Old 11-19-2012, 06:05 AM   #81 (permalink)
70 flights here, a no vibration problems in this moment. All stock
What is the recommendation of the factory?
Will our birds should be grounded?
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 11-19-2012, 06:07 AM   #82 (permalink)
Originally Posted by Dino Spadaccini View Post
guys i jumped the gun with the tail gears as part the of fix, I just received and email from Align and they have a solution for the hum. Sorry for getting ahead of myself on this matter but the Fix will happen and i will update everyone as soon as i know
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote Quick reply to this message
Old 11-19-2012, 06:56 AM   #83 (permalink)
you should be fine as long as you dont here a hum if you do i would try a lighter set of tail blades this helps the problem \\
As i said before i did jump the gun but the latest email states they have the solution for the hum and will update when it ready sorry for the fpr the delay Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 11-19-2012, 07:14 AM   #84 (permalink)
Thanks,
Ok, I replace the stock tail blades with EDGE 105mm and no vib and no hum.
Thanks in advance.
Old 11-19-2012, 07:55 AM   #85 (permalink)
Default HUM ?
So i think i have the hum i spooled up yesterday and when i got off the ground it just didnt sound clean hard to explane my v2 never sounded like that but sounds like i had a piece of tape from balancing or those hologram stickers they make for blade tips was fluttering but i have no tracking tape or anything on my blades it has been bugging me all night is that what everybody is hearing
Nicasiobantolino is offline        Reply With Quote Quick reply to this message
Old 11-19-2012, 08:00 AM   #86 (permalink)
Default bad set of main blades?
so yesterday i went flying had 2 issues one that weird sound the hum and second i think i got a bad set of main blades like the weight in one blade shifted what was happening is i thought i had a bad vib so i did a bench test with no blades it was really smooth so i went flying and had a bad wobble couldnt find what it was gyro gain or a sticky tail it would just wobble like a 450 with low speed all i did that fixed was change to a set of edge mains and the wobble was gone
Old 11-19-2012, 09:30 AM   #87 (permalink)
if you feel the main are out of spec contact tim at assurance he can set you up with an RMA on the mains
what head speed are you running on the DFC head when you saw the wobble with the align blades
562 598 4700
Old 11-19-2012, 06:19 PM   #88 (permalink)
Not sure if they are off it was suggested to me by another pilot I'm running 1850 1950 2050 with a vbar that is showing high vibes in a hover
Just kept oscillating like the tail was doing a figure 8 and the edge 713 le fixed the prob all that is left is to put the align back on and see if it does it again but I won't fly it till the tail is fixed
Old 11-19-2012, 06:44 PM   #89 (permalink)
Me too. Do you like me?
Please reply.
TREX 700E DFC HV . BEASTX
TREX 450PRO DFC. BEASTX
sipham is offline        Reply With Quote Quick reply to this message
Old 11-19-2012, 06:51 PM   #90 (permalink)
This is technical error from factory.
To align: align to have more incentives to these customers.
Very dangerous for player.
Old 11-19-2012, 07:52 PM   #91 (permalink)
Sounds like the new gear ratio in V3 to speed up the tail is causing resonance( the hum)? This can be fatal to metal like the tail shaft.
Slow the sucker back down and opt for longer tail blades like 115's.
Sounds like align will get it sorted in short order, lots of attention here
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 11-19-2012, 08:07 PM   #92 (permalink)
Once again we know about the problem and have a solution, i will say this for the 100th time if you have the hum dont fly the hub will snap off try a lighter set of tail blades which will stop the hum we have factory pilots testing the solution.
Old 11-20-2012, 02:12 AM   #93 (permalink)
I know this is a long shot but does anyone have a video of the difference in sound between the 'good sounding tail' and the 'bad humming' one?
I realise that for most of you experienced guys, the sound is probably like 'night and day'.
However, the DFC is my first 700 and I have not been flying long enough, or around others, so have no real way of knowing what sounds right and what doesn't.
Kind regards,
B
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 05:40 AM   #94 (permalink)
if you listen to the video i posted that is a normal tail sound if you listen to the video from the guy in Vietnam that is a bad tail with a bad hum you can here it as he spools up
Old 11-20-2012, 07:07 AM   #95 (permalink)
Default Look at the first vid from sipham
He posted a good video of the sound and what happens my 700e dfc is grounded until this is fixed and it would be great full not just to the ones who havnt had the tail snap off but also the ones who have had for align to replace parts for the fix for free and damaged parts to those who have had the failure.not just me but everybody has paid good money around $2000 some more some less and want it to work with no worries this is bad and dangerous guys don't fly until its fixed I won't even try different blades
Old 11-20-2012, 07:22 AM   #96 (permalink)
Any idea where to find the video of the tail that hums? Can't seem to locate it on here..
Thx.
TRex 700DFC CC 120HV/VBar
TRex 500 ESP/FBL CC Ice100, MiniVBar
TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C
Geardaddy is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 08:07 AM   #97 (permalink)
its in this thread look for mine no hum
Old 11-20-2012, 08:28 AM   #98 (permalink)
Thx.
I think what you are looking for, is this page, post #89....
https://www.helifreak.com/showthread...=445050&page=9
Velos 880/Sab Urukay, KSE, Carbon Speed/Mikado Uvular/RCA Blackshark/Chaos 500 Evo, 550, 600, 700/Trex 500, 600, 600 Pro, 700/Roban 470 Cobra, 700 Apache, Cobra, 429, Jayhawk, 800 Airwolf/TFM 800 Blue Thunder, Seahawk, Jayhawk/ DX8 DX18QQ
treotraveler is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 08:37 AM   #99 (permalink)
post 89 is a very bad hum and as you can see he wasnt sure what it was the noise and looked at the tail and spool up again not sure how many time or how long he flew like this
Old 11-20-2012, 02:09 PM   #100 (permalink)
Ah, ok. Thanks guys.
Mine isn't as bad as 'that' but it still doesn't sound quite right. To me at least.
I was going to put the Rail105 tail blades on to if that helps, as well as the 696 mains, but
I think I'll play it safe and not fly until we hear of a resolution of the issue from Dino/Align.
Thanks again.,
B
