A123 A123 Battery Support |
05-05-2009, 08:24 AM | #321 (permalink) |
I'm using the Dimension Engineering Park BEC and have never had an issue in MANY flights.
Bill
2x TRex 650e ; Blade 130x Scorpion motors, Castle ESCs, BeastX FBL 2x Voltz 101k & Honda generator for FAST field charging!! |
05-05-2009, 11:55 PM | #322 (permalink) |
What servos do you run on your 450SE with the ParkBEC Bill ?
Kenneth * MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300 * TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550 SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS) |
05-06-2009, 08:37 AM | #323 (permalink) |
HS65MG on cyclic and 401 / 9650 on the tail.
Bill
05-06-2009, 08:57 AM | #324 (permalink) |
OK, so 3 x analog, gyro + 1 x digital all comfy within the 1.25A rating. Good to know.
05-06-2009, 11:34 AM | #325 (permalink) |
I'm running 3x Hyperion DS09-AMD, 401 and 9650 on a ParkBEC without issue.
Chris Boultinghouse |
05-06-2009, 07:25 PM | #326 (permalink) |
I am lugging around a 13g SportBEC on my 450 (3 x HS65MG, LT2100+little digital tail servo) so I guess I could free it up for a bigger model and save 7g and a little space with a ParkBEC instead Maybe next time. More likely I will swap the CC45+BEC for a K-Force 40 with the built in SBEC, much more convenient IMO.
05-06-2009, 08:45 PM | #327 (permalink) | |
So 2 points for parkBEC and none for SportBEC (kgfly's setup is 4s). I'm still wondering if I should sell the CC45A, SportBEC and Hyperion 35A CC/SBEC and get the Hyperion 50A ... Today I had the Hyperion 35A back in, 3 flawless flights... So Bill, the bog is a weather issue? have you tried a 14T w/ govenor?
Synergy 556, Sab 700, Vbar and Vcontrol |
05-06-2009, 09:59 PM | #328 (permalink) | |
A123s also don't like cold and northern MN is COLD much of the year. We've had one day where it was close to 70 degrees so far this year and the A123s were much happier that day. On 50 degree days the A123s don't put out as much power until after 1 flight and a fast charge. The second flight is much better. I think my bogging is just pushing too hard and expecting too much form the heli. I've got +-13 pitch and fly VERY hard. Not wild 3D but fast, big air flying. This sucks a lot of power. If I get it going flat out and pull through a corner with full collective I can certainly slow the head down. I put new bearings in my HK2221-6 late this winter and just changed them again last night because they were beginning to squeal. The top bearing was much worse than the bottom. I put it in the Greaser just to see what would come out of the bearing, and you wouldn't believe all the black ugly grease that came out. This black gunk is worn metal! Ther bearing was obviously shot. I'll bet I didn't get more than 60-70 flights on this set of bearings. I think it's beause I'm pushing the power system very hard. We had a radar gun at the field and on a downwind run in a dive I got the 450 going 64 mph! Not bad considering that a nitro 600 had to make several passes to get up to the same speed. Bill
05-06-2009, 11:18 PM | #329 (permalink) |
Oh yeah dang some told me parkbec wouldnt be enough. thats good to know your using one and its working.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs. |
05-07-2009, 05:31 PM | #330 (permalink) |
i also have been dealing with tail issues using the cc set rpm gov
figetty bounce type wag that comes an goes. i went thru the tail thinking it was binding . but didnt see a problem .kgfly thanks for posting your experience. ive since lowered the gain to 1 it has got better but cant go any lower. ill try adj the rpm in small increments. T2O did Castle say anything about going up or down in hdsp. an what about the hdsp change rate setting. you guys were asking about bec's thought i would post I remember a time before the 450s when the lite machine was king. a common setup was a CC35 an a mega 16/15/3 brushed motors were out, brushless inrunners were all the rave! People were running Nicads an nimhs what 7.2 or 9.6 v boom lipos hit the market 11.1v 12.6v thats when folks started having esc shutdowns due to the bec overheating having to drop the higher 12 v down to 5 v. you could tell on the CC35 because it melted a small square in the heat shrink were the bec is on the esc. I was running a 555 rec gy401 3x hs 81s .i had a shutdown after 8 mins of flying on a hot day. Then i realized what happened when i saw the hole in the heat shrink, it created its on cooling. Bam! the miracal from the heli gods the park bec hit the market. Any way is this the mythbusters reason we use them today. I also got a servo sense plus that will read the current usage on your control circuit i think it was right at the bec rating , an that was with the larger servos. Since switching to 3s a123, i thought about removing the the park bec. Do you think we need it running the lower voltage with a123s. |
05-07-2009, 07:32 PM | #331 (permalink) |
YES. I would not trust the linear BEC in a CC ESC. On the other I happily run the linear BEC in the Align ESCs on 3S lipo (or 3S A123) with no problems and no overheating issues. For 4S A123 I would only consider a switched-mode BEC, either integrated or external. So if you want to fly a CC ESC I would definitely recommend an external SBEC for any setup, lipo or A123.
05-07-2009, 09:31 PM | #332 (permalink) | |
One advantage to consider with the Park BEC is that 6 volts is available to speed up the servos. On cyclic I don't notice as big of an improvement as I do on the tail. Both of my 450s use 401/9650 and on the 6 volt setup with the Park BEC the tail holds much tighter than the 5 volt powered setup. Bill
05-08-2009, 03:19 PM | #333 (permalink) | ||
05-08-2009, 07:47 PM | #334 (permalink) | |
Bill
05-08-2009, 11:24 PM | #335 (permalink) |
my 1st b400 I was flying it with stock then switched toCC25 esc no extra BEC was going over pitch one afternoon the servos got really slow after moving controls really fast so i added a DE sport BEC next day...
my 2nd newest B400 got stock esc no bec for now I need to get one ut they both flew fine w/o on 4S A123 1100's but i am sure the ESC is getting hot best set up is with a external BEC. I run 9V or 8V (sorry sleep since set it lol)cut off and it lets mew know the heli slowly starts slowning down I know its time to land but I fly to a timer and pretty good about guessing time. I ran 3cell A123 2300's in a airplane for 100 flights with the DE sport BEC on 5v and never had a issue.
05-09-2009, 06:45 AM | #336 (permalink) |
i see your point, it was a random thought, to much trouble to remove it anyway.
it does make a convenient point to hook the castle link up kgfly did you see castle has a new gov https://www.helifreak.com/showthread.php?t=137652 |
05-09-2009, 07:55 AM | #337 (permalink) |
Thanks, I did not see that yet, I will monitor the feedback for a while before trying the update.
05-11-2009, 03:59 PM | #338 (permalink) | |
Bill
05-15-2009, 11:21 PM | #339 (permalink) |
CC45/Scorpion 2221-6 ESC settings...
These are my current settings - does anyone see anything that needs to be changed?
################################################## ##### # Castle Link Data File # Created: Saturday, 16 May 2009 # Do Not Edit This File By Hand ################################################## ##### Hex55: 85 Brake Strength: 0 Brake Delay: .6 sec (Delayed) (*) Brake Ramp: Immediate (*) Cutoff Voltage: 60 Current Limiting: Insensitive Cutoff Type: Soft Cutoff Motor Start Power: 59 Direction: Forward (*) PWM Rate: 8 Khz Vehicle Type: Helicopter Throttle Type: Governor Mode Throttle Response: 5 Governor Gain: 14 Initial Spool-Up Rate: 5 Head Speed Change Rate: 5 Auto Rotate Enabled: False Governor Mode Type: High Vehicle Setup - Battery Type: A123 Vehicle Setup - Number of Cells: 3 Vehicle Setup - Battery Voltage: 9.9000 Vehicle Setup - Gear Ratio: 13.633 Vehicle Setup - Motor Kv: 4400 Vehicle Setup - Motor Number of Poles: 6 Desired Head Speed 1: 2411 Desired Head Speed 2: 2508 Desired Head Speed 3: 2713 Motor Timing: 0 Power-On Beep: Disabled Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*)
CopterX 450SE, 3S A123. HS65MG cyclic, 9257 tail, 325 wood blades, AR7000 Scorpion 2221-6/CC45 ESC, GY401 gyro , Spider Gear. Lama V4 AR6100 brushless, Xtreme Blades. Blade mCX Blue LED, Shortened flybar and boom. |
05-16-2009, 07:27 PM | #340 (permalink) |
What is the cut -off voltage 60?
Many disable the cutoff voltage completely with A123 You are running an 11 tooth pinion? I dont think the ESC will be able to maintan your 2713 rpm. I have found that my packs average around 2.7 volts per cell over the course of the flight. With the 11T that gets you only about 2500 and thats at 95% eff. Of course your results may be better than mine. |
