Warp 360 Compass Warp 360 Model Helicopter Discussion |
07-21-2014, 08:08 PM | #1 (permalink) |
tail control rod
I bought a new tail control rod for my warp build and it seems like its too long, I am using a bigger servo, not micro, and have the output shaft towards the rear of the heli , like it is in the manual , should I shorten the rod( and if so, how?) or turn the servo round and unwind the ball links? or should it be the right length and I've assembled it wrong?
Anthony
Anthony raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba |
07-21-2014, 09:35 PM | #2 (permalink) |
Can you post a pic of it installed? It would be easier if we could see how it fits
Wayne Team Alees Australia AleeS Rush 750 Evolution, vortex Nano. Synergy N5c, Vbar. |
07-21-2014, 09:49 PM | #3 (permalink) |
I decided to cut it, I took about 1/3rd of an inch of , then heated it up with a soldering iron and unscrewed the end , then I jb welded it back in , it is the right length now and appears to be working ok, just a little re-wiring and I will probably maiden it at the weekend. thanks for the help
Anthony
07-22-2014, 07:54 AM | #4 (permalink) |
Re: tail control rod
So now still something is off.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro |
07-22-2014, 11:00 AM | #5 (permalink) |
I use a mini servo for rudder as well and I have had to shorten all of the tail push rods to get correct geometry.
NX4|Tri-Chronos|Chronos|7NT|Specter700 Saje Marvin - Citizen 125 |
07-22-2014, 07:22 PM | #6 (permalink) |
I seem to remember shortening the tail pushrod in both Warps-about 1/8".
I use JR 3500G Tail servos.
KBDD-Team Captain, JR DFA Team Pilot. Forza 450, Forza 600N, Forza 700, Compass 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Steam 550 and 600, OMP M2 (and anything else I can get my hands on...). |
07-22-2014, 08:55 PM | #7 (permalink) |
tail control rod
I ended up going the other direction with my tail pushrod and had to lengthen it. I am also using a mini servo on the tail, but positioned it with the output shaft forward because my servo lead was a wee bit too short. I removed the threaded ends and glued them back in position sticking out 4mm further to stretch the pushrod by 8mm total.
Warp 360, 6HV Ultimate, Mini Comet, Oxy 2, M1 Evo Citizen 46 ---------------- DVC |
