhelicopter-review.nl
trexpro is offline        Reply With Quote Quick reply to this message
Old 12-16-2014, 11:37 PM   #102 (permalink)
hi. just wondering what is the best esc setting pwm and timing for gb500. Using HW 100A Platinum Blue color.
Getting puff batt each flight. motor and batt so hot.
Own :
KDS Agile A3, SAB RAW 580, SAB RAW 700 Piuma
zhnme523 is offline        Reply With Quote Quick reply to this message
Old 12-17-2014, 09:45 AM   #103 (permalink)
We would need to know what motor you have to make a recommendation for settings. You can also check with the motor manufacturer for recommendations.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 12-17-2014, 07:20 PM   #104 (permalink)
Not sure what motor you are using. I'm running a quantum 4120-1200 and the default esc settings work good (pwm=32kHz timing=15*).
Citizen 529
Rotorious is offline        Reply With Quote Quick reply to this message
Old 01-01-2015, 05:21 PM   #105 (permalink)
Are you using the governor in the HW or FBL?
UCPharmD is offline        Reply With Quote Quick reply to this message
Old 01-01-2015, 05:23 PM   #106 (permalink)
HW
Citizen 529
Old 01-02-2015, 07:37 PM   #107 (permalink)
HW
See, my problem is that I'm kinda new at this tuning stuff and I'm using the ikon gov as I understood it to be more proactive than reactive using the hw gov. Anyone out there using the ikon gov and the 4120-1200 wanna post their settings?
Old 01-02-2015, 07:53 PM   #108 (permalink)
We've all been there.
Those settings will be just fine with the ikon gov.
Citizen 529
Old 01-03-2015, 12:12 AM   #109 (permalink)
Well, maiden will be happening on the next off day so long as it doesn't rain.
You guys are awesome and thanks for the help. I just totally redid the head on my G500 cause I didnt know how to fix the binding and my collective and cyclics kept coming up different at max throw after I leveled the swash. Everything is silent now and got even 12 on collective and maxed cyclic til it touched the top of the anti rotation guide then backed off a lil.
Wish me luck!
Old 01-03-2015, 12:25 AM   #110 (permalink)
Happy to help. Good luck!
Citizen 529
Old 01-03-2015, 12:30 AM   #111 (permalink)
FYI, you don't need to set the cyclic limits based on where it binds. You will never use that much throw. It's easier, and perhaps a bit safer, to set it to about 9-10° and check for binding after.
Citizen 529
Old 01-03-2015, 12:32 AM   #112 (permalink)
Hmm. May go back and reduce that then. I was just going off the ikon manual directions.
Thanks again.
Old 01-03-2015, 12:48 AM   #113 (permalink)
Oops, I didn't mean to make you stress over it. You can leave it where it is as long as it isn't binding. It will only use as much cyclic as it needs to achieve the desired roll rate. I was just saying that for future reference.
Citizen 529
Old 01-03-2015, 09:24 AM   #114 (permalink)
Can i use the cyclic ring settings to leave the throws where they are while limiting usage to 10 degrees?
Old 01-03-2015, 09:38 AM   #115 (permalink)
I guess I don't see the harm in that, but it seems a little convoluted. I just use this:
Citizen 529
Old 01-03-2015, 10:37 AM   #116 (permalink)
Exceeding 10 degrees will buy you a nice boom strike most likely. You might want start a new thread instead of discussing it in this ESC thread since this is an unrelated subject.
Old 01-14-2015, 07:13 PM   #117 (permalink)
Is this working well for everyone? After having my 50a version I'm leaning towards this on my g500 with bk minis and pyro 600-11. At $65 it's a steal.
"I fly because it releases my mind from the tyranny of petty things."
JayHelifreak number: 189,781
Soccerjay is offline        Reply With Quote Quick reply to this message
Old 01-14-2015, 07:56 PM   #118 (permalink)
I have a buddy who runs the hw100 plat v3 on his g500 at 2900rpm and flys very hard. Its a great ESC
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo
vertico is offline        Reply With Quote Quick reply to this message
Old 01-14-2015, 08:17 PM   #119 (permalink)
Jay, I don't fly anything close to you but it is holding for me. I have it set at 6v running MKS all around and scorpion.
G700 Comp / G700 KSE / OXY 3 TE / Dx9 Black
Ricky25 is offline        Reply With Quote Quick reply to this message
Old 01-14-2015, 08:51 PM   #120 (permalink)
Still working great.
Citizen 529
