MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
11-16-2010, 10:36 AM | #21 (permalink) |
What's the diameter of the motor shaft? Is it a normal 3.17mm? In all of the pictures it looks larger.
11-16-2010, 12:46 PM | #22 (permalink) | |
Stator Diameter..........22.0 mm (0.87 in) Stator Thickness..........21.0 mm (0.83 in) No. of Stator Arms..........9 Magnet Poles..........6 Motor Wind..........12 Turn Delta Motor Wire..........12-Strand 0.21mm Motor Kv..........2580 RPM / Volt No-Load Current (Io)..........1.50 Amps @ 10 volts Motor Resistance (Rm)..........0.038 Ohms Max Continuous Current..........38 Amps Max Continuous Power.......... 530 Watts Weight..........81 Grams (2.86oz) Outside Diameter.......... 27.9 mm (1.098 in) Shaft Diameter..........3.17 mm (0.125 in) Body Length..........38.3 mm (1.508 in) Overall Shaft Length..........58.7 mm (2.311 in) Max Lipo Cell..........4s Motor Timing..........5deg Drive Frequency..........8kHz
PRÔTOS 450 BRAIN FBL - PRÔTOS 500 BRAIN FBL - PRÔTOS 700 BRAIN FBL http://www.youtube.com/user/Iceberg3D |
11-16-2010, 04:10 PM | #23 (permalink) |
Cool! Thanks for the info. I have a 2500Kv motor on my 450 Pro for running 4s that I could use on the Mini (who would want to fly a Pro if they have a Mini?). On the other hand, for the cost difference on the bare bones v. motor+esc combo you get a really good deal on a Scorpion motor and YGE ESC, so it probably makes the most sense to just go with the combo and keep my Pro flight ready until crash parts become readily available for the Mini.
11-21-2010, 09:35 PM | #24 (permalink) |
Registered Users ):>
Oh shit
Banging them sticks. -Dan Duzinski |
11-27-2010, 04:52 PM | #25 (permalink) | |
David
cdave |
