300X Blade 300X Helicopters Information and Help |
09-20-2014, 02:29 PM | #1081 (permalink) | ||
I'm still running the plastic grips as well. I actually have some aluminum ones, but I like the plastics better. No problems there.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon) Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi) AMA Member, HCAM Member |
09-20-2014, 10:48 PM | #1082 (permalink) |
Most definitely. The stock plastic head, grips, and swash are very strong and durable. I have three 300Xs (I just sold a forth one I had)... I have metal head/grips on one (running 4s) and plastic head/grips on the other two. I've had the plastic head and grips up past 4000RPM without issue.
09-21-2014, 03:24 AM | #1083 (permalink) | |
...with a splash of Lynx dampers, the stock makes the head feel loose...
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV) Lynx Team Pilot / Oxy Field Rep |
01-01-2017, 08:44 AM | #1084 (permalink) |
What's a good esc to run with the scorpion 2213-14?
01-06-2017, 11:39 AM | #1085 (permalink) |
That motor is rated 32 amps, you would probably want a 35 amp ESC. I like the Castle Talon.
04-21-2018, 01:57 PM | #1086 (permalink) |
320H/250 CFX Main Motor Replacement?
My 250 CFX came with the same 320H motor as y'alls 300X
Do you know which motor may work in the 250's small frame without over-taxing its ESC? I am not sure... -do you think a 39 gram 250-size motor Lynx 1911 on 3S would work? It is only 3600kv, yet similar weight, so i suppose i could try a different pinion to make up for rpm loss (the 320H is supposedly 41.5 grams stock) The Lynx 2214 V2 looks way too large. Will likely tax the dual esc... Yall have the most experience with similar motor replacement versus the 250 forum... not trying to get off-topic. Thanks for any ideas
Hangar223: Logo 480 Xxtreme (prjct), DX6i, Heli-X demo, several airplanes, Club Saito RCGroups Last edited by Bunnyshooter223; 04-21-2018 at 06:55 PM.. |
11-08-2019, 03:35 AM | #1087 (permalink) |
So what's the easiest hop-up motor to install/use that's available now? And does anyone have a link to get one?
Helis: Blade 150s, Blade 300x (own 2), Spektrum ix12, -RC Cars: Tamiya TRF 417x, Traxxas E Revo, HPI WR8, -Boats: Proboat Recoil 17 |
11-08-2019, 11:16 PM | #1088 (permalink) |
How’s many cells do you want to run?
11-08-2019, 11:54 PM | #1089 (permalink) |
Drop in a Lynx 4S 4100kV motor with 1350mAh 4S packs...
Do the math for pinion size (most likely will be a 10T) http://www.jmrware.com/misc/hscalc.html 136T main gear will give 3200 @ 80 TC...3400 @ 85 TC https://www.ebay.com/itm/LYX8005-Lyn...0AAOSwgmJX1RdN Last One !! |
11-09-2019, 02:48 AM | #1090 (permalink) | |
I want to stick to stock esc and 3s
11-09-2019, 08:56 AM | #1091 (permalink) |
Scorpion 2213-14 is a solid motor for a 3s setup ungoverned with a 12t pinion. I ran one on my 300x (lynx frame) for hundreds of flights on 4s governed with a talon 35a at 3600 3800 & 4000 and it was great although it did just throw a magnet. I’ve since replaced it with the eox 2214, to match my Oxy3, which is def a bit stronger. Keep in mind if you go the scorpion route you’ll have to file/grind a flat on the shaft and they recommend lubing the bearings every couple of flights.
11-09-2019, 09:44 AM | #1092 (permalink) | |
You can use the Lynx w/3S...adjust the pinion for the head speed You need When I saw the words hop-up in You OP I thought 4S |
05-02-2020, 04:59 PM | #1093 (permalink) |
I'm doing another 300x rebuild with all my spares... I can't find any upgraded motors anymore, either they are on back order or discontinued, anyone have some links to buy?
03-08-2023, 02:11 PM | #1094 (permalink) |
Old threads.
Wow! Shadows and Dust! I recently cleaned out my closet and found my old 300x stuff packed away in a random box. I then logged in to see what was going on in the forum. Vaporware! Shadows and dust, Maximus!
DJI F550 (Hexa) + JR9503 (storage). Blade MQX (old and crusty). 300x (sold). 450x (sold). |
