Old 09-27-2014, 01:23 AM   #1 (permalink)
Default Lynx tail
Is the Lynx tail a Blingtastic "upgrade" for the guys that think everything should be aluminum, or is this actually a quality precision piece of aluminum?
Trying to trace out a tail issue that I'm pretty sure is tail hardware at this point, but hate to spend $100 on it if it's going to be just as sloppy as the original, which is not all that sloppy to begin.
jbaum81 is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 02:36 AM   #2 (permalink)
The usual advice is to not over tighten your tail fin screws... once I ignored this my 300x flew great.... also the stock hub and grips are of dubious quality.
Anything worth doing, is worth doing badly.
James Recard is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 02:52 AM   #3 (permalink)
I was looking into the rex 450 tail mod but meh... I just ordered the Lynx, I hope I don't regret it. If I can get this tail locked in on this bird I could easily see it becoming a permanent part of my fleet. If not she's headed to the trash bin.
Old 09-27-2014, 10:04 AM   #4 (permalink)
I had the stock case, shaft, pitch slider, and pitch lever on an Align hub and grips with Blade CF blades and it worked pretty perfect for a year or so. I do like bling though, so I got the Lynx tail kit and re-used the Blade CF blades. It is also pretty perfect.
You'll like it I think. I don't believe you *need* it, but it does work well.
-J
BigJay is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 08:17 PM   #5 (permalink)
https://www.helifreak.com/showthread.php?t=624491
Go fly one!
Dustin Mustangs is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 09:38 PM   #6 (permalink)
You will not be disappointed. The quality is outstanding, and it runs smooth as glass.
I'm not in it for the money
jcoop65 is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 09:58 PM   #7 (permalink)
I agree they are excellent parts. I just hope you get the result you're looking for and this is not simply wishful thinking.
But speaking of slop, here is a comparison I did a while back with some hard numbers measuring the differences in precision between the tail pitch lever/slider with the stock and Lynx versions.
https://www.helifreak.com/showthread...97#post5912397
I'll quote myself to make it easy...
Originally Posted by Nelsonisms View Post
I took some measurements off the parts I have on hand using some digital calipers. It's pretty much like I remembered, the pins on the Lynx pitch lever are definitely wider.
  • Stock Lever Pin Diameter: 2.01 mm
  • Lynx Lever Pin Diameter: 2.21 mm
  • Stock Slider Gap Width: 2.20 mm
  • Lynx Slider Gap Width: 2.24 mm
Note: The stock plastic slider is actually kind of inconsistent and varies slightly around the circumference. The numbers above are an average of several measurements I took from each.
So doing the math...
  • Stock Lever with Stock Slider = 2.01 - 2.20 = 0.19 mm slop
  • Stock Lever with Lynx Slider = 2.01 - 2.24 = 0.23mm slop
  • Lynx Lever with Lynx Slider - 2.21 - 2.24 = 0.03 mm slop
  • Lynx Lever with Stock slider = 2.21 - 2.20 = 0.01 mm OVER
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 09-28-2014, 11:42 PM   #8 (permalink)
Well in the past I've been able to eliminate wag with good servos and making sure my tail is clean. Two servos and the same behavior. It's got to be the tail... Unless vbar is just not playing nice with this small of a bird, which I find rather hard to believe... But then again how many people put on a fbl controller worth twice what the bird is worth haha.
Old 09-28-2014, 11:59 PM   #9 (permalink)
Believe me, I hope you're right and I'm wrong. There is less slop with the Lynx setup, so maybe that's it. I want to get rid of the AR7200BX and put either a Mini VBar or Ikon on mine as well, but I'm not ready to pull the trigger just yet. Let us know how it works out.
Old 09-29-2014, 10:49 AM   #10 (permalink)
Well if this doesn't work you should loan me your ar7200bx So I can check and see if it's my bird or the vbar.
Old 09-29-2014, 11:34 AM   #11 (permalink)
Im using the Lynx Ultra tail system and the stock 7200. Tail is rock solid. There's got to be something else there......
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
DCflyer is offline        Reply With Quote Quick reply to this message
Old 09-29-2014, 01:25 PM   #12 (permalink)
I'm using a mini-v bar and a stock tail... I have not yet received the lynx tail... But I am hopeful with some of the reports I've seen.
